Statics, centroids of lines, areas and volumes
In summary, the conversation is about calculating moments of forces and using the equation M = r x f or M = fd. Later, they discuss calculating the center of gravity using the moments principle and the equation x = ∫xdw/W. The confusion arises when trying to understand examples 5.12a and 5.12b, specifically the moment arms around the x-axis. After some discussion, it is clarified that in 5.12a, the gravity acts on the z-axis at point C and in 5.12b, to calculate zc, the gravity is acting parallel to the x-axis and to calculate xc, the gravity is acting parallel to the z-axis. Additionally, the moment arm is not necessarily the
jonjacson
447
38
Hi to everybody.
I´m reading a book about statics and I cannot understand this chapter. I have been calculating moments of forces in hundreds of problems, when I found a force acting on a body I needed to fix a coordinate system, then calculating the moment arms of that force around a point and then using the equation M= r x f, or M=fd if it was a simple case on a plane.
Now they start talking about calculating the center of gravity and using the moments principle (the sum of the moments has a resultant that passes throught the center of gravity) they give this equation:
x = ∫xdw/ W
The point is that x is the moment arm of the force dw (differential weight) around the x-axis if I am right.
Well if that is true, What is the meaning of this advice some pages later in the book?
I see the logic, you need to use the coordinate of the centroid of the differential element when you are integrating, but I cannot understand examples 5.12 a, and 5.12 b.
In the first example the only option to see any logic for those moment arms is assuming that the gravity is acting on the z axis at point C. Until here it could be right.
But now I cannot understand in any way example 5.12 b, it says that the moment arm of the differential element has a moment arm of xc around axis x, if that is true WHat is the axis in which the gravity is acting??
There are three options:
1.- If gravity acts on the x-axis to point C, we have a force parallel to the x-axis so the moment is zero, this cannot be the case.
2.- If gravity acts on the y-axis to point C, the moment arm is zc but the book says clearly that zc is not the moment arm, that it is xc, so this cannot be the case.
3.- So the only option should be gravity acting on the z axis to point C, but that would cross the x-axis since due to symmetry around z axis.
So I understand you need to use the centroids of the differential elements, not the boundaries, but in this case I cannot see in any way that zc is the moment arm around x-axis for that element.
Does anybody know the line of action of the gravity in that example? And what about the moment arms of the element of 5.12 b?
Maybe I´m confused and it has some logic, but now I cannot understand this.
Does anybody know something about this?
In 5.12a, pretend the gravity acts at point C perpendicular to the image (parallel to the z-axis).
In 5.12b, to calculate zc, pretend gravity is acting parallel with the x-axis perpendicular to the y-z plane. To calculate xc, pretend gravity is acting parallel with the z-axis perpendicular to the x-y plane.
Thank you very much for your answer!
Ups I see, when you calculate xc, yc and zc you imagine an orthogonal direction for the gravity, in an hypothetical case. Then in reality, gravity will act only on a particular direction and you will use only one of those coordinates, thanks.
Now just another question, I feel bad asking this because it seems too basic, in 5.12 a for example, the moment arm of the differential element around the x-axis I think it is yc, not xc.
As I understand it the moment arm around an axis for a given force is the shortest distance, if we have a force on the z axis at point C, the shortest distance to the x-axis is yc, not xc. Maybe I have a bad day and I don´t understand anything, I don´t know, but I cannot see how xc is used as moment arm around the x axis.
The same happens with the y axis, in that case I see that the moment arm is xc, so the equations should look like this:
[itex]\overline{x}[/itex] = ∫ yc dA / A
[itex]\overline{y}[/itex] = ∫ xc dA/ A
I don´t understand why they are using the distance yc as moment arm around the y axis, and xc for the x axis.
I don't understand your comments about the moment arm being the 'shortest' distance.
The centroidal distance xc is the location along the x-axis about which the area, volume, mass, etc. is balanced. Another way to look at it is as a weighted average, where the weighting factor is the distance along the x-axis from the origin. Ditto for yc and the y-axis and zc and the z-axis.
I have just realized what was my mistake, I misread a sentence and I thought that this equation:
[itex]\bar{x}[/itex] = ∫x dW / W
Was for the moment around the x axis, that´s why I didn´t understand the moment arms, in fact this is the equation for the moments around the y-axis and now everything makes sense.
I´m sorry for my mistakes :( .
Thank you very much, and see you in other threads!
What is statics?
Statics is a branch of mechanics that deals with the study of objects at rest or in constant motion. It involves the analysis of forces acting on objects and their effects on their equilibrium.
What is a centroid?
A centroid is the geometric center of a shape or object. In statics, it is an important point used to determine the distribution of forces and moments acting on an object.
How do you calculate the centroid of a line?
The centroid of a line is calculated by finding the average of its endpoints. For a straight line, the centroid is located at the midpoint. For a curved line, the centroid can be found using integral calculus.
What is the significance of centroids in statics?
Centroids play a crucial role in statics as they help determine the point of application of forces on an object, which is necessary for calculating the object's stability and equilibrium.
How do you find the centroid of a composite shape?
To find the centroid of a composite shape, the shape can be divided into smaller, simpler shapes whose centroids are known. The centroid of the composite shape can then be calculated using the principle of superposition, which states that the centroid of a composite shape is the weighted average of the individual centroids.
  • Classical Physics
  • Classical Physics
  • Mechanics
  • Classical Physics
28K
  • Classical Physics
