Fluid mechanics -- flow through a pipe (Bernoulli equation)
In summary: Chestermiller! In summary, the OP determined the head at the restriction by equating the head at the top of the tank to the head at the exit, and solved for h.
jinro
water flows steadily with negligible viscious effects through this pipe.
the 4-inch diameter section of the thin walled tubing will collapse if the pressure within is at 6 psi below atmospheric pressure. determine maximum h so that the tube won't collapse.
final answer for h to be in feet.
known data:
p1 = 0, V1 = 0, Z2 = 0, p2 = -6 psi, specific weight of water = 62.4 lb/ft^3, gravity = 32.2ft/s^2
bernoulli equation
p1/gamma + z1 + V1^2/2*g = p2/gamma + z2 + V2^2/2*g
gamma is specific weight of water, z is height of water, V is velocity of water, g is gravity, p is pressure
to convert from lb/in^2(psi) to lb/ft^2, multiple by 144in^2/ft^2
using bernoulli equation and known data, p2 = -6*144 = -864lb/ft^2
with z1 = 4ft
4ft = (-864)/(62.4lb/ft^3)+V2^2/(2*32.2ft/s^2)
-->V2 = 33.90~~ ft/s
from point 1 to 3
p1/gamma + z1 + V1^2/2*g = p3/gamma + z3 + V3^2/2*g
p3 = 0, z3 = -h, V3 = A2/A3*V2 = (D2/D3)^2*V2 = 15.0672 ft/s
4ft = -h + (15.0672ft/s)^2/(2*32.2ft/s^2)
4ft = -h + 3.525
h = -0.4748ft?
a negative value for h would not make sense!
thanks in advance
You set P2=-6 psi. This means you are using gauge pressure (ie, pressure relative to atmospheric pressure). When using Bernoulli equation, you must use absolute pressures, not gauge pressures.
Even if the density is constant? How will adding 1atm/gamma to both sides of every occurrence of the equation change the outcome?
It makes physical sense, but implies the diagram is misleading, and suggests a calculation error by either you or the question setter.
Hmm I will have to think about that one.
This is not correct. For incompressible fluid, use of gauge pressure is perfectly acceptable.
Likes Delta2
Sorry! @haruspex and @Chestermiller are correct. I will have to do the algebra myself to see if/where the OP went wrong.
Likes Delta2
The OP's setup has zero elevation at the restriction.
The OP solved by equating the head at the top of the tank to the head at the restriction, to find the velocity at the restriction. And then used this to find the head at the exit, allowing the height h to be calculated.
I can't quite explain why this is incorrect, except to note that the flow rate (and hence the velocity at the restriction) depends in part on the elevation difference between the top of the tank and the exit. The greater the height h, the greater the flow through the piping. Somehow the OP approach fails to take this into account; s/he determined the restriction velocity without finding h. I don't think that is possible.
I solved this by setting the exit at zero elevation, the restriction at elev h and the top of the tank at (4+h). Then equate the head at the top of the tank to the head at the exit, yielding a relationship between h and the exit velocity. Using that relationship along with the continuity (Vrestriction vs. Vexit), I was able to solve for h. I got 3.93 feet.
Likes Delta2
It was determined on the basis of the pressure in the central section being the critical value. You seem to be arguing that it has to calculated in a causal way, i.e. based on the exit height. I see no need for that. The equations should turn out the same.
If you would be so kind as to post your working, I will endeavour to pinpoint the reason for the different answer.
Likes gmax137
OK, this helps me, with the question I have on the OP method. I will check over my work to see if I can spot any blunders before I pass it along.
Thanks @haruspex ! In the course of transcribing my scribbled calcs into LaTex, I corrected an error and obtained the same result as the OP's simpler approach. For posterity (o:)) here is my updated calculation:
Bernoulli:
$$H = z + \frac {144~P} {\rho}~+~\frac {v^2} {2g}$$
where
H = head (feet)
z = elevation (feet)
P = gauge pressure, psig
##rho## = fluid weight density, lbf/ft^3
v = fluid velocity, ft/sec^2
g = grav acceleration, 32.2 ft/sec^2
I am setting z=0 at the 6-inch diameter exit. Then the elevation of the 4-inch section is h, and the top of the fluid in the tank is at elev (4+h).
I call the top of the fluid location "1", the 4-inch section location "2", and the exit location "3". I will determine the total head at these locations as H1, H2, H3. The density ##\rho## is constant at 62.4 lb/ft^3.
