Calculating the amount in moles
  • Thread starter Struggling
  • Tags
    Moles
In summary, to calculate the amount of Cl- ions in 13.4g of nickel chloride (NiCl2), you can use the formula n=m/M, where n is the number of moles, m is the mass, and M is the molar mass. First, find the number of moles of NiCl2 by dividing the mass (13.4g) by the molar mass (130g). Then, since each mole of NiCl2 contains 2 moles of Cl- ions, you can double the number of moles to find the number of Cl- ions. This gives an answer of 0.206 moles of Cl- ions in 13.4g of NiCl2.
Struggling
52
hi guys, need help with a question.
i know how to get the amount of a substance in moles from something like NaCl in 5.85g of salt you just use n = m/M
but would like to know how to:
calculate the amount(in mole) of:
cl ions in 13.4 g of nickel chloride(NiCl2)
i know the answer i just can't get it
Chemistry news on Phys.org
How many moles of chloride are there in a mole of nickel dichloride...?
Daniel.
sorry i forgot to add that in 35.5 is the atomic mass of cholrine(Cl)
There is very little difference to this from what you normally do. What do you do to find the number of moles from the mass and molar mass? Well you know that because you stated it. What is the molar mass of Cl2? That should answer your question.
The Bob (2004 ©)
This is not required.
The question asks for the number of moles of Cl- ions. How many such ions are there in one molecule of NiCl2 ? Therefore, how many moles will there be in each mole of NiCl2 ? Finally, how many moles of NiCl2 are there ?
Point made. Good call. :smile:
However I would find the percentage, by mass, between the two elements and then work out how many there are of chlorine. Then I would work out the number of moles this represented.
Your way, though, is simplier.
The Bob (2004 ©)
i still can't get the right answer I've got:
the amount (in mole) of Cl ions in 13.4g of nickel chloride (NiCl2)
Cl molar mass = 35.5
Ni molar mass = 59
NiCl2 molar mass = 130
n= m/M --> n = 13.4/35.5 = 0.37746
and then i don't understand I've tried getting the percentage from 130 moles and all that but it comes nowhere near the answer.
the answer is 0.207 moles but i always seem to get .188 moles or .338 around those figures
Premise:
13.4 g of NiCl_{2}------------------->(13.4/130) moles of NiCl_{2}
*) 2 moles of Cl^{-}------------------->1 mole of NiCl_{2}
*) x moles of Cl^{-}-------------------->13.4/130 moles of NiCl_{2}
Daniel.
arghh i still don't get it, this is killing me
I see you're really struggling :tongue2:Which line of the 3 I've written is fuzzy...?
Daniel.
this line:
i can't seem to get the answer from it, I've been stuck on this thing for days
This is something I've learned in 6-th grade.Translating it mot-à-mot from Romanian,i'd call it "the rule of 3 simple".
Basically it is a ratio.U have to find the "x" by using logics to obtain the correct ratio.HINT:Check out the units.They should cancel.
For example a ratio:x moles/y moles=x/y which is just a number.
Daniel.
eeeeek, i don't think were as well taught as europeans are here in australia.
im still not understanding, I am sort of getting the cancelling out part but i shall try again in the morning its late here now. wat i understand is that the units cancel each other out that is moles, so the equation is x/y = x/y am i wrong here?
Understand the reasoning. Read post #5 first. Answer each of those 3 simple questions and you'll see that you are doing exactly what Dexter did in post #8.
I also struggled with this in chemistry:
Find the number of cl- ions in 13.4 g of nickel chloride(NiCl2)
n(cl)=13.4g/M(Ni) +2M(Cl)
n(cl)=13.4/129.7
therefore n(cl)=0.103 mol
For the next step you have to look at the mole ratios
For every 1 mole of NiCl_2, there will be 2 moles of Cl- ions present
Therefore all you have to do is double the answer from above
2*0.103 = 0.206 or 2.6 * 10^-1 in scientific notation
You have 13.4g of nickel(II) chloride, or NiCl2 (13.4g NiCl2/1)
The molar mass of NiCl2 is, as you stated, about 130. (1mol NiCl2/130g NiCl2)
From this you can find the moles of NiCl2. (13.4g/1)(1mol/130g) = (13.4/130) mol NiCl2
Now the only question left is: How many moles of Cl- are in a single mole of NiCl2? As you can see, each molecule of NiCl2 has two chlorine ions, so each mole of NiCl2 will have 2 moles of chlorine ions.
You can set up a conversion factor with this: (2mol Cl-/1mol NiCl2)
Now you just convert from mol NiCl2 to mol Cl-.
The whole thing looks like this:
(13.4g NiCl2/1)(1mol NiCl2/130g NiCl2)(2mol Cl-/1mol NiCl2) = n mol Cl-
As you can see, the units cancel out. to give you mol Cl-.
You correctly calculated number of moles, but not number of ions.
You also successfully posted in almost 6 years old thread. This is called necroposting.
Fortunately the curriculum hasn't changed much and the same question is on page 15 of the Heinemann Chemistry 2 4th Edition -Enhanced-
and I was having exactly the same problem as the VCE graduate before me, which is now solved. THANKS :D
hi
in simple way,
1mole of NiCl2 contains 2mole of Cl-
13.4/130 mole of NiCl2 contains Y mole of Cl-
then Y=13.4*2/130 mole C-
What is a mole?
A mole is a unit of measurement used in chemistry to represent the amount of a substance. It is defined as the amount of a substance that contains the same number of particles (atoms, molecules, or ions) as there are atoms in exactly 12 grams of pure carbon-12.
How do you calculate the amount in moles?
To calculate the amount in moles, you need to know the mass of the substance and its molar mass. The molar mass is the mass of one mole of the substance, expressed in grams per mole. You can calculate the amount in moles by dividing the mass of the substance by its molar mass.
Why is it important to calculate the amount in moles?
Calculating the amount in moles allows you to accurately measure and compare the quantities of different substances in chemical reactions. It also helps in determining the quantities of reactants and products needed for a reaction.
What are the units for amount in moles?
The unit for amount in moles is "mol". It is often written after the numerical value, for example, 2 mol.
Can you convert between moles and other units of measurement?
Yes, you can convert between moles and other units of measurement such as mass or volume. This can be done by using the molar mass or molar volume of the substance. It is important to note that the conversion factor is different for each substance and can be found by using the molar mass or molar volume.
  • Chemistry
  • Chemistry
  • Mechanical Engineering
  • Chemistry
