Electric field produced by electron
In summary, the conversation discussed the concept of a two-dimensional wave function, psy(x,y), and its relationship to the probability distribution |psi(x,y)|^2 of the position of an electron. The conversation then delved into the question of how to find the electric field strength produced by an electron at a given position, and various methods were suggested, such as using the effective potential or calculating the potential from the charge density. The conversation also touched on the complexities of handling this question in quantum field theory. Finally, there was discussion about the direction of the A(vector) and how to find it given the information of 'Ar'.
Kruger
214
Lets imagine the wavefunction psy(x,y) and with this the probability distribution |psi(x,y)|^2 of the position of an electron is given. psy(x,y) is a two dimensional wave function.
So how can I find the electric field strength produced by this electon at position x=3, y=2?
I'm confused. Assuming the wave function for the electron, how can you then say that the electron is at (3,2)?
I don't say it is there. I want to know, if the wave function of an electron is given by psi(x,y) how can we then find the distribution of the electric field E(x,y) produce by this electron (described with psi(x,y)) ? This is my question.
i hope i will be able to address your question after i complete my course on field theory. At meantime, let's bump this, someone here should know...
There can be answers at different levels (of approximation).
The simplest one is the "effective potential", which is used in quantum chemistry: just calculate the |psi|^2, and put that equal to a charge density. Then calculate the E-field from this charge density.
This method is not entirely correct however.
A "better" way would be, if we can use an electrostatic approximation, to consider the "E field" to be in a superposition of different values, each corresponding to a different position of the electron, and with an amplitude given by the amplitude of the electron to be in that position (namely, psi(x,y)).
In QFT, what you ask is a terribly tricky question ! I'm not sure that there is an entirely correct way of handling it.
Ah, thanks. I only need the easy one.
What you mean is this differential equation?
dE(x,y)/dx+dE(x,y)/dy=|psi(x,y)|^2/e0 where e0 is the electric permittivity
Seems to be a good approximation for me, better an easy one.
Can I change this formula in that way, that I can get E(x,y) immediately?
What you wrote down is only Gauss' law. That's not good enough to find E !
You better calculate the potential from the density:
[tex] V(p) = -1/\epsilon_0 \int d^3r |\psi|^2/|r-p| [/tex]
(check this, typing from memory...)
cheers,
Patrick.
nov.02.2005
One must also consider whether the electron is a solid sphericle particle or hollow sphericle body to describe the field strength?
dr_syed_ameen
Nope, in this case, when the electron's described at quantum level, it's assumed a pointlike particle.
Poisson's equation for the electrostatic potential reads
[tex] \nabla^{2}V\left(\vec{r}\right) =-\frac{\rho\left(\vec{r}\right)}{\epsilon_{0}} [/tex]
with the charge density given by Vanesch.
Daniel.
Ok. let's assume I have the following wave function (not normalised):
psi(x,y)=exp[kx+ky]
Sorry, I can't calculate this. What means "p" in Vanesch's equation? And why do I have to integrate this. I mean p(r) is the charge densitity and the charge density of an electron's wave function is just |psi|^2. And how can I get the electric field strength produced by the electron out of the electric potential, which I guess isn't static?
Could I also do this:
Calculate |psi|^2 which is equal to the charge density. And then if the charge density at the point x=2 and y=3 (example) would be 0.33 I can immedialtely calculate the electic field strength on this point.
psi(x,y)=exp[kx+ky]
This one diverges. Next, please...:tongue2:
That's actually "rho".
It is VERY STATIC.
Not that "immediate". You've been already told what to do.
Daniel.
The solution I liked the most was that in which you consider the wave function as an instrument for you to know the state of quantum coherent superpositions of different field values at a given point.
Nothing more natural than this procedure. If the charge is in a quantum superposition of different spatial locations, then, its field must also be in a quantum superposition of different field values.
state of field at (x0,y0) =
int int PSI(x,y) . {field generated by the electron at (x,y) in the point (x0,y0)} dx dy
where {field generated by the electron at (x,y) in the point (x0,y0)} is the well known Coulomb's expression:
1/(4 PI e0) Q_electron/ (distance between (x,y) and (x0,y0)) ^2.
Best Regards
DaTario
Ok dexter and Vanesch and all together. I will try to calculate it by myself.
The last important question:
How can I find the direction of the A(vector) (picture) if I have found 'Ar'.
(this is of course the nabla operator in spherical coordinates)?
A point (p) in space. r is the point we're integrating over, so the name is taken! p is the point where we calculate the value of the potential...
The thing I wrote down was in fact very simple: you have a (static) charge density in space, rho(X), with rho(X) here given by the |psi|^2, but that doesn't matter. When you have, in electrostatics, a given charge density rho(X) in space, you can calculate the potential from it using the integral I gave, which is nothing else but a solution to the differential equation Dexter wrote down. Of course, for most distributions, you will not be able to write down the solution in a closed analytic form.
cheers,
Patrick.