At location 1, the elevation is (4+h), the pressure is atmospheric (P=0 psig), and the velocity is assumed negligible (i.e., the tank area is >> the pipe area).
$$H_1~=~z_1+ \frac {144~P_1} {\rho}~+~\frac {v_1^2} {2g}$$
$$=~(4+h)~+~\frac {144~*~0} {\rho}~+~\frac {0^2} {2g}$$
$$=~(4+h)$$
At location 2, the elevation is h, and the pressure is -6 psig
$$H_2~=~z_2+ \frac {144~P_2} {\rho}~+~\frac {v_2^2} {2g}$$
$$=~h~+~\frac {144~*~(-6)} {\rho}~+~\frac {v_2^2} {2g}$$
$$=~h~+~\frac {-864} {\rho}~+~\frac {v_2^2} {2g}$$
At location 3, the elevation is zero, and the pressure is atmospheric (P=0 psig).
$$H_3~=~z_3+ \frac {144~P_3} {\rho}~+~\frac {v_3^2} {2g}$$
$$=~0~+~\frac {144~*~0} {\rho}~+~\frac {v_3^2} {2g}$$
$$=~\frac {v_3^2} {2g}$$
Equate H1 and H3, and solve for v3
$$=~(4+h)~=~\frac {v_3^2} {2g}$$
$$v_3^2~=~(4+h)2g$$
$$v_3~=~\sqrt {(4+h)2g}$$
Equate H2 and H3
$$h~+~\frac {-864} {\rho}~+~\frac {v_2^2} {2g}=~\frac {v_3^2} {2g}$$
by continuity,
$$A_2~v_2~=~A_3~v_3$$
$$v_2~=~ \frac {A_3} {A_2} ~v_3$$
And
$$v_2^2~=~( \frac {A_3} {A_2} )^2~v_3^2$$
Then
$$h~+~\frac {-864} {\rho}~+~\frac {( \frac {A_3} {A_2} )^2~v_3^2} {2g}=~\frac {v_3^2} {2g}$$
Solve for h
$$h~=~\frac {v_3^2} {2g} ~-~\frac {v_3^2} {2g} (\frac {A_3} {A_2})^2~+~\frac {864} {\rho}$$
$$h~=~\frac {v_3^2} {2g} ~(1~-~(\frac {A_3} {A_2})^2)~+~\frac {864} {\rho}$$
Insert v3^2 from above:
$$h~=~(4~+h) ~(1~-~(\frac {A_3} {A_2})^2)~+~\frac {864} {\rho}$$
$$h~=~4~(1~-~(\frac {A_3} {A_2})^2)~+~h~(1~-~(\frac {A_3} {A_2})^2)~+~\frac {864} {\rho}$$
$$h~=~\frac {4~(1~-~(\frac {A_3} {A_2})^2)~+~\frac {864} {\rho}} {1~-~(1~-~(\frac {A_3} {A_2})^2)}$$
$$(1~-~(\frac {A_3} {A_2})^2)~=~(1~-~(\frac {6^2} {4^2})^2)~=~-4.0625$$
so
$$h~=~\frac {4~(-4.0625)~+~\frac {864} {62.4}} {1~-~(-4.0625)}$$
$$h~=~-0.4748$$
Showing that "my" approach yields the same result as the OP.
Bernoulli:
where
H = head (feet)
$$=~(4+h)$$
$$v_3^2~=~(4+h)2g$$
Equate H2 and H3
by continuity,
And
Then
Solve for h
so
$$h~=~-0.4748$$
Thanks for sorting that out.
So, unless I've blundered again, the negative value of h means the restriction is below the exit, with the top of the tank less than 4 feet above the exit. The diagram is misleading at best.
For me, the take-away from the exercise:
1. the pressure terms can be taken from an arbitrary reference value
2. the elevation terms can be taken from an arbitrary reference value
Quite so.
Yes, as long as the density is constant.
Likes gmax137
1. What is the Bernoulli equation and how is it related to fluid flow through a pipe?
The Bernoulli equation, named after Swiss mathematician Daniel Bernoulli, is a fundamental equation in fluid mechanics that describes the relationship between the pressure, velocity, and elevation of a fluid in a steady flow. It states that the total energy of a fluid remains constant along a streamline, meaning that as the fluid flows through a pipe, the sum of its kinetic energy, potential energy, and flow energy (pressure energy) remains constant.
2. How does the diameter of a pipe affect the flow rate of a fluid?
According to the Bernoulli equation, as the diameter of a pipe decreases, the velocity of the fluid increases. This means that the fluid will flow faster through a smaller pipe, resulting in a higher flow rate. However, this also means that the pressure of the fluid decreases, as described by the Bernoulli equation. The relationship between diameter and flow rate is known as the continuity equation.
3. Can the Bernoulli equation be applied to both laminar and turbulent flow through a pipe?
Yes, the Bernoulli equation can be applied to both laminar (smooth and orderly) and turbulent (chaotic and irregular) flow through a pipe. However, the equation assumes that the flow is steady, incompressible, and inviscid, meaning that there is no friction or viscosity present. In reality, these conditions are rarely met, especially in turbulent flow.
4. How does the height of a pipe affect the pressure of a fluid?
The height of a pipe does not directly affect the pressure of a fluid, as stated by the Bernoulli equation. However, the elevation of a fluid can indirectly affect its pressure through changes in potential energy. For example, if a fluid flows from a higher to a lower elevation, its potential energy decreases, resulting in an increase in kinetic energy (velocity) and flow energy (pressure).
5. Can the Bernoulli equation be used to calculate the flow rate of a fluid in a real-life pipe system?
No, the Bernoulli equation is a simplified equation that only applies to idealized situations. In real-life pipe systems, there are many factors that can affect the flow rate, such as friction, viscosity, and turbulence. These factors are not accounted for in the Bernoulli equation and must be considered separately in order to accurately calculate the flow rate of a fluid.
