Register to reply
Ax+b=0 is one-variable linear equation
Share this thread:
WannabeFeynman
#1
Mar13-14, 01:17 PM
P: 55
Hello
Am I right in saying:
ax+b=0 is one-variable linear equation
ax+by+c=0 is two-variable linear equation
ax^2+bx+c=0 is one-variable quadratic equation
ax^2+bx+c=y is two-variable quadratic equation
Every linear or quadratic equation in one or two variables can be represented in those ways.
How come graph of ax+by+c=0 is point of solution set {(x,y) | ax+by+c=0}? Why not (y,x)? Since we can rearrange it as x=(y=b)/m, can we pick the y value first and then find the x value?
I know graph of x=a and y=a is vertical and horizontal lines respectively because x or y will always be constant no matter what y or x is respectively. But how would we represent the solution sets? For x=a, would it be {(x,y) | x+0y=a}?
Thanks.
Phys.Org News Partner Mathematics news on Phys.org
Researcher figures out how sharks manage to act like math geniuses
Math journal puts Rauzy fractcal image on the cover
Heat distributions help researchers to understand curved space
micromass
#2
Mar13-14, 01:23 PM
Mentor
micromass's Avatar
P: 18,345
Quote Quote by WannabeFeynman View Post
Hello
Sure.
I would say the general two-variable quadratic equation has the form
[tex]ax^2 + by^2 + cxy + dx + ey + f = 0[/tex]
It doesn't matter much. You might as well choose
[tex]\{(y,x)~\vert~ax+ by + c = 0\}[/tex]
It might not be the same set, but it will be an equivalent situation you're dealing with. Geometrically, this corresponds to just swapping X-axis and Y-axis.
Usually, we will of course use
[tex]\{(x,y)~\vert~ax + by + c = 0\}[/tex]
but that's a convention.
Yes, that will be one possible way of writing the solution set. Another one is
[tex]\{(x,y)\in \mathbb{R}^2~\vert~ x =a\}[/tex]
or
[tex]\{(a,y)\in \mathbb{R}^2~\vert~y\in \mathbb{R}^2\}[/tex]
WannabeFeynman
#3
Mar13-14, 07:13 PM
P: 55
Thanks a lot. That cleared my doubts.
WannabeFeynman
#4
Mar14-14, 09:05 AM
P: 55
graph of f(x) is graph of solution set {(x,f(x)) | f(x)=x+a}
Can I right it as x=f(x)-a too?
micromass
#5
Mar14-14, 09:37 AM
Mentor
micromass's Avatar
P: 18,345
I would say the graph of a function ##f:\mathbb{R}\rightarrow\mathbb{R}## is
[tex]\{(x,f(x))\in \mathbb{R}^2~\vert~x\in \mathbb{R}\}[/tex]
or perhaps
[tex]\{(x,y)\in \mathbb{R}^2~\vert~y=f(x)\}[/tex]
In the case that ##f(x) = x+a## for all ##x##, then this becomes
[tex]\{(x,x+a)\in \mathbb{R}^2~\vert~x\in \mathbb{R}\}[/tex]
or
[tex]\{(x,y)\in \mathbb{R}^2~\vert~y=x+a\}[/tex]
and you can write this of course as
[tex]\{(x,y)\in \mathbb{R}^2~\vert~x=y-a\}[/tex]
WannabeFeynman
#6
Mar14-14, 09:49 AM
P: 55
So
[tex] {(x,f(x)) | f(x)=x+a} [/tex]
is wrong then?
Can't get { and } to show...
micromass
#7
Mar14-14, 09:51 AM
Mentor
micromass's Avatar
P: 18,345
So
is wrong then?
If your ##f## is defined by ##f(x) = x+a##, then that just says
[tex]\{(x,f(x))~\vert~x+a=x+a\}[/tex]
which simplifies to
[tex]\{(x,f(x))~\vert~0=0\}[/tex]
So yes, it's not really right.
WannabeFeynman
#8
Mar14-14, 09:53 AM
P: 55
The how come
[tex] (x,y) | y=x+a [\tex]
is correct?
WannabeFeynman
#9
Mar14-14, 09:53 AM
P: 55
Then how come
[tex] (x,y) | y=x+a [/tex]
is correct?
Register to reply
Related Discussions
Graphs of Fractional Functions Precalculus Mathematics Homework 6
Graphs of Functions problem Precalculus Mathematics Homework 6
Functions & Graphs ( help ! ) Precalculus Mathematics Homework 7
Help!How functions are driven from graphs? General Math 4
Graphs of functions of several variables Calculus & Beyond Homework 12
