Conservation of Linear and Angular Momentum
In summary, the collision between the spheres results in the center of mass moving downwards with a velocity v0. After the collision, the system has a linear velocity v1 and an angular velocity omega1.
NeuronalMan
We have two spheres of equal mass, M, and radius R. One of them is initially at rest (in space, apparently) and the other is moving downwards with a velocity v0. Air resistance is given by an approximation (see below). Consider a completely inelastic, linear collision between the two spheres. What is the velocity v1 of the center of mass of the system of two spheres, after the collision? And similarly, what is the angular velocity omega1 of the sytem?
The only equation that I think might be relevant is that of air resistance, which is Fv = -kvV, where kv is a constant. This is to say that the air resistance is proportional to the velocity, though. Obviously other relevant equations would be conservation of linear and angular momentum, but these I consider to be so fundamental that I don't write them down.
In problems like these, one is inclined to use conservation of momentum, and that is what first crossed my thoughts when I looked at this problem. As for the angular momentum, the net external torque is zero (at least for the linear case), so angular momentum is conserved. That should make it easy to find the angular velocity omega1 for the system of two spheres. However, I have never seen any problem like this, concerning linear momentum. It seems to me that the linear momentum cannot be conserved during the collision, because the net force acting on the system, isn't zero. Namely the weight due to gravity and air resistance. Thus, I am left with no other way of finding the linear velocity v1.
There is also a general case in which the line between the centers of the spheres, form an angle, theta, with the horizontal. And in the general case, the same frustration arises for angular momentum, as I believe air resistance act with a torque on the system.
I didn't yet take the time to learn the LaTeX-codes for writing formulas and equations, but I hope you can bear with my symbols.
Hi NeuronalMan,
It is true that the net force on the system is not zero if there is gravity and air resistance. However, if the time duration of the collision is very small, we can consider momentum to be conserved, becuase the momentum relation is (for average external force):
[tex]
\vec F_{\rm ext} \Delta t = \Delta \vec p
[/tex]
So if [itex]\Delta t[/itex] is vanishingly small, then momentum is for practical purposes conserved over the time interval of the collision.
I'm having an assignment with the exact same problem. In it there's a sentence saying that we can consider the collision to be instantaneous and thus we can ignore the gravity and air resistance.
alphysicist said:
Hi NeuronalMan,
[tex]
[/tex]
Thank you for your reply--it was most helpful.
To my great disdain, there is no such sentence in my assignment, and as happens, I feel compelled to do things the hard way.
The sentence has been added between the 3rd and 4th revision of the assignment... perhaps that's why?
Just find it odd if we don't have the same assignment, considering the striking similarities :)
1. What is the law of conservation of linear momentum?
The law of conservation of linear momentum states that the total momentum of a closed system remains constant over time, as long as there are no external forces acting on the system.
2. How is linear momentum calculated?
Linear momentum is calculated by multiplying an object's mass by its velocity. The formula for linear momentum is p = m * v, where p represents momentum, m represents mass, and v represents velocity.
3. What is the difference between linear and angular momentum?
Linear momentum refers to the motion of an object in a straight line, while angular momentum refers to the motion of an object in a circular or rotational motion. Linear momentum is a vector quantity, while angular momentum is a vector quantity with direction perpendicular to the plane of rotation.
4. What factors affect the conservation of linear and angular momentum?
The conservation of linear and angular momentum is affected by the mass, velocity, and direction of an object. External forces acting on the system can also affect the conservation of momentum. Inelastic collisions, where some energy is lost, can also affect the conservation of momentum.
5. How does the conservation of linear and angular momentum apply in real-life situations?
The conservation of linear and angular momentum is seen in many real-life situations, such as in sports like ice skating or figure skating, where the skater's angular momentum is conserved as they spin. It is also seen in car accidents, where the momentum of each car is conserved in a collision, and in rocket launches, where the conservation of momentum allows the rocket to gain speed and reach orbit.
