Can you decipher what my prof said regarding my hw question towards her?
  • Thread starter badtwistoffate
In summary: However, in the lab setup we had, the mass was fixed to the spring and the spring was rotating on a horizontal plane. This means that the frictional force was acting away from the centre of rotation and the spring force was the only real force acting on the mass.
badtwistoffate
81
Can you decipher what my prof said regarding my homework question towards her!?
My Q:> I did not acquire the accepted value for percent
> difference that we are doing in lab for F spring and F rotation, was it
> given, if so what is it?
Whatever the difference is, it is; discuss the difference in your report.
Supposed to figure out the 2 values, based on values you
measured or otherwise recorded in lab.
So discuss the difference. But how do I get accepted values to use for percent difference?
What exactly did you measure? What was the setup?
I measured F rotation and F spring. F spring by by multiplying weight of my mass * 9.8 m/s^2 and F rotation by Slope(T^2)= = F/4*pi^2*m and solved for F. I just pluged them into get my values for F rotation and F spring.
bump, anybody?
Was the spring fixed to the axis and the mass rotated on a horizontal table while being attached to the spring?
yes
it was
Your instructor is correct.
There is no such thing as "an accepted value for percent difference". There is an accepted value of a quantity, and there is an experimental value that you obtained, but there is NO accepted value of the differences. Each experiment will produce a range of value of a certain quantity. The difference will depend on the equipment, how well the experiment was done, random and systematic errors, etc. From what I can guess, you are asked to account for the difference between what you got, and what the accepted value is. This is important especially if the difference is large. Did you do something wrong? Did the equipment not perform the way it should when you were taking data? Did someone opened the door and let a gust of air in while you're doing it? Etc...etc.
Zz.
Was there some instructions on how to change the speed of rotation as to keep a certain relationship between the radius of rotation and the period (or square of the period) of the rotation? If not, what was plotted on the axes of the graph?
Well, I still not sure exactly what you did, but it seems to me that the spring force should "theoretically" be the centripetal force that causes the rotational motion. Looking at the rotating mass one can also calculate this centripetal force. The difference between the two is what is under discussion. I said theoretically since one always have yo deal with friction and since the mass tends to slide outwards one would normally have a frictional force acting towards the centre of rotation. This frictional force is therefore helping the spring force to give the "real" centripetal force.
What is deciphering and why is it important?
Deciphering is the process of interpreting or understanding something that is difficult to understand. It is important because it allows us to make sense of complex information and communicate effectively.
Is it possible to decipher what someone said if they were not clear?
Yes, it is possible to decipher what someone said even if they were not clear. This requires careful listening and asking for clarification if needed.
How can I improve my deciphering skills?
One way to improve your deciphering skills is to practice active listening. This involves paying close attention to what is being said and asking questions to ensure understanding. Additionally, reading and researching can also help improve deciphering skills.
What are some common strategies for deciphering unclear information?
Some common strategies for deciphering unclear information include breaking down complex information into smaller parts, using context clues, and asking for clarification or examples. It can also be helpful to take notes and summarize what was said to ensure understanding.
Can deciphering be improved through technology?
Yes, technology can be a helpful tool for deciphering. For example, using speech-to-text software can help translate spoken words into written text, which can be easier to understand. Additionally, there are various apps and tools that can assist with decoding complex information.
  • STEM Academic Advising
