CIRCUIT ANALYSIS: 7resistors & 1 I.V.S. - Find equivalent resistance and current
In summary, to find R_{eq} and i_0 in the given circuit, we use the resistor equations and simplify the circuit to a series circuit. After combining the resistors in parallel and series, we get an equivalent resistance of 12.5 ohms and a current of 3.2 amps. Therefore, R_{eq} = 12.5 ohms and i_0 = 3.2 amps.
VinnyCee
489
Find [itex]R_{eq}[/itex] and [itex]i_0[/itex] in the circuit below.
http://img215.imageshack.us/img215/3074/chapter2problem38aw0.jpg
[tex]v\,=\,i\,R[/tex]
Parallel and series resistor equations.
After using the resistor equations to get down to [itex]R_{eq}[/itex], I get the diagram below.
http://img218.imageshack.us/img218/3425/chapter2problem38part2xf8.jpg
[tex]40\,V\,=\,i_0\,\left(5\Omega\right)[/tex]
[tex]i_0\,=\,\frac{40\,V}{5\Omega}\,=\,8\,A[/tex]
So, [itex]R_{eq}\,=\,10.3\Omega[/itex] and [itex] i_0\,=\,8\,A[/itex]?
I don't agree that 10.3ohm is the result of the combination of the other 6 resistors.
In the second figure, surely you cannot write i0 = 40/5 without taking into account the other (10.3ohm) resistor.
Whoops, maybe [itex]R_{eq}\,=\,7.5\Omega[/itex]?
http://img90.imageshack.us/img90/1933/chapter2problem38part3jr5.jpg
Combining the two resistors in parallel that are circled in green.
[tex]\frac{(12\Omega)\,(6\Omega)}{(12\Omega)\,+\,(6\Omega)}\,=\,\frac{72}{18}\,\Omega\,=\,4\Omega[/tex]
http://img111.imageshack.us/img111/9434/chapter2problem38part4um9.jpg
Now combining the two resistors circled in green that are in parallel.
[tex]\frac{(80\Omega)\,(20\Omega)}{(80\Omega)\,+\,(20\Omega)}\,=\,\frac{1600}{100}\,\Omega\,=\,16\Omega[/tex]
http://img441.imageshack.us/img441/9001/chapter2problem38part5rb8.jpg
Combine the two resistors circled in green that are in series.
http://img20.imageshack.us/img20/8697/chapter2problem38part6bu7.jpg
Combine the two resistors circled in green that are in parallel.
[tex]\frac{(60\Omega)\,(20\Omega)}{(60\Omega)\,+\,(20\Omega)}\,=\,\frac{1200}{80}\,\Omega\,=\,15\Omega[/tex]
http://img294.imageshack.us/img294/7270/chapter2problem38part7ac4.jpg
Combine the last two resistors circled in green that are in parallel.
[tex]\frac{(15\Omega)\,(15\Omega)}{(15\Omega)\,+\,(15\Omega)}\,=\,\frac{225}{30}\,\Omega\,=\,7.5\Omega[/tex]
http://img363.imageshack.us/img363/1525/chapter2problem38part8yh6.jpg
So how do I solve for [itex]i_0[/itex] if that is the right [itex]R_{eq}[/itex]?
In your reduced circuit, the current should be the same through the whole circuit, right? Which makes sense, since the sum of the currents through all of those branches has to equal the current going through the 5 ohm resisitor.
You've reduced your circuit to a series circuit. Divide the voltage by the sum of your resistance.
[tex]V\,=\,i\,R[/tex]
[tex]i_0\,=\,\frac{V}{R}\,=\,\frac{40\,V}{12.5\Omega}\,=\,3.2\,A[/tex]
So, [itex]i_0\,=\,3.2\,A[/itex]?
yea that's correct
1. What is circuit analysis?
Circuit analysis is the process of determining the behavior of an electric circuit by studying its components and their interactions. It involves using mathematical equations and laws, such as Ohm's law, to analyze the voltage, current, and resistance in a circuit.
2. What is equivalent resistance?
Equivalent resistance is a single resistor that can replace a combination of multiple resistors in a circuit. It has the same effect on the flow of current as the original combination of resistors.
3. How do you find the equivalent resistance in a circuit?
To find the equivalent resistance in a circuit, you must first identify which resistors are connected in series and which are in parallel. For resistors in series, you simply add their values together. For resistors in parallel, you use the formula 1/R(eq) = 1/R1 + 1/R2 + ... + 1/Rn, where R(eq) is the equivalent resistance and R1, R2, etc. are the individual resistances. Once you have the equivalent resistance for each series and parallel section, you can combine them using the same methods until you have a single equivalent resistance for the entire circuit.
4. What is an I.V.S. in circuit analysis?
I.V.S. stands for "independent voltage source." It is a component in a circuit that maintains a constant voltage regardless of the current flowing through it. This means that the voltage remains the same even if the rest of the circuit changes.
5. How do you find the current in a circuit?
To find the current in a circuit, you can use Ohm's law, which states that current (I) is equal to voltage (V) divided by resistance (R): I = V/R. You can also use Kirchhoff's current law, which states that the sum of all currents entering a node in a circuit must equal the sum of all currents leaving that node.
