Finding mass of charged particle - magnetic field
In summary, an isotope separator is used to separate charged particles with different masses by subjecting them to a constant magnetic field. The radius of the circular path followed by the heavier particles is 1.1 times that of the lighter particles. By using the equations for kinetic energy and radius, it can be determined that the ratio of their masses is equal to the ratio of their charges and their respective radii in the magnetic field.
scholio
160
an isotope separator is used to separate charged particles having different masses. assume that two types of particles enter a region of constant magnetic field with the same kinetic energy, and assume that all particles have the same charge.
the radius of the circular path followed by the heavier particles is found to be 1.1 times that for the lighter particles. what is the ratio of their masses?
kinetic energy U = 1/2(CV^2) = KE = 1/2(mv^2) where C is capacitance, V is electric potential, m is mass, v is velocity
radius r = mv/qB where q is charge, B is magnetic field
i set up two relationships using both equations for each particle, the lighter and the heavier.
lighter particle:
r = mv/qB = ---> v = rqB/m ---> KE = 1/2(mv^2) = 1/2(m(rqB/m)^2) = (rqB)^2/2m
heavier particle:
i want to use the r = mv/qB but since both particles have same kinetic energy, the mass will be greater but the velocity will be lower than that of the lighter particle.
what would be the best way to determine the mass and velocity of the heavier particle? should i assume an arbitrary amount, say two times greater?
is my approach for the lighter particle along the right lines, or is there a better way?
First answer me this:
An electron and a proton are injected into a uniform magnetic field at right angles to the direction of the field with the same Kinetic Energy. Then:
a)the electron trajectory will be less curved than the proton trajectory
b)the proton trajectory will be less curved than the electron trajectory
c)both the trajectories will be equally curved
d)both the trajectories will be straight.
Once you get this, go ahead.
The angular frequency of a charged particle in a uniform magnetic field is independent of its velocity or energy.This is also known as cyclotron theory.
Heavier the particle is , larger is its radius ; faster a particle is , larger is the radius.
Where does the confusion lie?
You are on the right track.Go ahead.
Can you find the relation between momentum and kinetic energy?
physixguru:
"b)the proton trajectory will be less curved than the electron trajectory" - because proton has greater mass than electron thus less affected by magnetic field
a little confused about how the problem is stated, i can't really assume the two particles are either both electrons or both protons because one is heavier, yet they share the same charge.
rl.bhat:
momentum p = mv
kinetic energy KE = 1/2(mv^2)
so KE = 1/2(p^2) ??
so KE = 1/2(p^2) ??
This is wrong.
KE = 1/2(p^2)/m or p = (2mE)^1/2...(1)
This can be written as p = qBr...(2)
Compare eq. 1 and 2 and find the ratio of the masses. Note that the KE is same for both the masses.
1. How do you find the mass of a charged particle in a magnetic field?
To find the mass of a charged particle in a magnetic field, you can use the formula: m = qB / rω, where m is the mass, q is the charge of the particle, B is the magnetic field strength, r is the radius of the particle's circular motion, and ω is the angular velocity. This formula is derived from the equation for centripetal force and the Lorentz force law.
2. What is the relationship between the radius of a charged particle's circular motion and its mass?
There is an inverse relationship between the radius of a charged particle's circular motion and its mass. This means that as the mass of the particle increases, the radius of its circular motion decreases. This relationship can be seen in the equation for finding mass in a magnetic field, where a larger mass results in a smaller radius.
3. Can the mass of a charged particle in a magnetic field be negative?
No, the mass of a charged particle cannot be negative. Mass is a scalar quantity, meaning it has magnitude but no direction. Therefore, it cannot be negative. In some cases, the charge or velocity of a particle may be negative, but the mass will always be positive.
4. What is the significance of the magnetic field in finding the mass of a charged particle?
The magnetic field is a crucial factor in determining the mass of a charged particle. The strength of the magnetic field will affect the radius of the particle's circular motion, which is a key component in the formula for finding mass. Without a magnetic field, the particle would not experience any force and would not be able to be measured.
5. Are there any other factors that can impact the accuracy of finding the mass of a charged particle in a magnetic field?
Yes, there are other factors that can impact the accuracy of finding the mass of a charged particle in a magnetic field. These include any external forces acting on the particle, the shape or composition of the particle, and the precision of the measuring instruments used. It is important to consider and account for these factors when conducting experiments to find the mass of a charged particle in a magnetic field.
