Blackbody radiation and the Ultraviolet Catastrophe
In summary, Rayleigh attempted to calculate the black body spectrum. The result he got was only partially successful. It worked for low frequencies and failed at high frequencies. He was well aware of this. He never pretended it was correct.
Jimmy87
686
Hi, please could someone help me as I am struggling to understand the classical blackbody theory. I will briefly summarize what my textbook says. It says that if the classical model was correct then a tennis ball should be emitting radiation in mainly the ultraviolet region. The idea at the time was that atoms in the blackbody were thought of as oscillators which could vibrate at any frequency. The higher frequency oscillations would have more modes thus more ways of storing energy and therefore one would expect to find most of the energy in the ultraviolet range for any object above absolute zero as this is where most of the modes are. What I am struggling to understand is how this classical theory applies to low temperature objects such as a tennis ball. Even if the atoms of a tennis ball do indeed have more modes for the higher frequency oscillators where would it get the energy from to fill these modes when its only at room temperature!? I can see the logic (even though its wrong) that increasing the temperature/intensity would increase the radiation emitted all the way up to infinity but how does this classical theory also mean that things at room temperate for example, should also emit in mainly the ultraviolet region? Any help would be greatly appreciated!
Well sure, that's exactly the problem with the classical theory, isn't it?
Wikipedia said:
Thus, both the power at a given frequency and the total radiated power is unlimited as higher and higher frequencies are considered: this is clearly unphysical as the total radiated power of a cavity is not observed to be infinite,
Yes, but I'm saying that if we pretend the classical view was correct (and quantum mechanics didn't exist) where would a tennis ball get the energy from to radiate in the UV range as this is what the theory apparently predicted (Lord Rayleigh predicted this) but I don't see how. So even though its wrong I don't understand how Rayleigh predicted objects with room temperature should emit mostly in the UV range.
Likes 1 person
The Rayleigh calculation seems to give good result for intensity of low frequency component of the radiation. The energy corresponding to this radiation comes from the other objects used to heat the tennis ball up to its temperature.
If we attempt to extend the validity of the Rayleigh calculation to higher frequencies, mathematically we can, and the energy would again come from the surrounding objects. But what Bill is saying is right, for high frequencies the assumptions of the calculation are implausible and the result experimentally fails.
Likes 1 person
Thanks for all your answers guys, that has helped
1. What is blackbody radiation?
Blackbody radiation refers to the electromagnetic radiation emitted by an object at a certain temperature. This radiation spans a wide range of wavelengths and is dependent on the temperature of the object.
2. What is the Ultraviolet Catastrophe?
The Ultraviolet Catastrophe is a term used to describe the failure of classical physics to accurately predict the intensity of blackbody radiation at shorter wavelengths, specifically in the ultraviolet region. According to classical physics, the intensity of radiation should increase infinitely as the wavelength decreases, leading to a catastrophic result.
3. How did the Ultraviolet Catastrophe lead to the development of quantum mechanics?
The failure of classical physics to explain the intensity of blackbody radiation at shorter wavelengths led to the development of quantum mechanics. Max Planck proposed that energy is quantized and can only be emitted or absorbed in discrete packets, known as quanta. This theory successfully explained the intensity of blackbody radiation, leading to the development of quantum mechanics.
4. How does the wavelength of blackbody radiation change with temperature?
As the temperature of an object increases, the peak wavelength of its blackbody radiation shifts towards shorter wavelengths. This is known as Wien's displacement law and is described by the equation λmax = b/T, where λmax is the peak wavelength, T is the temperature, and b is a constant.
5. What practical applications does blackbody radiation have?
Blackbody radiation has many practical applications, including infrared and thermal imaging, medical thermography, and the development of thermometers and other temperature measurement devices. It is also used in astronomy to study the temperature and composition of stars and other celestial objects.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
