What is the square root of x^2?
In summary, the conversation discusses the concept of taking the square root of a number, and whether it should always return a positive value or if it can have both positive and negative values. It is agreed that when referring to "the square root" of a number, it is usually referring to the principal or positive value. However, when solving equations, both positive and negative values should be considered. It is also noted that the square root function is defined as a single-valued function, and taking the negative square root does not provide new information.
  • #36
Benn said:
I think you might mean
[tex]{ x }^{ 2 }=4\\ \sqrt{{ x }^{ 2 }}=\sqrt { 4 } \\ |x| = 2 \\ x=\pm 2[/tex]
As a reminder for the OP, while this argument does prove
If x2 = 4, then x = 2 or x = -2​
it does not prove
x = 2 and x = -2 are both solutions to x2 = 4​
unless you can argue that every step is reversible. (they are in this case)
Mathematics news on Phys.org
  • #37
it does not prove
What do you mean by every step is reversible? Can you give me an example where they are not reversible?
  • #38
x = -2 ## \Rightarrow## x2 = 4
The steps here are not reversible. If x2 = 4, it does not necessarily imply that x = -2.
  • #39
it does not prove
Wrong.Is x=2 a solution to x^2=4?-yes and is x=-2 a solution to x^2=4-yes, they are both solutions.Saying x=two values simultaneously is wrong, which I think is what you meant and thinking about this, with everything said generally being correct in this thread about(x^0.5)^2 being= to + or-(x) or abs(x) this means that (x^a)^b doesn't always equal x^(ab), which is an exponentiation law-I suppose there always are exceptions.The steps are irreversible because the inverse has more than one image, which isn't right.
  • #40
What Hurkyl said was absolutely correct. I think you misinterpreted his post.
  • #41
Alright, thanks for the help guys.
  • General Math
  • General Math
  • General Math
  • General Math
