Register to reply
Free expansion of a Van der Waals gas, physical explanation
by fluidistic
Tags: expansion, explanation, free, physical, waals
Share this thread:
fluidistic
#1
May7-13, 08:37 PM
PF Gold
fluidistic's Avatar
P: 3,188
Hello!
Today I've learned that when a Van der Waals gas undergoes a free expansion, it cools down a bit.
This is in contrast with the ideal gas in which case since it does no work and since the process is adiabatic, the internal energy of the ideal gas remains unchanged by the expansion and since the temperature of the gas depends strictly on its internal energy, the temperature remains unchanged.
However for a Van der Waals gas, one has ##\Delta T=\frac{2an}{3R} \left ( \frac{1}{V_f} - \frac{1}{V_i} \right )##. Where a is, according to Wikipedia:
Quote Quote by WikiTheGreat
a measure of the attraction between the particles
So the change of temperature doesn't seem to depend on the size of the gas' particles, only on the attraction between particles and the change in volume.
I don't really grasp it physically. What's going on for a Van der Waals gas during a free expansion? Why is the temperature going down?!
Phys.Org News Partner Physics news on Phys.org
Refocusing research into high-temperature superconductors
Neutron tomography technique reveals phase fractions of crystalline materials in 3-dimensions
Tiny magnets, huge fields: Nanoscale ferromagnetic electrodes create chemical equivalent of solid-state spin valve
morrobay
#2
May7-13, 09:04 PM
P: 376
The conceptual explanation seems straight forward to me : If there are attractions between
the gas molecules then heat energy from the surroundings will be required to overcome them
during expansion. And of course that heat will be released during compression.
fluidistic
#3
May7-13, 09:26 PM
PF Gold
fluidistic's Avatar
P: 3,188
Quote Quote by morrobay View Post
Ah bingo!
That makes sense, thank you.
Edit: Hmm I'm not really sure. If I'm not wrong for both the ideal and Van der Waals gas, the total energy remains unchanged, no heat is being released/absorbed from the surrounding during the free expansion and no work is done either.
I'm still at a loss.
Jorriss
#4
May7-13, 09:41 PM
P: 1,042
Imagine there is no change in internal energy (as the gas can expand into a vacuum in an adiabatic bath).
Consider the interplay between kinetic and potential energy of the gas.
fluidistic
#5
May7-13, 10:01 PM
PF Gold
fluidistic's Avatar
P: 3,188
Quote Quote by Jorriss View Post
Yeah I noticed.
Quote Quote by Joriss
Hmm I'm not sure at all.
Apparently the kinetic energy decreases because the temperature decreases during the expansion? This would mean that the potential energy increases (is is the enthalpy?). But I don't get really understand why this happens.
Ah.. I think it's because the molecules are getting farther away from each other so the potential energy of "attraction" between the molecules increases. Since the total energy must remain constant, this means that the kinetic energy has to lower, and hence the temperature.
Does that sound correct?
Register to reply
Related Discussions
Physical meaning of the extremums of the Van Der Waals equation Introductory Physics Homework 0
Physical Chem Van der Waals eqn of state Biology, Chemistry & Other Homework 0
Van der Waals gas - free energy Advanced Physics Homework 1
Virial expansion of van der Waals equation Biology, Chemistry & Other Homework 1
Joule-Thomson Expansion of a van der Waals gas Advanced Physics Homework 0
