Does the path between two points always have to be contiguous?
In summary, the conversation revolves around the concept of teleportation or "cheating" in terms of space travel and whether it is possible within the realm of quantum physics. The speaker brings up the idea of causality and how it may be less important than concepts like conservation of energy and momentum. The conversation also delves into the implications of general relativity and how it can affect our understanding of space and time. Ultimately, the speaker admits that understanding these concepts can be difficult and complex.
FireStorm000
169
This is more of a hypothetical "it doesn't work, but WHY?", but what stops something from being at point A now, then moving to a different point an instant later without traveling through the space in-between? What makes it so that the motion we observe is always (nearly) contiguous? Is there a theorem that explicitly prevents you from, say, "teleporting" between two points, or having a "Wormhole" that doesn't respect the normal notion of distance?
You are talking about quantum physics right? A particle in a well may have a zero wave function at some locations in the well. This doesn't mean the particle can't pass those positions, it just means you will never find it there. The particle can go from the left edge of the well to the right edge of the well while never being at the zero points in the well.
I was kind of looking at various FTL ideas from different SciFi and asking myself "why wouldn't that work?". One of the ones I've always struggled with are the ones that "cheat" and simply say that the object of interest doesn't have to cross the intervening space, or does so in a way that the notion of distance changes. And it's even more confusing because that does have a parallels in QM.
As far as I know, occupying two points that are space-like separated brings up problems like causality whether or not your cross the intervening space.
IDK, it seems to me like breaking causality is far less... important, than say breaking conservation of energy or momentum.
You are mistaken then.
How could causality possibly be as important as conservation of energy or momentum?
But why do you think that energy or momentum have something to do with being in two places at once ?
Ultimately its an individual's judgement call which one is more important. But I agree, causality is very very hard to imagine being violated. Momentum and energy conversations are not necessarily intuitive. Many people have thought they don't exist. But who has thought that perhaps you can die by a bullet before the trigger is pulled? Intuitivity, that is real nonsense and that is what your occupation of space-like points without crossing intervening space seems to imply.
Fair enough. As much of a mind bending craziness as SR seems, it's impossible to deny the evidence for it. You wouldn't necessarily have to give up the idea of causality altogether, but definitely the SR version of it. And with it all the rest of relativity. Which basically leaves you back at square one.
How do you define global energy and momentum without a well-ordered time? How do you define "the global energy at some point in time", if there is no clear way to find successive times in the universe?
Note that general relativity has no global "points in time", and correspondingly it has no global energy/momentum conservation.
I suppose it causality really is more important that it seems.
The old adage "Truth is stranger than fiction" seems to apply here. The closer you get to something that accurately describes many cases in physics, the farther you get from what we observe in everyday life. Goodness does GR/SR imply some strange things.
It isn't really a "strange" implication. The act of generalizing space-time to curved semi-riemannian manifolds brings in the caveat that not all space-times have killing vector fields. However, if for example a space-time has a time-like killing vector field (these are called stationary space-times) then there is a globally conserved energy current which is easily proven.
WannabeNewton said:
It isn't really a "strange" implication. The act of generalizing space-time to curved semi-riemannian manifolds brings in the caveat that not all space-times have killing vector fields. However, if for example a space-time has a time-like killing vector field (these are called stationary space-times) then there is a globally conserved energy current.
Lol, it's going to be a couple years yet before I actually understand what you just said. Conceptually I understand much of what SR and GR imply, but the mathematics make my brain melt. I've only the fuzziest grasp on this Tensor stuff.
1. Does the path between two points always have to be contiguous?
No, the path between two points does not always have to be contiguous. In some cases, there may be obstacles or other factors that prevent a direct, contiguous path between two points.
2. What does it mean for a path to be contiguous?
A contiguous path refers to a continuous, uninterrupted path between two points. This means that there are no breaks or gaps in the path.
3. Can a non-contiguous path still be considered a path?
Yes, a non-contiguous path can still be considered a path as long as it connects two points and allows for travel between them. However, it may not be the most efficient or direct route.
4. Are there any advantages to a non-contiguous path?
In some cases, a non-contiguous path may provide certain advantages. For example, it may allow for the avoidance of certain obstacles or provide a more scenic route.
5. How do scientists study and analyze paths between two points?
Scientists use various methods and techniques, such as mathematical models and computer simulations, to study and analyze paths between two points. They also take into account factors such as terrain, obstacles, and efficiency when evaluating different paths.
  • Precalculus Mathematics Homework Help
  • General Math
  • Differential Geometry
