Predicting Acid/Base of Salts: Explanations Included
  • Thread starter plexus0208
In summary, the acid/base nature of a salt can be predicted by determining the anion and cation present in the salt. A weak acid only partially dissociates in water, while a strong acid completely dissociates. A salt can have both acidic and basic properties if the anion and cation have amphoteric behavior. The strength of the acid or base used to form a salt can greatly affect its properties. To accurately predict the pH of a salt solution, you need to know the concentrations of the salt and water.
plexus0208
49
Predict whether an aqueous solution of the following salts will be acidic, basic or neutral. Briefly
explain your results.
a. NH4Cl
b. NaCl
c. MgCO3
d. NaH2PO4
e. KNO3
NH4Cl + H2O --> NH4OH + HCl (acidic)
NaCl + H2O --> NaOH + HCl (neutral)
MgCO3 + H2O --> MgOH + HCO3 (basic)
NaH2PO4 + H2O --> NaOH + H3PO4 (basic)
KNO3 + H2O --> KOH + HNO3 (neutral)
Is this correct?
Good.
Predictions are OK, but reaction equations are horrible.
methods
1. How do you predict the acid/base nature of a salt?
In order to predict the acid/base nature of a salt, you need to determine the anion and cation present in the salt. If the anion is the conjugate base of a weak acid, the salt will be basic. If the cation is the conjugate acid of a weak base, the salt will be acidic. If both the anion and cation are from strong acids or bases, the salt will be neutral.
2. What is the difference between a weak acid and a strong acid?
A weak acid does not completely dissociate in water, meaning only a small portion of the acid molecules will release hydrogen ions. A strong acid, on the other hand, completely dissociates in water, resulting in a higher concentration of hydrogen ions.
3. Can a salt have both acidic and basic properties?
Yes, a salt can have both acidic and basic properties. This is known as amphoteric or amphiprotic behavior, and occurs when the anion and cation have the ability to act as both an acid and a base.
4. How does the strength of the acid or base used to form a salt affect its properties?
The strength of the acid or base used to form a salt can greatly affect its properties. If a strong acid and a strong base are used, the resulting salt will be neutral. If a strong acid and a weak base are used, the salt will be acidic. If a weak acid and a strong base are used, the salt will be basic.
5. Can you predict the pH of a salt solution without knowing the concentrations of the salt and water?
No, in order to accurately predict the pH of a salt solution, you need to know the concentrations of the salt and water. This is because the pH is affected by the concentration of hydrogen ions, which is determined by the concentration of the salt and the dissociation of the salt in water.
12K
9K
13K
