willstaruss22
- 108
- 1
I've been trying to figure this our for a while now. My science teacher asked this question and he wants an answer by tomorrow but I have no idea. Can anyone help with this?
Joseph King said:boiling points for liquids change with altitude
The temperature of the air does not have a direct impact on the boiling point of water. The boiling point of water is determined by the atmospheric pressure, which can vary depending on location and altitude.
Yes, it is possible for water to boil at a lower temperature if the atmospheric pressure is lower. For example, at high altitudes, the atmospheric pressure is lower and therefore water can boil at a lower temperature.
Yes, water can boil at a higher temperature if the atmospheric pressure is higher. For example, in a pressure cooker, the pressure is higher than the atmospheric pressure and water can boil at a higher temperature.
As altitude increases, the atmospheric pressure decreases, causing the boiling point of water to decrease. This means that water will boil at a lower temperature at higher altitudes.
No, the boiling point of water can vary depending on the atmospheric pressure. At sea level, water will boil at 212 degrees Fahrenheit, but in other locations with different atmospheric pressures, the boiling point can be different.
