What is the instantaneous value of UL after commutation?
  • Thread starter builder_user
  • Tags
    Physics
In summary: Before commutationYou should be able to use what you know about the properties of inductors in DC circuits to determine the steady state conditions that will hold before switching and a "long time" after. Have you done that?Yes, I've determined the steady state conditions before and after the switch is thrown and found that UL always exists in the circuit.
  • #36
gneill said:
Do the same work for the case after the switch is closed. Note that all the switch does is put R1 in parallel with R2. What numbers do you get for the Norton equivalent in this case?
But when switch is closed there is the inductive element.It resistance add too?
This circuit after commutation?
  • #37
builder_user said:
But when switch is closed there is the inductive element.His resistance add too?
We're treating the inductor as the load being driven by a Norton equivalent of the source network. It plays no part in finding the equivalent circuit for the source network.
So no, there is no inductor added to the source network by the switch. It only adds R1 in parallel with R2 to the circuit we just analyzed. We will deal with the inductor after we have the equivalent circuits for the sources.
What we want to end up with is two Norton equivalent circuits, one for each state of the switch. These two equivalent circuits replace the current source and resistor networks of the original circuit. These equivalent circuits will be "driving" the inductor. They will make it easy to analyze what happens when the switch is closed.
  • #38
After replacing there will be diff. equatations?
So this scheme?
and
R=R1*R2/(R1+R2)
U=J*R
  • #39
I'll show you how to analyze the circuit without differential equations to begin with. That way you'll know what result you're looking for! :smile:
Yes, the figure you provided is the circuit of the source network after commutation of the switch. You want to find its Norton equivalent, just like you did for when the switch was open. What's its Norton resistance and current?
  • #40
But I must find U as time function...like this
U=900/375*e^375t+C
The problem is...I must use differential equatations.But they only need at the moment of commutation.With Laplace and without it(especially for LC).It's the task.
  • #41
Strange but currents are the same.
  • #42
U=900/375*e^375t+C
The equivalent circuits will allow you to write the differential equations very easily. In fact, you will probably already have done so for circuits in this basic form!
I will show you how to write the desired U(t) function by inspection, so that you can check your differential equation result. Will that work for you?
  • #43
I think you may have forgotten about R3 and R4...
  • #44
I found U.
U/R3=J3
U/R4=J4?
  • #45
I need equations like this
from example
UL=Ldi/dt
i2+i3=i1
i1*R1+i2*R3=E
-i2*R3+i3*R4+Ldi3/Dt=0
-E-i3*R1/(R1+R3)*R3+i3*R4+Ldi3/dt=0
i3=2.4+c*e^-375t
i(0)=1.7(before commut.)
2.4+c*e^0=1.7
c=-0.7
i3(t)=2.4-0.7*e^-375t
  • #46
builder_user said:
I found U.
U/R3=J3
U/R4=J4?
What are J3 and J4? :confused:
If you are looking at the Thevenin equivalent of your circuit, there is no current through R3 or R4. The Thevenin voltage is produced by the current flowing through the parallel combination of R1 and R2. The Thevenin resistance is the sum of R3 and R4 and the parallel combination of R1 and R2.
The Norton resistance, RN, is the same as the Thevenin resistance. The Norton current is VTH/RTH.
  • #47
I see.Operator method it seems to similar
find i before and after commutation
replace inductor with operator resistor
p=j*w - operator.
  • #48
from example
UL=Ldi/dt
i2+i3=i1
i1*R1+i2*R3=E
i3=2.4+c*e^-375t
2.4+c*e^0=1.7
c=-0.7
The equations will be easy to write from the equivalent circuits. You will have only to deal with one current source, one resistor, and one inductor. Your textbook probably has this form as an example!
  • #49
so, for L i'll just need to use U=Ldi/dt?
  • #50
builder_user said:
I see.
p=j*w - operator.
Yes. Certainly.
What I've been trying to do is reduce the before and after commutation circuits to their very simplest forms so that it will be very easy to apply any method of circuit analysis you wish to use. They will be so basic that your textbook should already provide a solved example.
  • #51
Ok.So I just need to make system of equatations and only to solve it?
  • #52
Essentially, yes. The transition that occurs when the switch is closed will be the same as applying a step change in the source current. Or if you wish, it will be equivalent to applying a voltage source to an RL circuit.
  • #53
If that is your goal, sure. And it will be one differential equation; The one for a parallel RL circuit driven by a current source.
  • #54
Perhaps I should summarize the work done so far. The equivalent circuits for before the switch is closed and after the switch is closed are as in the attached image. These are simple circuits!
