Find Steel Tubing Size for 4000lb Log Ramp - 8' Long
In summary, steel tubing is needed for the ramps to be 8' long and at the following angles; never less than 25 degrees never more than 38 degrees. 1.5 x .125 tubing is available locally, but that does not seem to be big enough.
MB3
I am making a ramps to load logs onto a portable sawmill. I would like to know the size steel tubing I need for logs weighing 4000 lbs. the ramps would be 8' long and at the following angles; never less than 25 degrees never more than 38 degrees. 1.5 x .125 tubing is available locally, but that does not seem to be big enough. Any help is appreciated.
length?
Mass of logs, length of travel, wall thickness of the rod, and angle are all important. Can you not use another profile - for example - "I" beam? The amount of work done is proportional to the distance the log is raised.
I was a sawyer for several years back in the 1960's. Never saw steel tubing like you describe used as part of end-dogging. We milled 20' bucked Quercus rubra logs, 36+" diameter - imported. We milled largely quartersawn 15/4 - air dried and planed to 12/4. We made church pews and furniture.
So I can tell what you are doing:
Will the logs roll up the incline, or are they to be dragged along the length? Unless things have changed radically, you are going to need lots of those (my current opinion) somewhat puny rods. If you are not milling log run, you have to reposition logs during the milling process and re-dog them in place. Log run also requires repositioning for some kinds of mills. So how does the mill hold the log during cutting?
Once you run logs through the mill you have the problem of getting them off there out of harms way, and then stickered (ventilated stacks), which means lifting as well.
So.
1. what exact rod stock are you planning on using?
2. How long do you need the rods to be?
3. Is this a one-man operation? If required, one man cannot usually reposition heavy logs easily and safely. Even with a pinch bar.
Do you have welding equipment or must it be a standard section?
It is the section of the ramp that makes the difference, it needs to be deeper near the middle like a truss.
Why use steel tube when you could use timber?
I run a portable 6" Lucas Mill. Out of interest, what type of mill do you have?
1. What is the weight capacity of the log ramp?
The weight capacity of the log ramp is 4000lbs.
2. How long is the log ramp?
The log ramp is 8 feet long.
3. What is the recommended size of steel tubing for the log ramp?
The recommended size of steel tubing for the log ramp would depend on the specific design and construction of the ramp. It is best to consult with a structural engineer for the appropriate size based on the intended use and weight capacity.
4. Can the log ramp be used for vehicles?
The log ramp is specifically designed for carrying logs and may not be suitable for use with vehicles. It is important to adhere to the recommended weight capacity and usage guidelines for safety purposes.
5. Is the log ramp easy to assemble and disassemble?
The log ramp is designed for easy assembly and disassembly, making it convenient for transportation and storage. However, proper safety precautions should be taken during assembly and use to prevent accidents or injury.
  • General Engineering
17K
10K
9K
  • Mechanical Engineering
10K