What is your opinion on this?
I have got an absurd result. I calculated the E-field of a particle with charge -e (electron) with a wave function proportional to this exp[-r]. I solved the differential equation dexter gave me and then calculated out of this the electric field.
The result is: the electric field strength is everywhere E(r)>0. This cannot be because a particle of negative charge should eleiminate the field of a particle with positive charge.
I tested if my solution is correct and of course it is (put it in dexters formula and got the right result).
Can this be true?
cheers,
Patrick.
Hi, another approach than the strict mean field one, would be to start off from the classical particle + maxwell equations. Start off from the one particle schroedinger equation and do polar decomposition. This gives you a hamilton jacobi equation with the quantum potential and a current conservation law. Now, you can postulate that the probability current defines the charge current and this gives you a system of coupled non linear Bohm - Maxwell equations. The advantage of this approach is that you allow the electron to radiate classically, everything is relativistically invariant, and you do not need second quantization.
Cheers,
careful
Thanks you all, I could solve all what I wanted.
Thanks dexter for the Poisson equation and
thanks Vanesch for this integral thing.
hehe Careful. I don't understand anything what you say (you must be on an higher level in physics)
Does somebody of you know where I can find an easy paper or formulas, that describe approcimately the electric field in a hydrogen atom?
nov.10.2005
Hansch(2005 nobel laureate in physics) in his recent experiments measured the magnetic field strength using attosecond laser pulses which have shown to interact with ELECTRONS,producing "OSCILLATIONS".What formulae he used to calculate and deduce the precise field strengths?
Dr.Syed ameen(Ph.D.)
The original poster considered looking for the EM field when the state of the electron was given (standard Coulomb solution for the H-atom I presume). The mean field solution gives you the electrostatic solution if you postulate that the probability density is the charge density.
First I thought that you were suggesting to use the probability CURRENT also as a charge current (eventually inducing a magnetic field that way) ; this could indeed be an idea:
Instead of simply taking the probability density as a static charge density, you could also consider the probability current as an electric current density, and use that as a source in the full Maxwell equations. That's a possibility.
However, you are trying to suggest an alternative way to solve the entire dynamical problem (in the original problem, the wavefunction of the electron was supposed to be given), in the Bohm framework.
What I don't understand, however, is that you can claim that everything is relativistically invariant: the quantum potential in Bohmian mechanics shouldn't be, should it ? (or maybe in the 1-particle version it is? I'm not really an expert on Bohmian stuff).
Relativistically invariant means two things:
(1) you have a coupled system of equations which are invariant under Lorentz transformations and this is obviously satisfied
(2) there is no signalling faster than with the speed of light
As is well known in the Bohm - de Broglie approach, the coupling between the phase and amplitude is not local (but quasi local/ the derivative of the phase is coupled to the derivative of the amplitude in the conservation law for example) which implies you can have trajectories which go faster than with the speed of light (the so called mass problem) - which is one of the textbook motivations to go over to second quantisation. Now, one can try to solve this mass problem by (a) making the Hamilton-Jacobi equation nonlinear (b) averaging position on very small time scales (comparable to observation times) (c) employ Weyl geometric approaches (such as Papini, Wood, Vigier and others) (d) something which I did not consider yet. Note that (a) leads to a violation of the Einstein equivalence principle in some cases (real action principles which contain connection terms). So, if you take into account these options, then you are allowed to speak of a relativistically invariant approach. For multiple particles, you have to go over to a kind of self field approach again (one wave package for each particle).
Cheers,
Careful
1. What is an electric field?
An electric field is a property of space that describes the force experienced by a charged particle. It is represented by a vector quantity and is created by the presence of electric charges.
2. How is an electric field produced by an electron?
An electron has a negative charge, and therefore produces an electric field around it. This field can be thought of as an invisible influence that extends outward from the electron, affecting other charged particles in its vicinity.
3. How is the strength of an electric field measured?
The strength of an electric field is measured by the force experienced by a unit charge placed in the field. This is known as the electric field intensity and is measured in newtons per coulomb (N/C).
4. What is the relationship between an electric field and electric potential?
An electric field and electric potential are closely related. The electric potential at any point is equal to the potential energy per unit charge at that point. The electric field is then the negative gradient of the electric potential, meaning it points in the direction of decreasing potential.
5. How does the electric field produced by an electron affect other charged particles?
The electric field produced by an electron affects other charged particles by exerting a force on them. If the particle has the same charge as the electron, it will experience a repulsive force, while opposite charges will experience an attractive force. The strength of the force is determined by the magnitude of the charges and the distance between them.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
