- #36
Fredrik
Staff Emeritus
- 422
Of course. But you're still nowhere near the very obvious and very trivial truth about what set [tex]\{z\in\mathbb C|0=0\}[/tex] is.Susanne217 said:Off cause since it contains the zero element then the set isn't empty, sorry about that
I hope you can forgive me :)
I think you should focus on the two problems I've been trying to get you to solve first. Both of them are about as easy as a math problem can get. As long as you haven't understood them, I don't think you can understand any problems of this sort, including the question of whether it's possible for a generalized circle to be the empty set.Susanne217 said:But how in anyones name a the function can be claimed to be the empty set that I have totally no idear on how it can be shown.
A "domain" is a set on which a function is defined. You probably mean the set of solutions of the equation. If that's empty, then the generalized circle is the empty set. Is that possible? I actually haven't thought that through, so at this precise moment, I can't tell you the answer. We can return to that when you have solved the two trivial problems.Susanne217 said:Only way that the eqn of generalized circle to represent the empty set is for the domain of eqn to be empty, and as understand your thoughts Fredrik then the domain of generalized circle can never be empty. Thus it can't be show to represent the empty set?
Edit: I have to add that I think you should try to re-evaluate your whole approach to solving math problems. It seems to me that most of the time, you try to guess the solution without actually using the information in the problem you have been given. Math doesn't work that way. I don't think anything does, but there's no other field where it's as important to use the information you've been given as in mathematics.