To analyze the instant of switch closure, you can produce a "differential" circuit that reflects the change between the two. The difference is the sudden change in current and change in parallel resistance. Since you are looking for the voltage across the inductor after the switch closes, the circuit to write the equation for will consist of a current supply with a value equal to the change in current, the parallel resistance of the "after switch closed" circuit, and the inductor.
  • #55
Final part.At the moment of commutation scheme(pic.)
It has only one equatation?
(Req+R3+R4)*i+Ldi/dt=J*Req
and I must find i??
How to do it in Mathcad?
  • #56
I've found i(t)=1.43+1.06*e^-1567t
To find U i only need to
U=i(t)'*L?
U(t)=-19.93*e^(-1567t)
Is it correct?About Laplace.
In what state I need to replace inductor with pL.before commutation and after commutation I do not have inductor.Does it mean that I only need to replace inductor at the moment of commutation?
  • #57
After operator method results are different
i(t)=1.43+1.06*e^-1567t vs i(t)=1.43-0.0000915*e^-1563t
  • #58
U=i(t)'*L?
Is it correct?
About Laplace.
Hi builder-user, sorry to be away so long...
Your equations look fine except the time constant parameter seems to be missing a decimal place; I see R/L as 1.567 given your component values.
My own method when I solve these sorts of problems where there's a sudden transition involved (like the switch being closed), is to find the equivalent circuits for before and after steady state conditions, then produce a "difference" circuit to analyze. The difference circuit incorporates the final steady state circuit components, and where the source is the change in source between the old and new states. So in this case, looking at the Norton equivalents, the "old" current source was 2.49, the "new" source was 1.43, so the change in source is -1.06. See the attached figure. I then analyze this circuit assuming no prior state ("power-on" is at t=0).
The results of this analysis will be the changes that will occur in the original circuit after the switch closes. It will give the voltage across the inductor, and the change in current through the inductor. So if the pre-switching steady state current through the inductor was I0, and the analysis provided current I1(t), then we have I(t) = I0 + I1(t) for when the switch is closed.
This method may or may not suit you.
To incorporate the initial inductor current into the Laplace transform method, it appears as an initial condition for the current -- the io term in L*(s*I - io).
So if you have the Thevenin equivalent of the circuit at time t = 0 (when the switch has just been closed), with voltage source V and series resistance R and series inductor L, the equation you write for the Laplace transform of the current looks like:
V/s = I*R + L*(s*I - i0)
Solve for I, take the inverse Laplace transform, and you're done (for the current, at least).
  • #59
You mean 1.43+1.06*e^-1.567t?
At time t=0 I need to add inductor to all resistance?And where is the potensial difference?
  • #60
Yes. I'm taking the component values as:
R1 = 5.6
R2 = 5.6
R3 = 4
R4 = 12
L = 12
Those are what I get after applying your 'K' constants.
These yield a Thevenin resistance of 18.8 when the switch is closed. So the time constant for the circuit should be τ = 12/18.8 = 0.6383, and 1/τ is 1.567
I not sure that I understand what you're asking. If you're referring to the Laplace transform equation, then I started with the Thevenin equivalent circuit and wrote KVL around the loop. The V is the Thevenin source voltage. i0 is the initial current flowing in the inductor at t=0 when the switch is closed.
V = i*R + L*di/dt
Laplace transform:
V/s = R*I + L*(s*I - i0)
I = (V + L*i0*s)/(L*s2 + s*R)
inverse Laplace transform:
i(t) = (i0 - V/R)e(-R*t/L) + V/R
  • #61
gneill said:
l = 12
l=0.012
  • #62
builder_user said:
l=0.012
If you say so. In your first post you had:
K1=1.2
L = 10*K1
You did not indicate units (for anything!) so I assumed Ohms for resistances and Henries for inductance.
  • #63
This loop?
  • #64
I forgot.In every task I have millihenries and so I've not written it there.
  • #65
builder_user said:
This loop?
No, this loop. All of the source and resistor network is replaced by its Thevenin equivalent. Makes life simple.
  • #66
Okay. Perhaps in future you should just state the component values. All the K multipliers and assumed units is confusing.
  • #67
Thevenin equivalent after commutation?Or at the moment of commutation?One of the equivalents that was found before?Or not found in this topic?
  • #68
After the switch closes, so yes, after commutation.
The circuit at the moment the switch closes remains the same thereafter.
It's only the initial conditions (the existing current in the inductor) that makes the moment of commutation special.
  • #69
How to do inverse Laplace transform in MathCAD?
  • #70
Select the 's' variable and then Symbolics --> Transform --> Inverse Laplace.
9K
  • MATLAB, Maple, Mathematica, LaTeX
