1st and 2d order phase transitions
In summary, the conversation discusses the difference between first and second order phase transitions and asks for simple examples of each type. The concept of equilibrium and the use of certain transitions as examples are also mentioned. There is also a discussion on how to prove that certain transitions are first or second order, and the limitations of classifying transitions based on the continuity of derivatives of the free energy.
paweld
255
What's the difference between first and second
order phase transitions. Could anyone give me some simple
examples of both?
Thanks.
For homework-type questions, we ask you to show your own reasoning first, then you'll likely get comments on your proposed answers.
OK, I'm looking for a simple example of second order phase transition.
Is "melting" of glass a good example? First derivatives of Gibbs potential
are continuous but what about higher. Second derivatives need to be
discontinous. Are they?
What in case of van der Waals gas. On the p-V-T plot all transitions are continous.
How about entropy?
I'm not sure a glass is the best example. Glasses aren't at equilibrium (they would generally crystallize except for kinetic limitations), so some object to applying equilibrium concepts like phase transitions to them.
Keep searching; there are one or two transitions that are always used as examples of second-order transitions.
Of course there are some examples which are alway used but they are not simple.
I don't have any idea why ferromangetic, superconductor or superfluid phase
transition are second order (how to prove it or at least intuitivly understand?).
How to prove that van der Waals gas transition are first order.
The general idea is to take the first (n-th) derivative of the free energy and to see that it is discontinuous. The van der Waals transition is a bit complicated given its coexistence region though. I'm sure the proof is available in some lecture notes online or you can find the details in some book on statistical mechanics.
The Fossheim, Sudbo book gives a very clear idea in its first chapter on the second order transition for superconductors. Quite generally second order transitions are linked to symmetry changes. It's quite intuitively easy to see one in superconductors when the Cooper pairs form and break. You get a similar phenomenon in ferromagnets where domains of aligned magnetic momenta are formed.
A first order transition (or discontinuous) will give off latent heat during the transition. A second order transition (or continuous transition) will not give off any heat during the transition.
Classification of transitions based on continuity of the derivatives of the free energy is outdated, as it fails to account for cases in which a derivative of the free energy diverges at the transition.
http://en.wikipedia.org/wiki/First-order_phase_transition#Classifications
What is a 1st order phase transition?
A 1st order phase transition is a type of phase transition in which there is a discontinuous change in the order parameter (a measure of the state of a system) at a specific temperature or pressure. This results in a sudden change in the physical properties of the system, such as the density or energy.
What is a 2nd order phase transition?
A 2nd order phase transition is a type of phase transition in which there is a continuous change in the order parameter at a specific temperature or pressure. This means that there is no sudden change in the physical properties of the system, but rather a gradual change as the system moves from one phase to another.
How do 1st and 2nd order phase transitions differ?
The main difference between 1st and 2nd order phase transitions is the nature of the change in the order parameter. In a 1st order transition, there is a discontinuous change, while in a 2nd order transition, there is a continuous change. This results in different physical properties and behaviors of the system during the transition.
What are some examples of 1st order phase transitions?
Some examples of 1st order phase transitions include the melting of ice, the boiling of water, and the transition of liquid water to solid ice. In each of these cases, there is a sudden change in the physical properties of the substance at a specific temperature or pressure.
What are some examples of 2nd order phase transitions?
Some examples of 2nd order phase transitions include the Curie temperature of ferromagnetic materials, the superconducting transition in certain materials, and the liquid-gas transition in fluids. In these cases, there is a continuous change in the physical properties of the system as it undergoes the transition.
  • Atomic and Condensed Matter
  • Classical Physics
  • Other Physics Topics
