Integration involving trig. substitution
In summary, the conversation revolves around self-study of Calculus II and the use of trigonometric substitution in integrals. The person seeking help is unsure about the legality and limitations of using trigonometric substitution and is concerned about potential errors in their work. They receive helpful advice and clarification on the concept, leading to a resolution of their doubts.
Mangoes
96
See below.
2. The attempt at a solution
Hey there, apologies for doing so, but I don't know how to use latex on this board (it doesn't show me anything when I hit preview, so I had to make a picture for the sake of cleanness.
imgur.com/WzrAR.png
The first line is the original problem, with the proceeding lines being the attempt I made.
I have about four months before I transfer to a new university and figured I might as well self-study Calculus. I finished Calculus I without any trouble so I just started doing what I will eventually cover in Calculus II, but unfortunately my textbook offers only a mechanical way of doing this technique which leaves some doubt in my mind.
Is trigonometric substitution legal to do in any integral (regardless of whether it will actually help integrating) so long as you also substitute any related variables to the one you're substituting with? I've tried it out with simple indefinite integrals like ∫3x^2 dx but I'm unsure whether or not issues would occur if I substituted, for example, x = tan(θ) for ∫1/x due to the fact that 1/tan(θ) is undefined in an infinite amount of inputs while 1/x is undefined in only one.
Furthermore, I've looked over my work and I can't find any errors, so I don't know whether there's some concept I'm completely missing out on or there's some hidden error I just can't see.
Thanks for any input.
You are messing up in the integration by parts section. Otherwise, well done! You are partially ignoring the presence of the 9/4 factor. Try it this way. Just integrate sec^3 by parts. Add the 9/4 factor later.
Your work looks good, and nothing immediately pops out at me. I think that you have a constant wrong somewhere.
I'll take a closer look and see if I can spot where the problem is.
I suppose trig substitution could be applied to any integral, but where it's most commonly used is where you have the square root of a sum or difference of squares. The radical can appear in the numerator, but commonly appears in the denominator.
The idea with trig substitution is to apply the substitution to get an integral that you can actually evaluate, so I don't see it used with cube roots, or the like, or with simple polynomials or power functions, as in your example.
LaTeX isn't hard to use. Here's the LaTeX for the integral you started with. To make it actually render, put a pair of $ signs at the beginning, and another pair at the end.
\int \sqrt{9 + 16x^2}dx
Edit: Dick beat me to it, so I won't take a closer look.
Thank you! I followed your suggestion and saw that the result I had was indeed different than what I had previously gotten. After multiplying that by 9/4, differentiating gives my original function. :smile:
Yeah, I can see where it's convenient to use, I was just wondering if there were any inputs in which θ would lead to an undefined expression where, in the original expression written in terms of x, there would be a defined answer.
However, I worked it out for a specific example on paper and saw that when θ gave undefined values, the corresponding x for that θ would have given undefined values anyways. Sorry if my wording was a little strange, but I'm satisfied now. It had been bothering me for a couple of days.
It should all work out ok. If you take your original example of integrating 1/x by substituting x=tan(t) you should wind up with log(|tan(t)|). Sure that has problems all over the place, but when you change back to x you get log(|x|) and everything is ok again. Glad you are feeling better about it.
What is trigonometric substitution?
Trigonometric substitution is a method used in integration to simplify integrands involving trigonometric functions. It involves substituting a trigonometric function for a variable in an integral, making it easier to solve.
When should I use trigonometric substitution?
Trigonometric substitution is most commonly used when the integrand contains square roots of quadratic expressions, or when it involves a combination of trigonometric functions.
What is the process for using trigonometric substitution?
The process for using trigonometric substitution involves identifying which substitution will make the integrand simpler, substituting the variable with the appropriate trigonometric function, and then solving the integral using trigonometric identities.
What are the common trigonometric substitutions?
The most common trigonometric substitutions are:
  • For integrals involving √(a^2 - x^2): x = a sin θ
  • For integrals involving √(x^2 + a^2): x = a tan θ
  • For integrals involving √(x^2 - a^2): x = a sec θ
Do I always need to use trigonometric substitution in integration?
No, trigonometric substitution is an optional method in integration and there may be other methods that can be used to solve the integral. However, it is a useful tool for simplifying certain types of integrals and can make the integration process easier.
