Finding the angle when given the coefficient of friction
In summary: Cosθ/Sinθ = 0.3And if friction = the coefficient of friction x the reaction force,and the reaction force (R) = Fsinθ then it would beFcosθ = Friction x Fsinθ
NYILoveYou
A mop is being used to clean a floor. The coefficient of friction between the mop and floor is 0.3. Find the angle between the handle and the horizontal when the mop head is moving at constant velocity.
The coefficient of friction = Friction/ Normal Force
Pythagoras Theorem
I figured, the main force would be gravity at 9.8 as mass is negligible. I also tried to get the components of the force. If the downward force was 9.8m/s, the horizontal would be 0.3*9.8 - 2.94 (?). The normal force would also be 9.8, as there is not vertical acceleration or velocity.
I thought could you say perhaps, 2.94/9.8 and the inverse sine of this? It does give the right answer but it feels like the working is incorrect..
Please help, any pointers would be appreciated.
If the mass is negligible, then so is the force of gravity.
Do this: Assume that some force is being applied along the line of the mop handle. Call it F. Call the angle that the mop makes with the floor θ. Now figure out the horizontal and vertical forces on the mop.
Hint: you are missing a major point. there is a force holding the mop. otherwise the mop will fall.
no...the mass is not negligible. if that is so then gravity, normal and friction force would all be negligible. consider all forces and apply the concept of torque..
That is incorrect.
Well the horizontal force would be cos θ = 0.3/F
I'm not too sure on the vertical component as you don't actually have the opposite side?
NYILoveYou said:
so the horizontal component is Fcosθ
the vertical component would be Fsinθ
Good.
i still don't see how that will help, as you don't actually have F or θ
Those aren't the only forces acting on the mop. What about the normal force and friction?
Doc Al said:
Good.
The normal force would be equal to friction, as the mop is moving at constant velocity,
Fr=coefficient of friction x the normal force?
Not exactly. Since, the velocity is constant the net force is zero. That means that the horizontal component of the applied force (F) must equal the friction force.
Right!
Right!
Thanks, so if
Fcosθ = Friction
would it be...
Fcosθ = 0.3 x Fsinθ?
NYILoveYou said:
would it be...
Looks good. Now just solve for θ. (Rearrange a bit and reach for your calculator.)
Well I tried that, but then I got stuck...
The F's cancel out.
Move the sinθ to the other side, so you get
Cosθ/Sinθ = 0.3
then I got stuck, I was thinking perhaps you could use trigonometric proofs?
So far, so good. Can you replace that ratio of trig functions--or its inverse--with a single trig function? Then use your calculator.
THANKS! I finally did it! Thank you so much! :D
What is the coefficient of friction?
The coefficient of friction is a dimensionless quantity that represents the ratio of the force of friction between two surfaces to the normal force pressing the two surfaces together.
How is the coefficient of friction measured?
The coefficient of friction can be measured experimentally by applying different amounts of force to an object and recording the resulting frictional force. It can also be calculated by dividing the frictional force by the normal force.
What factors affect the coefficient of friction?
The coefficient of friction can be influenced by several factors, including the roughness of the surfaces, the type of materials in contact, and the presence of any lubricants. It can also vary with the amount of force applied and the temperature of the surfaces.
How does the coefficient of friction relate to finding angles?
The coefficient of friction is directly related to the angle of a surface, as the angle can affect the amount of friction between two surfaces. By knowing the coefficient of friction and the normal force, the angle of a surface can be determined using trigonometric equations.
What is the significance of finding the angle when given the coefficient of friction?
Finding the angle when given the coefficient of friction is important in various applications, such as engineering and physics, as it allows for the calculation of forces and the design of structures. It also helps in understanding the behavior and limitations of objects in contact with each other.
