Potential Due to a Charged non conducting sphere
In summary, the conversation discusses the calculation of potential and electric field inside a charged sphere. The formula for electric field inside a non-conducting sphere is provided, along with the formula for potential which requires integration. It is noted that the formula for electric field changes between infinity and the point of interest and that the potential must be calculated in two steps. The conversation ends with the resolution of the question.
snshusat161
214
[tex]
\bold{V}\ =\ \frac{Q\,(3R^2\ -\ r^2)}{4\,\pi\,\varepsilon_0 \ \ {2R^3}}
[/tex]
Potential inside the sphere.
Electric field inside the sphere (non conducting):
[tex]
\bold{E}\ =\ \frac{Q.r}{4\,\pi\,\varepsilon_0\,R^3}
[/tex]
and
[tex]
\bold{V}\ = \int E.dr[/tex]
In one dimension.
Even when we use both the formula's I've given we don't get the one given in the book. Does anybody here have some suggestion to find, how they have derived it.
How have you used the formulae you are given? What have you tried to do?
Note that to calculate the potential you must integrate from infinity up to the point that you're concerned about - in this case the formula for the electric field changes between infinity and your point.
What do you know about the electric field inside a charged sphere?
Electric field is zero inside charged conducting sphere but not in the case of non conducting sphere.
Yes, sorry, I misread your post - I've edited it now.
Thanks, It is solved now. Actually we have to calculate it in two steps. work required to bring unit positive charge from infinity to the surface and then from surface to some point inside the sphere.
BTW, thanks once again gadje. Sometime a very small hint can trigger our mind.
1. What is potential due to a charged non conducting sphere?
The potential due to a charged non conducting sphere is the electrical potential energy per unit charge at a point in space caused by the presence of a charged non conducting sphere. It is a measure of the potential energy of a test charge placed in the electric field created by the sphere.
2. How is potential due to a charged non conducting sphere calculated?
The potential due to a charged non conducting sphere can be calculated using the formula V = kQ/r, where V is the potential, k is the Coulomb's constant, Q is the charge of the sphere, and r is the distance from the center of the sphere.
3. What is the relation between potential and electric field for a charged non conducting sphere?
The electric field created by a charged non conducting sphere is directly proportional to the potential at any point in space. This means that as the potential increases, the electric field also increases.
4. Does the potential due to a charged non conducting sphere depend on the size of the sphere?
Yes, the potential due to a charged non conducting sphere is directly proportional to the size of the sphere. This means that a larger sphere will have a greater potential than a smaller sphere, given the same charge.
5. How does the potential due to a charged non conducting sphere change with distance?
The potential due to a charged non conducting sphere decreases with increasing distance from the center of the sphere. This is because the electric field strength decreases with distance, resulting in a decrease in potential. The potential also becomes zero at an infinite distance from the sphere.
