New Reply
Sound diffraction
Share Thread Thread Tools
Dec5-12, 01:53 AM   #1
Sound diffraction
Hi, my friends. Today, I come up with a question suddenly. It is about Sound diffraction.
why can we hear someone's voice even when he is in a closed office. Many books says that it is because of Sound diffraction. But I can't understand. how does it happen? would you be so kind to explain it in detail? Thank you!!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec5-12, 04:08 AM   #2
Recognitions:
Gold Membership Gold Member
Diffraction of sound: the bending of waves around small* obstacles and the spreading out of waves beyond small* openings.
http://hyperphysics.phy-astr.gsu.edu...d/diffrac.html
Also see the images: https://www.google.com/search?q=soun...w=1350&bih=647
Cheers,
Bobbywhy
Dec5-12, 06:37 AM   #3
But the office is closed!
Don't forget that sound can travel through the thickness of doors, and even through some sorts of wall. The sound is attenuated (weakened) but here something else comes into play...
The ear's sensitivity is 'logarithmic'. This implies that it is disproportionately sensitive to very weak sounds. So although the sound intensity might fall by a factor of 1000 as the sound passes through the material of the door, it may still be audible.
Dec5-12, 06:40 AM   #4
Sound diffraction
Quote by Philip Wood View Post
why sound can travel through the thickness of doors? please explain it ! Thank you very much!!!
Dec5-12, 08:30 AM   #5
or you confused sound with light,which can not go after a wall.Sound can,right!
Dec5-12, 08:40 AM   #6
Recognitions:
Quote by einstein1921 View Post
Sound is a mechanical vibration in a medium. It can be transfered to another medium. So ... inside air to wall to outside air. It gets attenuated each time, which is why you don't hear the sound as clearly outside the office as you do inside the office.
EDIT: it can also be reflected off of objects (mostly hard, smooth ones), thus can "go around corners"
Dec5-12, 08:54 AM   #7
Sound travels through solids and liquids as well as gases such as air. In a liquid or solid, the vibrations which make up the sound are passed from one particle to another via the forces which hold the particles together. In many materials (such as steel) the wave energy propagates very efficiently in this way. In softer materials, or materials containing large particles or fibres, much of the energy is scattered or dissipated (making the material slightly hotter), so the sound propagation is inefficient. That's just what you want in the material of a wall or door.
Dec5-12, 02:36 PM   #8
As an extension to what phinds said...
The sound is the vibration of the air. The vibrating air is in contact with the wall, and transfers some of that energy to the wall. Now the wall is vibrating. The vibrating wall transfers some energy to the air inside the office. Now the air inside the office is vibrating, allowing you to hear the noise, even if the office is sealed. If the door is very thin, you hear more through it, because it's easier for the air to vibrate the door. If you make the door very heavy and stiff, it's harder to get the door to vibrate, so less energy is transfered through it. If you make the door infinitely stiff and heavy, then no sound energy passes through it.
New Reply
Thread Tools
Similar Threads for: Sound diffraction
Thread Forum Replies
diffraction of sound General Physics 5
Diffraction: how to know the amount of slits from a diffraction pattern? Introductory Physics Homework 0
Simple single-slit sound diffraction Introductory Physics Homework 4
diffraction grating problem, missing orders, diffraction minimum and maximums. Introductory Physics Homework 1
Diffraction of sound waves Advanced Physics Homework 1
