Is the experiment to find water on mars by NASA is most idiotic one
In summary, the conversation was about the possibility of finding water on Mars through NASA's exploration. While some argued that any water found could be from the spacecraft's fuel, others pointed out that the amount of water in Mars' atmosphere is much greater than what could have been introduced by the spacecraft. The general consensus was that Mars is an ideal place to search for evidence of exobiology and that the experiments conducted are not foolish but rather valuable in understanding the planet's history.
sr241
83
Is the experiment to find water on Mars by NASA is most idiotic experiment ever conducted by mankind.
I mean, spacecraft send to Mars use hydrocarbons or hydrogen as fuel; this fuels byproduct is water. So there is a greater chance that after some exploration if NASA find traces of water on Mars that could be from the spacecraft itself( as the byproduct of fuel combustion is water)
They aren't looking for water on Mars. They are looking for evidence that large amounts of liquid water existed in the past. Lots of water already exists as ice in the ice caps. In addition trace amounts of water vapor exist in the atmosphere.
See here: http://en.wikipedia.org/wiki/Water_on_Mars
Most of the recent landers didn't use engines to land anyway and even for those that did, the water vapor would never have condensed.
[Edit] And rocket scientists aren't that stupid.
Mars is an exciting laboratory to explore. It is similar to earth, has a wide variety of terrain and geology, and widely believed to have held large amounts of water for the first billion years or so of its existence. Thus, it is an ideal place to search for evidence of exobiology - at least in the fossil record. This would obviously be a find of enormous significance. It would be disappointing to come up empty, but, entirely worth the expense. At very least we will learn how not to look for life. I am, however, still optimistic it will produce results.
I mean that traces of water in atmosphere may be from rocket's fuel burned
Every Hydrocarbon , hydrogen, H2O2, even ammonia as fuel produces water vapor as exhaust
You might try calculating an upper bound on the amount of water introduced into the Martian atmosphere in this way. If measurements indicate much more water than that, then we can conclude that there was water there before the probe arrived; if not the results are inconclusive. That's the way it is with almost all scientific experiments: The press reports "Scientists have found that there is no <something>", but when you read the actual paper, you find that the scientists are making the more precise claim "Our experiment doesn't prove that there is no <something>, but it show that if <something> does exist, there's no more than <some small number> of it".
I expect that if you do the calculation you'll find that even if the upper bound is high by several decimal orders of magnitude, we're dealing with a reasonably well-designed experiment.
Nonsense.
Do the math. Let's just look at Mars' atmosphere. The mass of the Martian atmosphere is around 2.5×1016 kg. Most the atmosphere is CO2, but a small trace (210 ppm) is water. Mars' atmosphere alone contains about 5.2×1012 kg of water. Compare that to a fully loaded Saturn V rocket at takeoff, about 2.9×106 kg. The water in Mars' atmosphere is the same mass as 1.7 million Saturn V rockets at takeoff.
Missions to Mars don't use Saturn V rockets. They use smaller ones. Almost all of any rocket's mass is consumed during launch. For missions to Mars, a tiny bit was used to send the vehicle on the way to Mars. An even tinier bit was used to put vehicles into orbit about Mars. None of these tiny bits contributed to Mars' atmosphere. The only part that did was the extremely tiny bit used to get vehicles from Mars entry to the surface, and that was only done on a handful of missions or so.
We would have needed to have sent billions of missions to Mars for those Mars missions to explain the amount of water in Mars' atmosphere. We didn't do that.
Thread closed for moderation.
1. Is NASA really trying to find water on Mars?
Yes, NASA has conducted multiple experiments and missions to search for evidence of water on Mars. This is because water is essential for life, and the presence of water on Mars could indicate the potential for past or present life on the planet.
2. Why is the experiment to find water on Mars considered idiotic?
The experiment itself is not considered idiotic, but some critics may argue that it is a waste of resources and time. Others may argue that there are more pressing issues to address on Earth rather than searching for water on another planet.
3. What methods does NASA use to search for water on Mars?
NASA uses various methods, such as orbiting satellites, landers, and rovers, to search for water on Mars. These methods include analyzing the chemical composition of the Martian soil and atmosphere, searching for signs of ancient rivers or lakes, and detecting water vapor in the atmosphere.
4. Has NASA found any evidence of water on Mars?
Yes, NASA has found multiple pieces of evidence that suggest the presence of water on Mars. This includes the discovery of hydrated minerals, evidence of ancient lakes and rivers, and the confirmation of water ice at the poles of the planet.
5. What is the significance of finding water on Mars?
Finding water on Mars is significant because it could provide valuable insights into the past and potential habitability of the planet. It could also open up possibilities for future human exploration and colonization of Mars. Additionally, studying the water on Mars could improve our understanding of the evolution of the solar system and the potential for life on other planets.
  • Aerospace Engineering
11K
  • Astronomy and Astrophysics
  • Mechanical Engineering
  • Science Fiction and Fantasy Media
9K
