Concentration of solids and liquids in Chemical Equilibrium
In summary, the concentration of pure solids and pure liquids is not taken into consideration in equilibrium constant expressions because their concentration per unit volume does not change and they do not undergo any reaction. However, for solids in contact with a solution, their activity is assumed to be 1. For pure liquids, their activity is also assumed to be 1, but this is a convoluted concept that is still not fully understood.
zorro
1,384
Why don't we take into consideration the concentration of pure solids and pure liquids in equilibrium constant expression?
I read that their concentration per unit volume does not change.
If the concentrations (moles per litre) don't change then it won't undergo any reaction i.e. it has no use in the reaction. How is it possible?
If we keep the reactants (say all gases) in a closed container, then their volume does not change. But no. of moles change so we can say that the concentration changes.
But this is not the case in solids(pure) and (liquids)
Please provide detailed explanation
Technically concentration of solid that is in contact with the solution is zero in the solution, isn't it? However, it can react on the surface. As long as the surface exists, reaction is possible, and amount of solid doesn't matter. We assume its concentration to be 1, but more correct term to use is "activity" - and activity of the solid is 1.
Note that reaction quotient, which is usually expressed using concentrations, should be in fact expressed using activities.
Activity = activity_coefficient * concentration
For diluted solutions activity coefficient is 1, for more concentrated solutions it initially gets lower, later gets higher. This is quite convoluted and details are still not fully understood, even if the phenomenon is researched for well over 100 years.
What about a pure liquid?
1. What is concentration in chemical equilibrium?
Concentration in chemical equilibrium refers to the amount of a substance present in a given volume or amount of a solution at a particular point in time. It is an important factor in determining the direction and rate of a chemical reaction.
2. How does concentration affect chemical equilibrium?
The concentration of reactants and products in a chemical equilibrium system determines the position of the equilibrium and the overall rate of the reaction. Higher concentrations of reactants will favor the forward reaction, while higher concentrations of products will favor the reverse reaction.
3. How is concentration measured in chemical equilibrium?
The concentration of a substance in a solution can be measured in various units, such as molarity (M), molality (m), or percent by mass (%). In chemical equilibrium, the concentrations of the different substances involved in the reaction can be determined using equilibrium expressions and equilibrium constants.
4. How can concentration be manipulated to shift the equilibrium?
By altering the concentration of reactants or products in a chemical equilibrium system, the position of the equilibrium can be shifted. Adding more reactants will shift the equilibrium towards the products, while adding more products will shift it towards the reactants. Additionally, changing the volume or pressure of the system can also affect the equilibrium concentrations.
5. Can concentration ever reach a point of complete equilibrium?
In theory, yes, concentration can reach a point of complete equilibrium where the rates of the forward and reverse reactions are equal and the concentrations of reactants and products remain constant. However, in reality, many factors such as temperature, pressure, and catalysts can affect the equilibrium and prevent it from reaching a state of complete balance.
  • Chemistry
