Calculating rate law equation by determining initial rate of oxygen produced
In summary, the individual did seven trials with different concentrations of H202 and NaI, and recorded the volume and concentration of O2 produced. They then attempted to find the initial rate of decomposition of H202 by converting volume or mass to an initial rate of decomposition of H202.
jmarsiglio
http://scc.scdsb.edu.on.ca/Students/onlinecourses/Sikora/sch4u/v12/64.pdf
That is the lab I have been working on. I've done the lab but I am answering the questions. I don't understand the Analysis question #1. How do I calculate the reaction rate for oxygen if I don't have its concentration?
c = n/v
m = m/mr
r = k[h202]^m[NaI]^n
Well I know it's completely wrong but I took the volumes recorded of the oxygen produced, converted to moles, divided by the volume of NaI + h202 which was 20ml and divided by 10 seconds (for each trial).
Okay, nevermind, the question specifically says to convert th volume of O2 within the time interval to get the reaction rate, so it can't be that, if so what would be the point of getting the values for the volume.
edit: wouldn't it be the same... what the heck is the point of getting these values though! ARGHHHHHHHH someone please help I'm being torn apart it's 1:50 am but I can't go to sleep pleasezzzzzzzzzz helppppp!
edit2: now that I think of it, since they are different trials, I think they are independant from each other, therefore d[A] and dt don't exist... I believe it is just the mol/L*S of the actual oxygen... hmmmm, do i figure out the moles of oxygen, divide by volume (what would it be... 20ml?) and by the time of the reaction(10 seconds in this case)
please tell me ill hug you
Have you read the question? It specifically says to use the stoichiometry of the reaction - oxygen is just a product, and you are interested in the rate of decomposition of the H2O2.
Yes, several times.
It says "For each experiment, determine the initial rate of reaction. That is convert the volume, or mass, or increase in pressure of O2 within the time interval to get an initial rate of mol O2/(L*S). Using the stoichiometry of the reaction, convert this initial rate to a rate of decomposition of H202 in mol/(L*S)".
There are 2 questions here. Find the intial rate for O2, then using this rate, stoichiometrically determine the rate of decomposition of H202 which would be double.
I'll try and explain the lab. All trial are independant from each other. That is, they are different concentrations they are left to react for the same time. But it is not one experiment recording at different times, it is 7 different experiments with different concentrations and each 10 seconds. What the lab wants me to do is figure the initial rate for each experiment using the data of volume recorded, with units mol/(L*S). Then I graph the initial rates where H202 is constant and determine what order the reaction is regarding NaI, and vice versa. I can do ALL of this else except I don't know how I am supposed to find the initial rates with the volume of O2 into mol/(L*S). I can get ml/S or mol/S but not mol/(L*S).
Maybe my first attempt was correct when I changed to moles, then to concentration, and divided by time?
The data I have is the volume and concentration of H202 and NaI, and the volume of O2 recorded.
Thanks
to clarify, the concentration was changed manually, as an independant variable to see what affect it would have on the amount of oxygen produced (dependant variable).
You know how many moles of oxygen were produced, you know what was the volume of the solution, you know in what time, just combine these numbers to get correct units.
There is no such thing as oxygen concentration, as oxygen that you collect is not dissolved, it is a separate phase. However, when you use stoichiometry to find out how much hydrogen peroxide decomposed, you will be able to deal with concentration, as peroxide was in the the solution.
AMAZING! One more thing! The volume of the solution is the catalyst and the hydrogen peroxide? 20 ml in each case? Or just the h202: 10 ml?
I don't think the catalyst counts though, it just speeds up the process. So 10ml, I'll do this.
Correct?
No, to calculate concentration you need to know total volume. That is (approximately, in general volumes are not additive) sum of volumes of all samples mixed.
aha... I guess I have to multiply everything by two then -.-
Thanks.
(actually divide)
1. How do you determine the initial rate of oxygen produced?
The initial rate of oxygen produced can be determined by measuring the change in oxygen concentration over a short period of time at the beginning of the reaction.
2. What is the rate law equation?
The rate law equation is an equation that relates the rate of a chemical reaction to the concentrations of the reactants and any other factors that may affect the rate of the reaction.
3. How do you calculate the rate constant?
The rate constant is calculated by dividing the initial rate of oxygen produced by the product of the concentrations of the reactants raised to their respective reaction orders.
4. What is the importance of determining the rate law equation?
Determining the rate law equation allows us to understand the mechanism of a chemical reaction and predict how changing the concentration of reactants will affect the rate of the reaction.
5. Can the rate law equation be used to predict the rate of a reaction at any given time?
Yes, the rate law equation can be used to predict the rate of a reaction at any given time as long as the concentrations of the reactants and the rate constant are known.
