General solution of a linear ordinary differential equation
In summary, the solution to a linear ordinary differential equation can be found by solving for its "fundamental" solutions at the x-axis value of x0.
hanson
319
Hi all.
Can the general solution of a linear ordinary differential equation be expressed in terms of its initial conditions?
It seems that I have seem this kind of representation.
It makes "some sense" to me but I hope to know if there is some "proof" or explanation of why it can be?
To be specific, for a n-th order ODE,
the solution is something like
y = y(xo)(something) + y'(xo)(something) + ... + y(n-1)(xo)(something)...
why?
Hallo. The equation you mention here looks only like a Taylor- Mac Laurin development of the y(x0 + epsilon) function arond y(x0). Your something should be a factor (1/N!). epsilon ^N with N = 0, 1, ... Why it is so ? Well a good question but I need help too. Certainly the explanation is related to the methods of the infinitesimal calculus. The fact is that such a development demonstrates the relationship between the function in or at x0 plus epsilon and the function in or at xo. So yes conditions somewhere else have an influence on what hapens here.
Given any linear, nth (homogeneous) ordinary differential equation, you can define its "fundamental" solutions (at x= x0) as the solutions satisfiying
1) Y1(x0)= 1, Y1'(x0= 0, Y1"(x0)= 0, ...
2)Y2(x0)= 0, Y2'(x0)= 1, Y2"(x0)= 0, ...
n)Yn(x0)= 0, Yn'(x0)= 0, Yn"(x0= 0, ..., Yn(n)(x0)= 1.
Any solution to the differential equation can be written as a linear combination of those: Y(x)= C1Y1(x)+ C1Y2(x)+ ...+ CnYn(x).
If you set x= x0 in that equation you get C1= Y(x0).
If you differentiate both sides of the equation to get Y'(x)= C1Y1'(x)+ C2Y2'(x)+ ... and set = x0, you get C2=Y'(x0). Continuing in that way, you see that the coefficients are precisely the "initial values" for Y.
i have problem understanding the following..
"define its "fundamental" solutions (at x= x0) as the solutions satisfiying
n)Yn(x0)= 0, Yn'(x0)= 0, Yn"(x0= 0, ..., Yn(n)(x0)= 1."
why is this so...?
What is a linear ordinary differential equation?
A linear ordinary differential equation is a mathematical equation that relates an unknown function to its derivatives. It is called "linear" because the unknown function and its derivatives appear only in the first power and not multiplied together or raised to a power.
What is a general solution of a linear ordinary differential equation?
A general solution of a linear ordinary differential equation is an expression that includes all possible solutions to the equation. It contains an arbitrary constant that can take on any value, allowing for an infinite number of solutions.
How is a general solution of a linear ordinary differential equation different from a particular solution?
A particular solution is a specific solution to a differential equation that satisfies any initial conditions given. It is derived from the general solution by substituting specific values for the arbitrary constant. The general solution, on the other hand, includes all possible solutions, including the particular solution.
How do you solve a linear ordinary differential equation to find its general solution?
To solve a linear ordinary differential equation, you must first determine its order (the highest derivative present) and its linearity. Then, you can use various methods such as separation of variables, integrating factors, or series solutions to find the general solution. The solution can also be verified by checking that it satisfies the original equation.
Why is the general solution of a linear ordinary differential equation important?
The general solution of a linear ordinary differential equation is important because it gives a complete understanding of all possible solutions to the equation. It can be used to find particular solutions for specific initial conditions, and it can also be used in applications to model real-world phenomena. It is a fundamental concept in differential equations and has many practical applications in science and engineering.
  • Differential Equations
