Register to reply
Effects of gravity on different elements
by JesseTH
Tags: effects, elements, gravity
Share this thread:
JesseTH
#1
Feb6-14, 12:41 AM
P: 2
Hi,
Hopefully this is the right place for this question.
I'm wondering whether a 100lb ball of lead would roll down a ramp (assuming a 35 degree slope) at the same speed as 100lb ball of copper.
Would there be a difference in force while they are rolling down?
Thanks,
Phys.Org News Partner Physics news on Phys.org
Optimum inertial self-propulsion design for snowman-like nanorobot
The Quantum Cheshire Cat: Can neutrons be located at a different place than their own spin?
A transistor-like amplifier for single photons
CWatters
#2
Feb6-14, 12:57 AM
P: 3,107
Might be interesting to watch...
http://www.youtube.com/watch?v=5C5_dOEyAfk
http://www.youtube.com/watch?v=7eTw35ZD1Ig
JesseTH
#3
Feb6-14, 01:36 AM
P: 2
Thanks CWatters..
I do understand that with no 'interference' the two would fall at the same speed.
But would the larger contact area of the copper ball on the ramp surface be enough to affect results (here on earth)?
HallsofIvy
#4
Feb6-14, 09:01 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,348
This kind of experiment has been done many times in many different ways, going back to Galileo. The "effect of gravity" (acceleration due to gravity) depends only on the mass of the object, not the material it is made of.
CWatters
#5
Feb6-14, 10:05 AM
P: 3,107
Quote Quote by JesseTH View Post
Thanks CWatters..
Any difference could potentially change the results but it might be a small. If the balls are different sizes (which they would be as they have different densities) then rolling resistance or air drag might be different and that would change the results.
If you eliminate every possible difference (same mass, size and rolling resistance and EDIT: Moment of inertia) so that they are the same except for the element that are made from then no, they would both roll down at the same speed.
How small a difference counts as different? Both lead and copper are electrical conductors and they have different conductivities. On earth they would be moving through the earths magnetic field and that might affect the results - but it would be an exceptionally small effect that is hard to detect.
Register to reply
Related Discussions
Gravity's effects Special & General Relativity 52
The Effects of Gravity Beyond the Standard Model 2
Gravity Effects General Physics 1
Effects of Gravity on pi Astronomy & Astrophysics 11
Gravity and the effects of. General Physics 11
