Thread Closed
Does the Universe have a "Frame Rate"?
Share Thread Thread Tools
Feb21-13, 01:53 PM   #1
Surely, thinking about it, things can't just smoothly transpose from one location to another, there must be regular gaps, (far to quickly for us to notice) where it "jumps" from one point in space to another. I think this because it seems hard to imagine how something can go from one place to another perfectly smoothly with absolutely no "gaps" between "frames". Otherwise, the frame-rate would be infinite, which is impossible. Sorry if this seems stupid it's just something that has intrigued me.
My physics teacher said this seemed viable, and said it could have something to do with the properties of sub-atomic particles.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Feb21-13, 02:37 PM   #2
mfb
Mentor
No.
The universe is not limited by your imagination.
Processes as short as 10-25 seconds can be observed (indirectly), and I think a step size close to that value would seriously influence those results.
On the planck scale (10-43 seconds), things might look different.
Feb21-13, 02:51 PM   #3
Recognitions:
Gold Membership Gold Member
Quote by Braders790 View Post
... I think this because it seems hard to imagine ...
To expand on what mfb said, one of the first things that you MUST do if you are going to study either cosmology or quantum mechanics is realize that our "instincts / common sense / intuition / etc" are UTTERLY USELESS for very large and very small scales. We rely on those thing to tell us about human scales, where they ARE useful, but they are not extensible to large numbers of things at very large and very small scales.
Feb21-13, 02:53 PM   #4
Quote by mfb View Post
No.
I mean, faster "gaps" than we could possibly perceive. so if you filmed, say a car going past, and slowed it down hundreds of billions of times, (assuming the camera had no frame-rate limit) would it still appear to be moving smoothly, or would it, (on a sub-atomic level) phase out of, and into existence moving forward as it does so. If I'm wrong, could you explain how, (physically) it's possible that things in the universe move completely smoothly, with no frame-rate what-so-ever because I can't see how that would work
Feb21-13, 02:57 PM   #5
I don't see why it shouldn't work. A bit of understanding of calculus, especially differential equations, wouldn't hurt, a lot of it studies "instantaneous" conditions, and solutions to relations between "instantaneous" conditions.
Note that time being quantized (which is pretty much what you're suggesting) is possible, though, with current observation, if it is quantized, then the "frame rate" is absurdly fast.
Feb21-13, 03:08 PM   #6
Quote by Whovian View Post
I've read that Plank time is the amount of time it takes light to travel 1 plank unit, and light is the fastest thing in the universe, and the plank is the smallest thing in the universe, (which we can measure). 1 Plank length is 1.616199 × 10^-35 Metres. The speed of light is 300,000,000 m/s (give or take). There is approximately 6.18735688 × 10^34 planck lengths in 1 metre. Therefore there is 1.85 x 10^43 Plank lengths covered in 1 second by light, so would this be the universal frame-rate 1.85 x 10^43 Fps?
Feb21-13, 03:10 PM   #7
mfb
Mentor
I think I understood quite well what you meant.
Use real numbers to describe time. Actually, all current models of physics do that, and they work extremely well.
You cannot simulate this perfectly on a digital computer - so what?
Feb21-13, 04:15 PM   #8
I think one good argument why discrete time is implausible is that it is hard to discretize equations of motion so that energy and other quantities are conserved. While with continuous time, we can write down differential equations, and these then imply the conservation of energy quite easily.
Feb21-13, 05:16 PM   #9
Recognitions:
No, I don't think so. It is just a particular measure. It IS way smaller than anything we can currently measure, but so what?
Feb21-13, 05:45 PM   #10
That usually the justification for atomism, but that type of argument isn't really convincing IMO. Sure, given our limited minds, we cannot conceive of dimensions or processes without viewing them as something discrete, but that doesn't mean that the world we live in necessarily has to be the same. In fact, such "frames" or "building blocks" may not even exist at all for all we know, and may be nothing more than just an artifact of our minds.
Feb22-13, 07:46 AM   #11
Mentor
Locked pending moderation
Feb22-13, 07:55 AM   #12
Mentor
The problem with this thread and the way it is going is that a lot of the discussion, and the way it started, it based on PERSONAL PREFERENCE. When it is based on that, then this becomes purely speculative and in direct violation of the PF Rules that everyone has agreed to.
We welcome such topics. HOWEVER, it must be based on either accepted peer-reviewed journals, or based on established physics. If you are arguing for something, and you are simply using what feels OK with you and nothing else, then that is not allowed. If you want to know if time is discrete, or can be discrete, then ASK JUST THAT, without imposing your opinion of it, especially when you don't know much about that subject area. If not, topic such as this will continue to be either locked, or deleted for rules violation.
Zz.
Thread Closed
Tags
frame, movement, quantum, rate, universe
Thread Tools
Similar Threads for: Does the Universe have a "Frame Rate"?
Thread Forum Replies
Meaning of a "Flat," "Open," and "Closed" Universe Cosmology 21
does the hup essentially represent the "wall" or "curtain" of the universe? Quantum Physics 7
Can one approximate an "ether" frame by analyzing "superimposed" rotating frames? Classical Physics 0
"The universe is expanding" & "the universe is infinite" General Astronomy 21
Two Reviews: "God's Equation" and "Universe In A Nutshell" Science Textbook Discussion 9
