Force = mass * acceleration. A question about gears.
In summary, when using a bike with a versatile engine and gearing mechanism, the force applied to the pedals may remain constant regardless of the gear, but the overall gear ratio and rotational inertia of the driven wheel play a role in allowing for faster acceleration when starting in a low gear.
pletharoe
This question is about push bikes, but could be applied to anything with a versatile engine and a gearing mechanism.
My bike is propelled by pushing on the pedals. Whether I use a high or low gear, the force remains the same. If the force and mass remain constant, how come I can accelerate faster by starting in a low gear and working up in stead of just starting in in the high gear?
When you pedal, you feel a constant force between a low gear and a high gear? I feel that the lower gears are harder to pedal...
The force on your pedals may remain the same for any gear, but the torque applied to your wheel varies with the overall gear ratio.
Also, the rotational inertia of the driven wheel, as seen at the driving gear, varies with the gear ratio squared.
All this transpires to make it easier to accelerate faster in low gear.
Cheers,
Terry
Which force? What matters for the acceleration of you+bike are the external forces on you+bike, like the force between road and wheel. In lower gears the same internal force on the pedal creates a greater external force between road and wheel, and therefore more acceleration.
This is because the gearing mechanism on your bike allows for a change in the acceleration of the bike, even though the force and mass remain constant. In a low gear, the pedals are easier to turn, allowing for a higher rate of acceleration. As you shift to a higher gear, the pedals become harder to turn, resulting in a slower acceleration. This is due to the relationship between force and acceleration, where a smaller force applied over a longer distance (in the low gear) results in a higher acceleration, while a larger force applied over a shorter distance (in the high gear) results in a lower acceleration. This concept is known as mechanical advantage and is commonly used in many machines, including bicycles.
1. What is the formula for calculating force?
The formula for calculating force is force = mass * acceleration, where force is measured in Newtons (N), mass in kilograms (kg), and acceleration in meters per second squared (m/s^2).
2. How does mass affect force?
According to the formula, force is directly proportional to mass. This means that as mass increases, force also increases, and vice versa. This relationship is represented by the slope of a force vs. mass graph, which is equal to acceleration.
3. What is acceleration?
Acceleration is a measure of how quickly an object's velocity changes over time. It is calculated by dividing the change in velocity by the change in time. This can be expressed as acceleration = (final velocity - initial velocity) / time and is measured in meters per second squared (m/s^2).
4. How are gears related to force and acceleration?
Gears play a crucial role in the transfer of force and acceleration in mechanical systems. In a gear system, the smaller gear will rotate faster than the larger gear, resulting in a greater acceleration for the smaller gear. However, the force remains the same for both gears, as stated by the formula force = mass * acceleration.
5. Can gears change the amount of force produced?
No, gears cannot change the amount of force produced. As mentioned, the force produced is dependent on the mass and acceleration of an object and is not affected by the gears themselves. However, gears can change the speed and direction of the force, which can be useful in various mechanical systems.
19K
  • Mechanics
