| New Reply |
Is it possible to get an explicit solution for this? |
Share Thread |
| Dec10-12, 11:58 PM | #1 |
x = 10logx + 30 (log is log base 10)
I cannot get to anything other than this implicit solution. By trial and error I can tell that x must be slightly more than 1/1000 but I would like to get an exact answer. |
| Dec11-12, 12:09 AM | #2 |
Recognitions:
You need a function such as the Lambert W function to get an explicit solution. Real solution are approximately .0001 and 46.6925.
| Dec11-12, 12:21 AM | #3 |
Thanks for the reply. I know you probably don't want to give me the answer right out but in looking at that Wikipedia article I still don't see how to do it. I am not able to get both x's on the same side in any manner resembling the examples from the article.
| Dec11-12, 04:01 AM | #4 |
Recognitions:
It can be a little tricky. These log's are base e.
x = (10/log(10))log(x) + 30 (-log(10)/10)x=-log(x)+30(-log(10)/10) (-log(10)/10)x+log(x)=log(10^-3) (-log(10)/10)x+log((-log(10)/10)x)-log(-log(10)/10)=log(10^-3) (-log(10)/10)x+log((-log(10)/10)x)=log(-log(10)/10^4) (-log(10)/10)x=W(-log(10)/10^4) x=(-10/log(10))W(-log(10)/10^4) There are log's of negative numbers in there. For finding numerical answers, you can improve your guess systematically guess 50 x = 10log10(x) + 30 guess 0 x=10^(x/10-3) Then in each case put the guess into the right hand side over and over until it changes very little. ie 50 10log10(50) + 30~46.9897000 10log10(46.9897000) + 30~46.7200267 ~46.6950 and so forth |
| Dec11-12, 05:16 AM | #5 |
Recognitions:
[tex]\ln(x) = ax + b[/tex] Now exponentiate both sided and put it in the form, [tex]x = e^b \, e^{ax}[/tex] Finally mult both sides by (-a) and rearrange into the form, [tex] (-ax) e^{-ax} = k[/tex] It should then be straightforward to use the Lambert W function. |
| New Reply |
Similar discussions for: Is it possible to get an explicit solution for this?
| Thread | Forum | Replies | ||
| Implicit and explicit solution for a given initial-value problem | Calculus & Beyond Homework | 4 | ||
| explicit construction of SO(n) | General Math | 7 | ||
| Explicit function | Precalculus Mathematics Homework | 11 | ||
| explicit solution of heat/diffusion equation | Differential Equations | 3 | ||
