For which positive real numbers a does the series converge
In summary, the series Ʃo→∞ a^log(n) converges for positive real numbers a between 0 and 1/e, where logarithms are to the base e. The series becomes a geometric series when written as e^(log(a))^log(n) and converges by the properties of exponents and logarithms. The summation must start from 1 to infinity as log(0) is undefined. The series will not converge for values of a greater than 1 or less than 0, as it will increase exponentially.
.d9n.
61
Ʃo→∞ a^log(n)
converge.
Here logarithms are to the base e
Im afraid I'm not sure where to start, I'm not sure which topics would be applicable to this question. If someone could point me in the right direction or give me a clue, it would be much appreciated. tthanks
Is it possibly between -1 and 1? As log(n) will keep getting larger as n does. So if a<-1 and a>1 then it will keep increasing in size so therefore it must be -1<=a=<1? If this is right how would I go about proving it?
thanks i'll have a look at that
Ʃo→∞ a^log(n)
converge.
Hello .d9n. . Welcome to PF !
Write a as elog(a). Then using properties of logarithms you can show that this is a geometric series.
BTW: The summation needs to be from 1 to ∞ . log(0) is undefined.
so you mean
sum 1 to infinity e^(log(a))^(log(n))
I'm not sure what property i am trying to find. is there any need to change log(n) to the integral from 1 to n of 1/x? Or is there something to simplify log(a)^log(n). Otherwise i don't see the benefit of changing a to e^log(a).
thanks
is it
sum 1 to infinity of e^log(a^n)= sum 1 to infinity of a^n?
or is that just rubbish?
Perhaps I should have said properties of exponents and logarithms.
[itex]\displaystyle \left(b^k\right)^t=b^{kt}=\left(b^t\right)^k[/itex]
.d9n. said:
is it
Rubbish. (e^log(a))^log(n)=e^(log(a)*log(n))=(e^log(n))^log(a). Think about that.
Thanks so i am left with
sum 1 to infinity n^(log (a))
correct?
In regards to it converging I am assuming a must be between 1 and 9 for this to converge as log1=0 and log9=0.954..., bigger than 9 then it won't converge but increase exponentially?
correct?
You aren't thinking very clearly about this. If a=1 then log(1)=0 and the series is n^0=1. I.e. 1+1+1+... That does not converge. Try some more values. Don't forget values of a<1. You should start to realize this is a p-series. And usually when you write log, without indicating a base then you assume the base is 'e'.
[itex]\displaystyle\sum_{n=1}^\infty\ n^{p}[/itex] converges for what values of p ?
so ∑n=1,∞ n^p converges when -1<p<1 with p≠0, is that correct?
so therefore a=-9,-8,-7,-6,-5,-4,-3,-2,2,3,4,5,6,7,8,9?
No, that doesn't sound correct.
is it nearly correct?
i don't think it will converge if bigger than 1 or -1 as it will increase exponentially, so it must be between them?
No.
Perhaps it's more familiar to you in the following form.
For what value of r, will the following converge?
[itex]\displaystyle\sum_{n=1}^\infty\ \frac{1}{\ n^r}[/itex]
does it converge if p<-1
so it converges when r>1?
if r>1 which would make -p=r, what values for a would make log(a) negative?
That sounds good. So you want log(a)<(-1), right? Solve that for a. What's the inverse function to a log? And I don't think they mean log to the base 10.
so -1<a<1 a=/0,
say y=log(a) then the inverse is a=e^y ?
.d9n. said:
so -1<a<1 a=/0,
No again to the first line. But yes to the second. e^(log(a))=a. Take log(a)<(-1) and exponentiate both sides of the inequality.
so a<e^-1= a<0.367879441?
Now you've got it. And you also need 0<a. Otherwise the log (or your original series) isn't even defined.
so sum n=1 to infinity of a^log(n) converges when 0<a<0.3678...
.d9n. said:
so sum n=1 to infinity of n^log(a) converges when 0<a<0.3678...
Yes, but I'd write e^(-1) or 1/e instead of 0.3678... There's no need to replace an exact number with an approximation.
ok, brilliant. thanks for all your help, much appreciated
1. What is a series and what does it mean for it to converge?
A series is a sequence of numbers that are added together. For a series to converge, it means that the sum of the terms in the sequence approaches a finite value as the number of terms increases.
2. How do you know if a series converges or not?
There are several tests that can be used to determine if a series converges or not, such as the comparison test, ratio test, and integral test. These tests involve analyzing the behavior of the terms in the series and their relationships to each other.
3. What is the significance of positive real numbers in determining convergence?
The behavior of a series may differ depending on whether the terms are positive or negative. For positive real numbers, the series may have a higher chance of converging, but it is not a guarantee. However, if the terms are negative, it is more likely that the series will not converge.
4. Can a series converge for some values of a and diverge for others?
Yes, it is possible for a series to converge for some values of a and diverge for others. This is because the convergence of a series depends on the behavior of its terms, which can vary depending on the value of a.
5. Is there a general rule for determining which positive real numbers a will result in convergence?
There is no general rule that can determine which positive real numbers a will result in convergence. As mentioned before, there are various tests that can be used to analyze the behavior of a series and determine its convergence. The choice of which test to use may depend on the specific series and its terms.
