New Reply
Power 741 op amp with +9 and -5 ?
Share Thread Thread Tools
Jan4-13, 10:46 AM   #1
I have a few power supply's of different voltages, but for convenience a.t.m. can I use +9 and it's -5, it has a ground of course too
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jan4-13, 11:26 AM   #2
Yes, but you will only be able to obtain an output swing based on the lower voltage ie about -4.5 volts. +5 volts will obviously be attainable since it is nowhere near 9.
Jan4-13, 07:54 PM   #3
According to my reading of the LM741 specification,
For power supply voltages of +9 volt, -5 volt and load resistance greater than 10,000 ohm, a typical LM741 will have an output voltage range of +8 volt to -4 volt
Jan5-13, 08:33 PM   #4
Recognitions:
Quote by Carl Pugh View Post
Yes, but for an input signal that is symmetrical about the ground point, the maximum output will depend on the lower of the two supply voltages.
In this case, because the negative supply is only 5 volts, distorted output will result if the negative output is driven beyond about -4 volts, although the positive output may be clean.
New Reply
Thread Tools
Similar Threads for: Power 741 op amp with +9 and -5 ?
Thread Forum Replies
Maximum Power transfer theorem ( Power dissipation in resistors in circuits) General Physics 4
How to design a nuclear power plant reactor power control system ? Nuclear Engineering 25
Vibration shaker: electr. output power of piezodevice exceeds mechanical input power Advanced Physics Homework 0
Explain Why Wind Power Works But Permanent Magnet Power Doesn't General Physics 10
