Frictional Force (and μ) & Acceleration (w/friction)
In summary, the conversation discusses a problem involving two blocks connected by a string and a pulley, with one block on a table and the other hanging off the edge. The system starts from rest and the hanging mass falls a certain distance with a given downward speed. The question asks for the frictional force between the two blocks, and the conversation covers how to solve for this using equations for summing forces and finding acceleration. It is mentioned that friction is automatically included in the kinematic equations. The conversation also addresses the relationship between friction, mass, and acceleration, but notes that solving for friction directly is more efficient.
ceceliaz
1. The problem: 2 blocks are arranged at the ends of a
massless string (mass one is on a table and mass two is hanging straight down off the other side of the pulley that is connected to the edge of the table). The system starts from rest. When the 4.18 kg (the hanging mass) mass has fallen through 0.389 m, its down-ward speed is 1.29 m/s.
The acceleration of gravity is 9.8 m/s2 .
mass one (on table)=5.68 kg
mass two (hanging)=4.18 kg
μ=?
a=? (to the right towards the hanging mass)
What is the frictional force between the 5.68 kg mass and the table?
Answer in units of N.
2. I put together the SumFx and SumFy to make the equation to solve for frictional force:
μ(subk)= (m2)g-a(m1+m2) / (m1g)
3. However, I need acceleration. I tried using both (vf=vi+at) and (vf^2-vi^2/(2deltaX)), but it was wrong (probably because those formulas don't take into account friction.
QUESTION 1: How do you find friction or acceleration without each other?
QUESTION 2: Is "frictional force" the (μ) times (mass on the table) times (acceleration)?
Finding the acceleration is a kinematic exercise; friction is automatically included since the speeds are given. Redo your calculation--those kinematic equations should work just fine.
You don't. But you have all the information needed to solve for acceleration, and then for the friction.
No. But why are you solving for μ? Calling the friction force "F" and solve for it directly. (Friction equals μmg, but that's not needed unless you are asked to solve for μ.)
Frictional force is a force that opposes the motion of an object and is caused by the interaction between two surfaces. In this case, the frictional force between the 5.68 kg mass and the table can be calculated using the equation μN, where μ is the coefficient of friction and N is the normal force between the two surfaces. The normal force can be found by multiplying the mass of the object by the acceleration due to gravity, which in this case is 9.8 m/s^2.
To find the coefficient of friction, we can use the equation μ = (m2g - a(m1+m2))/(m1g), as you have correctly identified. However, in order to solve for the frictional force, we need to know the acceleration of the system, which is not provided in the given information.
To find the acceleration, we can use the equation F = ma, where F is the net force acting on the system. In this case, the net force is equal to the difference between the weight of the hanging mass and the tension in the string. Once we have found the acceleration, we can use it to solve for the frictional force using the equation μN.
To answer your first question, friction and acceleration are related to each other as they both depend on the net force acting on an object. In order to find one, we need to know the other. In this case, we need to find the acceleration in order to solve for the frictional force.
To answer your second question, frictional force is not equal to μ times the mass on the table times acceleration. The correct equation is μN, where N is the normal force between the two surfaces. The normal force depends on the weight of the object and the acceleration due to gravity, not the mass on the table.
What is frictional force?
Frictional force is the force that opposes motion between two surfaces that are in contact with each other. It is caused by irregularities in the surfaces and can be influenced by factors such as the type of material and the force pressing the surfaces together.
How is frictional force calculated?
The formula for calculating frictional force is: F = μN, where F is the frictional force, μ is the coefficient of friction, and N is the normal force. The coefficient of friction is a constant value that depends on the materials in contact, and the normal force is the force exerted by one surface on the other in a direction perpendicular to the surfaces.
What is the relationship between frictional force and acceleration?
Frictional force and acceleration have an inverse relationship. As frictional force increases, acceleration decreases, and vice versa. This is because frictional force acts in the opposite direction of the motion, thus slowing down the objects in motion.
What factors affect the coefficient of friction?
The coefficient of friction can be affected by several factors, including the type of material, the roughness of the surfaces, the amount of force pressing the surfaces together, and the presence of any lubricants or contaminants on the surfaces.
How does friction affect the motion of an object?
Friction can either assist or resist the motion of an object. It can assist by providing enough traction for an object to move, such as in the case of walking or driving a car. It can also resist motion by acting in the opposite direction, slowing down or stopping an object's movement. The amount of friction present can greatly impact the speed and direction of an object's motion.
