Desk addition for raising and lowering monitor/keyboard/mouse setup
  • Thread starter workindan
  • Tags
    Addition
In summary, the idea is to build a desk that can be raised and lowered with a simple system, but it needs to be adjustable to account for future changes.
workindan
I'm looking to build my own desk addition that will allow me to raise and lower my work setup (keyboard, mouse and monitor) any time I like and with a fair amount of ease. I was inspired by the "Ergotron Workfit" but find the price tag beyond my range for now.
Attached is a laughably incomplete design...but it's in the right direction:
1) you can set it on top of and clamp it to your current desk
2) It's simple
Obviously the thing I've got here would fall apart...but does anyone have any ideas on how to get a platform to raise and lower around 30-35lbs?
http://dl.dropbox.com/u/22827/photos/deskaddition.jpg
2) It's simple
Welcome to the PF.
The link doesn't appear to work. Can you fix it or re-post a link?
Checked it on my iphone and another computer, the link shows up fine. Is it not loading for you? -->
LINK: http://dl.dropbox.com/u/22827/photos/deskaddition.jpg
How about a spring for the lifting capacity? Then have the desk on a rail system.
Is that the best way to go? What about hydraulics?
The counterweight concept is fine, just add a method to lock the desk position. That can be as simple as drilling holes in the frame for pins/dowels (similar to the way adjustable shelving is supported), but there are myriad options available.
Also, you might want to make the weight adjustable to account for future changes in the load.
I'll try the counterweight out and see what I get built. I'll post pics when I get something together.
1. How does a desk addition for raising and lowering monitor/keyboard/mouse setup work?
A desk addition for raising and lowering monitor/keyboard/mouse setup typically consists of a platform or tray that can be attached to the desk and adjusted to different heights. It may also have a mechanism, such as a gas spring or electric motor, that allows for smooth and easy height adjustments.
2. What are the benefits of using a desk addition for raising and lowering monitor/keyboard/mouse setup?
Using a desk addition for raising and lowering your monitor, keyboard, and mouse can help improve your posture and reduce strain on your neck, shoulders, and back. It can also allow you to switch between sitting and standing positions throughout the day, promoting movement and reducing the risks of a sedentary lifestyle.
3. Can a desk addition for raising and lowering monitor/keyboard/mouse setup accommodate different monitor and keyboard sizes?
Yes, most desk additions for raising and lowering monitor/keyboard/mouse setup are designed to be adjustable and can accommodate different sizes of monitors and keyboards. However, it is important to check the weight limit and dimensions of the desk addition to ensure it can support your specific setup.
4. Is a desk addition for raising and lowering monitor/keyboard/mouse setup easy to install?
The ease of installation may vary depending on the specific desk addition. Some may require minimal assembly and can be easily attached to the desk, while others may require more complex installation. It is recommended to follow the instructions provided by the manufacturer or seek professional help if needed.
5. Are there any additional features to consider when purchasing a desk addition for raising and lowering monitor/keyboard/mouse setup?
Some desk additions may come with additional features, such as built-in cable management systems, storage compartments, or adjustable keyboard trays. It is important to consider your specific needs and preferences when choosing a desk addition for your setup.
