New Reply
Carnot Efficiency of a heat engine
Share Thread Thread Tools
Nov8-12, 11:10 PM   #1
My problem only gives me joules to work with. Is it possible to convert from joules of energy to temperature (Kelvin)?? If so how?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov9-12, 01:15 AM   #2
Best to state the problem. Maybe we can see a way around it.
Nov9-12, 01:29 AM   #3
An engine transfers 2.00x10^3 Joules of energy from a hot reservoir during a cycle and transfers 1.50x10^3 Joules as exhaust to a cold reservoir. Find the actual efficiency of the engine and then compare it to the carnot efficiency.
The actual efficiency is 75% I calculated. For carnot efficiency i need temperature, but I dont know how to get it.
Nov9-12, 01:45 AM   #4
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Your calculation of the efficiency is wrong. Also, if you don't have the temperature of the reservoirs, you can't get the Carnot efficiency.
Nov9-12, 03:31 AM   #5
The actual efficiency of the engine
[itex]\epsilon=\frac{work \; done \; by \; the \; engine}{total \; energy \; used \; by \; it}[/itex]
Nov9-12, 03:43 AM   #6
My book says (efficiency=energy output/energy input)
Which would give me 75% I believe.
So there is no way to get the carnot efficiency?
Nov9-12, 03:57 AM   #7
The engine extracts energy between the input and output reservoirs of the engine, this it converts into work. Look in the section on the 2nd law of Thermodynamics how to convert the transferred heat to temperatures.
Nov9-12, 04:05 AM   #8
The 75% is the Carnot engine's efficiency.
Nov9-12, 04:16 AM   #9
Hmmm interesting. My book does not go in to depth very much, because im in a survey class, so I dont understand how you could calculate it without having your temperatrure. The only equation I got in my book for carnot efficiency is
carnot efficiency=(Thot-Tcold)/ Thot
Nov9-12, 04:24 AM   #10
For a Carnot engine it is assumed that all of the extracted heat, QH - QL (high, low), is converted into work by the engine, so that its efficiency is given by
[itex]\epsilon=\frac{Q_{H}-Q_{L}}{Q_{H}}[/itex]
Nov9-12, 05:34 AM   #11
Recognitions:
Quote by Basic_Physics View Post
W = Qh-Ql for any heat engine. So this is the definition of efficiency for any heat engine. To calculate the Carnot efficiency, the maximum efficiency of any possible heat engine operating between these two reservoirs, you would need to know the temperatures, Th and Tc.
AM
Nov9-12, 05:57 AM   #12
Recognitions:
Quote by AlaskanPow View Post
The heat exhausted to the cold reservoir is not the energy output of the heat engine.
New Reply
Thread Tools
Similar Threads for: Carnot Efficiency of a heat engine
Thread Forum Replies
Carnot Engine Efficiency Classical Physics 2
Heat Engine Carnot Efficiency question Introductory Physics Homework 5
Carnot engine efficiency * Carnot refrigerator efficiency Classical Physics 2
Carnot engine efficiency Advanced Physics Homework 2
Carnot Engine Efficiency Introductory Physics Homework 2
