What is the relationship between p-adic and l-adic numbers?
  • Thread starter navigator
In summary, the p-adic integers can be formed even when p is not prime, but it wouldn't be a norm. The p-adic and l-adic are the same if l=p. There is no relationship between the p-adic field and the Galois field. You can define a p-adic integral and differentiation, but they are quite different from their real counterparts. The q-analogue of a function is not related to the p-adic numbers. The letter "l" is often used for a prime number different from the characteristic of a base field, such as in l-adic etale cohomology and p-adic crystalline cohomology. Galois fields are finite fields with q elements, where
navigator
42
1.Why the object requires prime number p?
2.Why the p-adic norm of x is defined by [tex]|x|_{p}=p^{-m}[/tex]([tex]x=\frac{p^{m}r}{s}[/tex]),not [tex]|x|_{p}=p^{m}[/tex]?
3.[tex]Q_{p}\subset R[/tex] or [tex]R \subset Q_{p}[/tex]?
4.What is the difference between p-adic and l-adic? what is the letter "l" stands for?
1) You can still form the p-adic integers when p is not prime. However, [itex]|x|_p[/itex] wouldn't be a norm ([itex]|xy|_p=|x|_p|y|_p[/itex] wouldn't be true), and the p-adic integers will not be an integral domain (there are zero divisors).
2) the alternative you suggest wouldn't satisfy |x+y|<=|x|+|y|, so it isn't a norm.
3) neither. Q < R and Q < Q_p.
4) l-adic is the same as p-adic, if l=p ! l is just some prime number.
Thank you.
One more question here is: What is the relationship between p-adic field and Galois field?
navigator said:
Thank you.
They're quite different. A Galois field is just any field with a finite number of elements; the p-adics form an an infinite field for each prime p.
can you define a p-adic integral of any function f(x) where x- is always a p-adic number
Can you define a p-adic differentiation ? in similar manner
Is there any relationship between the q-analogue of a function and the p-adic set of numbers?
In arithmetic geometry, one usually uses the letter, p, to denote the characteristic of a base field and "l" for a prime number different from the char.
For example, l-adic etale cohomology. p-adic crystalline cohomology.
i once heard a guy talking about galois fields. I asked him what the heck it was. he said it is a finite field.
So, if a finite field has q elements, then q is a power of some prime p. there is a subfield F_p in it. Z_p=inv.lim. F_p^n.
1. What are p-adic numbers?
P-adic numbers are a type of mathematical number system that extend the rational numbers to include infinitely small and infinitely large numbers. They are based on the prime number p, and they are represented by an infinite decimal expansion in which the digits repeat periodically.
2. How do p-adic numbers differ from real numbers?
P-adic numbers differ from real numbers in several ways. First, they are not based on a decimal system, but rather on a system based on a prime number. Second, p-adic numbers can represent infinitely small and infinitely large numbers, while real numbers are limited in their precision. Finally, the arithmetic operations for p-adic numbers are different from those for real numbers.
3. What is the significance of p-adic numbers?
P-adic numbers have many applications in mathematics, particularly in number theory and algebraic geometry. They are also used in physics and engineering, particularly in the study of fractals and chaotic systems. In addition, p-adic numbers have connections to other areas of mathematics, such as topology and group theory.
4. How are p-adic numbers calculated?
P-adic numbers are calculated using a specific algorithm that involves dividing the decimal expansion of a number by p and taking the remainder. This process is repeated infinitely to generate the full p-adic number. Alternatively, p-adic numbers can also be represented using power series or other methods.
5. What are some real-world applications of p-adic numbers?
P-adic numbers have been used in cryptography, particularly in the development of secure communication systems. They are also used in coding theory, which is important for data transmission and storage. In addition, p-adic numbers have applications in computer science, particularly in the analysis of algorithms and data structures.
  • Linear and Abstract Algebra
  • General Math
  • Science and Math Textbooks
