Probability distribution for hard sphere elastic collisons
In summary, the conversation discussed various aspects of modeling neutron moderation, including the number of collisions required for fast neutrons to be moderated, the distribution of energy absorbed by the moderator, and the use of mean free path and Monte Carlo simulations. There was also mention of the concept of energy transfer in elastic collisions and the possibility of using cross-section to calculate the probability of sphere collisions.
Jack_O
65
I'm researching neutron moderators and I want to model how many collisions are required for fast neutrons to be moderated to thermal temperatures and the distribution of energy absorbed by the moderator during the process. I have quickly worked out the %age velocity reduction for the simple head on 1d elastic collisions:
http://dl.dropbox.com/u/4550021/1d%20elastic.xls
(100% for H1, 67% for D2 and 15% for C12, i.e. light water, heavy water and graphite moderators) For graphite i can then say the largest energy absorbed is 1-(1-0.15)2 because KE is proportional to v2(e.g. for 1MeV neutron first C12 would receive 278KeV). To cool a 1MeV neutron to 0.1eV with head on graphite collisions would be (log0.1-log106)/log(1-0.15)=99 collisions.
But I'm struggling to come up with a more realistic 3d model because I can't find a probability distribution for sphere collisions.
Basically I'm looking for a graph with radius of a sphere from 0 to 1 on the x-axis and probability of impact (of an incident sphere) on the y axis.
Hello,
Your research on neutron moderators sounds very interesting. Neutron moderation is an important aspect in nuclear reactors, so it's great that you are looking into it.
To model the number of collisions required for fast neutrons to be moderated to thermal temperatures, you can use the concept of mean free path. Mean free path is the average distance a neutron travels before colliding with a moderator. This can be calculated using the cross-section of the moderator material and the density of the moderator.
For a more realistic 3D model, you can use Monte Carlo simulations. This involves randomly generating the positions and velocities of neutrons and tracking their interactions with the moderator. By repeating this process many times, you can obtain a probability distribution for the number of collisions required for neutron moderation.
For the distribution of energy absorbed by the moderator during the process, you can use the concept of energy transfer in elastic collisions. This involves calculating the energy transferred from the neutron to the moderator in each collision and summing these energies over all collisions. This will give you a distribution of energy absorbed by the moderator.
I'm not sure if there is a specific graph that shows the probability of impact for a sphere collision, but you can use the concept of cross-section to calculate the probability of a neutron colliding with a moderator of a certain size.
I hope this helps with your research. Good luck!
1. What is a hard sphere elastic collision?
A hard sphere elastic collision is a type of collision between two spherical objects where there is no loss of kinetic energy. This means that the total kinetic energy of the objects before and after the collision remains the same.
2. How is the probability distribution for hard sphere elastic collisions calculated?
The probability distribution for hard sphere elastic collisions is calculated using the Maxwell-Boltzmann distribution. This distribution takes into account the velocities and masses of the colliding spheres, as well as the temperature and pressure of the system.
3. What factors affect the probability distribution for hard sphere elastic collisions?
The probability distribution for hard sphere elastic collisions is affected by factors such as the size and shape of the colliding spheres, the temperature and pressure of the system, and the speed and direction of the spheres' motion.
4. How does the probability distribution for hard sphere elastic collisions change with increasing temperature?
As the temperature increases, the probability distribution for hard sphere elastic collisions shifts towards higher velocities. This is because at higher temperatures, the particles have more kinetic energy and are more likely to collide with greater force.
5. What is the significance of the probability distribution for hard sphere elastic collisions in physics?
The probability distribution for hard sphere elastic collisions is important in understanding the behavior of gases and other particles in thermodynamic systems. It helps to predict the likelihood of collisions and the resulting outcomes, and is a fundamental concept in the study of kinetic theory and statistical mechanics.
  • Nuclear Engineering
29K
