Does virtual particle-antiparticle annihilation produce anything?
In summary, virtual particle-antiparticle pairs are not the same as traditional particle-antiparticle pairs, as they do not produce anything tangible and are merely fluctuations in vacuum energy. These pairs are represented in calculations as steps and probabilities of interaction, and in the case of a photon creating a virtual pair, it is represented by a fermionic propagator in Feynman diagrams.
kdlsw
My understand is, the virtual particle-antiparticle pairs created under uncertainty principle are not the same as the traditional particle-antiparticle (creates new particle after annihilation), the virtual ones does not produce anything, since they are created from nowhere, which the antiparticle must have exact but opposite (negative) energy as the particle.
Please correct if my understanding is not right. Thanks
The virtual particle-antiparticle pairs are understood as fluctuations in vacuum energy - the Feynman diagram shows a photon in and a photon out with the pair in a single loop between them.
The thing about virtual particles is that they are virtual - think of them as steps in a calculation and things should settle down for you. Their presence in the math represents a probability of an interaction.
Let's talk for electron and positron...
they create the real photon... you can see the pair of particle antiparticle in analogy to how you see a virtual photon being emitted and reabsorbed .. In the photon's case you have a bosonic propagator which, in the qft formalism, you integrate over all possible momenta. In the case of a photon creating a pair of virtual electron+positron, you deal with is as a fermionic propagator, which has different form, but still the idea is the same. All these correspond to several possible loops which exist in Feynman's diagrams...
All this as an additional comment to Simon's post #2...
1. What is virtual particle-antiparticle annihilation?
Virtual particle-antiparticle annihilation refers to the process where a particle and its corresponding antiparticle spontaneously appear from the vacuum, exist for a brief moment, and then annihilate each other, producing energy in the form of photons.
2. Does virtual particle-antiparticle annihilation produce anything?
Yes, virtual particle-antiparticle annihilation produces energy in the form of photons. This process is a manifestation of the uncertainty principle in quantum mechanics.
3. How does virtual particle-antiparticle annihilation occur?
Virtual particle-antiparticle annihilation occurs through the creation and annihilation of virtual particles in the quantum vacuum. These particles are not observable, but their effects can be measured through their influence on other particles.
4. Can virtual particle-antiparticle annihilation be observed?
No, virtual particle-antiparticle annihilation cannot be directly observed as it occurs at a subatomic level. However, its effects can be observed through various experiments and calculations in quantum mechanics.
5. What is the significance of virtual particle-antiparticle annihilation in physics?
Virtual particle-antiparticle annihilation is significant because it helps explain the behavior and interactions of particles at a quantum level. It also plays a role in various phenomena, such as the Casimir effect and Hawking radiation.
  • High Energy, Nuclear, Particle Physics
  • Other Physics Topics
  • Science Fiction and Fantasy Media
