What's the difference btw double and triple integrals
In summary: Yes, you can use a double integral to find the volume of a solid by solving for V in terms of x, y, and z. However, you will need to solve for V in terms of x, y, and z given only one equation.
denian
641
i read both double and triple integrals can be used to find the volume.
so, what's the difference?
Double integrals integrate over two variables -- for example, x and y on a plane -- and can be used to calculate areas, but not volumes.
Triple integrals integrate over three variables -- for example, x, y, and z in Cartesian three-dimensional space -- and can be used to calculate volumes.
- Warren
A double integral involves two variables you integrate, a triple 3 variables (guess the pattern...). They can be used to find many things, depending on how you use them, if you use them to 'find' anything.
Sorry, chroot but that isn't exactly accurate.
Take single integrals. They can be used to find path length or areas, same with double and triple integrals. It depends on what the integrand is and what integral is with respect to.
Just to illustrate the situation:
Let the volume of a region be given by:
[tex]V=\iint_{A}\int^{s(x,y)}_{h(x,y)}dzdydx, (x,y)\in{A}[/tex]
Then, we have the trivial conversion into a double integral computation:
[tex]V=\iint_{A}(s(x,y)-h(x,y))dydx[/tex]
I know it's not exactly accurate; I suppose I should have said more.
- Warren
matt grime said:
Take single integrals. They can be used to find path length or areas...(snip)
...or even volumes.
Long story short: You can use a triple integral with a unit integrand ([itex]
\int\int\int dV[/itex]) to find the volume of any closed figure in [itex]\mathbb{R}^3[/itex]. The boundary of the region is encoded in the limits of integration. You can use double integrals of the form [itex]\int\int f(x_1,x_2) dS[/itex] to find the volume of a region in [itex]\mathbb{R}^3[/itex] provided that the region is partially bounded by the surface [itex]x_3=f(x_1,x_2)[/itex]. And lastly you can use single integrals to find volumes of regions of [itex]\mathbb{R}^3[/itex] bounded by surfaces of revolution.
Loosely speaking the fewer integrations in your volume computation, the more picky you have to be about the region.
tq.
i want to ask another question:
is it possible to find the volume of the solid by double integration,
if only one equation is given
x/3 + y/4 + z/5 = 1
i got the answer -30
is it correct?
1. What is the difference between double and triple integrals?
The main difference between double and triple integrals is the number of variables involved. Double integrals involve two variables, typically represented by x and y, while triple integrals involve three variables, typically represented by x, y, and z. This means that double integrals are calculated over a two-dimensional region, while triple integrals are calculated over a three-dimensional region.
2. How are double and triple integrals related?
Double and triple integrals are related in that a triple integral can be thought of as a series of nested double integrals. This means that the innermost double integral is calculated first, then the result is used as the integrand for the next double integral, and so on until all the integrals have been calculated.
3. Can a double integral be converted into a triple integral?
Yes, a double integral can be converted into a triple integral by simply adding an extra variable and an extra integration step. For example, if a double integral is being calculated over a region R in the xy-plane, the equivalent triple integral would be calculated over the same region R but with an added z variable and an extra integration step over the z-axis.
4. What are some practical applications of double and triple integrals?
Double and triple integrals are used in many fields of science, such as physics, engineering, economics, and statistics. They are particularly useful for calculating quantities such as volume, mass, and center of mass for three-dimensional objects or systems. They are also used in solving differential equations, finding areas and volumes of complex shapes, and in probability and statistics.
5. Are there any special techniques for solving double and triple integrals?
Yes, there are several special techniques for solving double and triple integrals, such as using polar or spherical coordinates, using the method of substitution, and using symmetry to simplify the integrand. Additionally, numerical methods such as Monte Carlo integration can be used for more complex integrals that cannot be solved analytically.
