Photon Size: Direction & Probability
  • Thread starter alvaros
  • Tags
    Photon
In summary, photons go in all directions, but there is a probability you can find it in any direction.
  • #211
Anonym said:
That is not what I have in mind. Zz is the experimentalist.
that is he that--and probably more
Anonym said:
You need the standard references and standard terminology if you want that the other people will understand what you want to say.
hopefully you know that was not what I was saying
Anonym said:
What is the problem? Just apply to Zz at ANL to be his student/assistant. They need youngers with one leg in the experiment and the other in the theory.
Regards, Dany.
and from post 51:
Anonym said:
I have no professional knowledge in details of the Particle Accelerators.
we could BOTH apply and be ROOM MATES
--but the problem would be, if we did apply and be the junior peon preons in the accelerator world, from what I'm reading that we STILL wouldn't find out 'how big a photon is'
  • #212
ZapperZ said:
I wonder about A LOT OF STUFF! That is irrelevant to what we are discussing here. Just because I tow the "party line" and refuses to speculate about things on here should not be associated with the notion that I do not wonder about such things. I too follow the PF guidelines, and it is inappropriate if I start spewing off all the stuff that I "think" is neat and wonderful, yet I have nothing to back them with.
Zz.
I don't have problem with the part about you toeing the party line--I think I got that part. --and there is, also to me, a fine line between being subjective in an opinion (from knowledge) and speculative; in that you (and the other mentors) have to define from time to time.
anyway, post 202 was answering to your question, not me just spewing (and I wasn't arguing either)
  • #213
rewebster said:
is HUP complete? hopefully you know that was not what I was saying
Honestly, I have no any idea what you have in mind and what does it mean.
Go ahead. I promise it will be great fun not only for Zz but for whole ANL!
However, you missed something. I know 'how big a photon is' in QED but don’t know that in CED yet. I do not need help from them. This is my job.
Regards, Dany.
  • #214
Regards, Dany.
(shhhhhh-----don't say that aloud around here-----shhhhh)
  • #215
rewebster said:
so, the well trodden path is the best way?
I think it was Zz who lead me from the dark side. He made a rather good post that answered this question in terms I felt made the most sense. If people really want to find out good answers to this they've all been given numerous times before and will suit most people.
To be frank though I was never really that convinced it had mass, I just had questions like a a lot of people do.
In this particular case and with our current level of technology, the well trodden path is best . Words of wisdom do not cover everything, at some point you have to accept that to proceed further along the unbeaten trail you need better machinery :smile:
  • #216
-----LHC ?
  • #217
I don't think it's going to suffice, it's not so much smashing them apart but how you detect and measure such tiny portions of energy amongst the mass of energetic particles created in a collision; besides establishing the mass or ever more precise upper limits of a photon is not as important as establishing the existence or non existence of say the Higgs Boson, so since detection methods aren't precise enough scientists probably have better things to do with it. I'm not an expert not even close, but I don't think we are anywhere near being refined enough with the machinery atm. I'd ask Zz...
  • #218
I wasn't too serious when I suggested it---just the idea of 'bigger and better' came up.
I wonder how many betting 'pools' have come up as to how many new particles will be 'discovered'/'created' with the first year there.
well, that's good for you though that's one less worry/thing to think about if it is 'at rest' now.
  • #219
ZapperZ said:
But one can say that to every single quantum particles.
Zz.
No! I don’t agree with this statement. The idea of the photon was at least partly introduced as a solution to the old problem of what causes “action” at distance. But the question presupposes the notion of locality. This in the context of modern physics would be the assumption that the “particles” composing matter can be assigned, for any given time, a unique position in space. However, correlation experiment results showing the violation of Bell’s inequality suggest that our world has a non local flavour; casting doubts on the idea that particles of matter can be assigned exact locality relative to our inertial reference frames. This in turn puts into doubt the need for carrier particles to mediate action at a distance. If the locations of “particles” are not fixed exactly relative to our inertial reference frames then neither are the gulfs that separate them and direct interaction between pairs of particles becomes possible when the gulf between them has zero magnitude.
The “particles”/ “fields” of matter must remain in our philosophy it is only the photon (the suggested mediator of force) that is surplus to the explanation of electromagnetism.
  • #220
ZapperZ said:
At the same token, photons and other quantum particles have definite position upon measurement, or else, what exactly are those photomultipliers and CCD detectors measuring? So what exactly do you mean by "cannot have exact locality" here?
Zz.
No one has ever observed the position of a photon or any other quantum particle. What you observe is a macroscopic response in a particular experimental set up. The timing and position of the response may be measured with exquisite accuracy but the observable response exists at the end of a sequential causal chain that is necessary to amplify a quantum event to an observable event.
You are observing the location of a macroscopic event that is initiated by a quantum event. There is no clear logical path that links what is observable to where and when the quantum event took place. To give a photon or other quantum particle a definite position on this evidence is unsustainable. All we can say is that somewhere in the four dimensional manifold an event has occurred that has affected our detection device in a particular way. There is no justification based on experimental evidence for assigning a definite position to a quantum object.
  • #221
Then you need to write a rebuttal to all the experimental high energy physics papers, and even to condensed matter papers using anything that measures electron and neutron spectroscopy such as what I've shown in my avatar. Look under ANY papers in any physics journal that actually detects these particles and tell them that they're not really detecting that 'quantum event'. Remember, in angle-resolved photoemission experiment, the location where the electron hits the detector just doesn't signify that this electron was there at that time, but also carries information about its energy and "in-plane" momentum while it was in the solid!
Did I see electrons? Of course not! But did I detect that at the instant the detector made its detection, that quantum particle was there? Sure I did! Is this macroscopic? Of course it is! All our measurements are not only macroscopic, they are also classical! That is why I can talk about "position" and "momentum" and "energy", because these are all classical concepts. It is also the CAUSE of the weirdness at the quantum level, because we are asking for properties that are not that well-defined at the quantum world.
Note that in the HUP, there's nothing here that says that you cannot measure, as accurately as technologically possible, the position and momentum of just ONE measurement. The accuracy of these measurements do not depend on the HUP, but depends on the accuracy of the instrumentation and technique. The HUP says nothing about a single measurement. The HUP, however, tells you (i) the accuracy that you can predict the NEXT measurement, given the accuracy that you have imposed on one of the non-commutating observable, and (ii) the spread in the value of that observable after repeated identical measurement.
Zz.
  • #222
Huh?
What's with the Bell inequality all of the sudden?
Here's what you can do. Write down the wave function for a free particle. Now find <x>. Tell me what is "local" here.
Zz.
  • #223
Zz.
Sorry for this late response I only rarely get chance to look at your forum
Far be it from me to issue a rebuttal; a lead balloon comes to mind. Within the context of the ARPES experimental setup and other scattering experiments the electron and the “photon” seem to behave as if the were particles. This has been known for many years and the advance in the energy resolution and angular resolution (momentum) does not alter this perspective. But because in this particular experimental set up we can explain the observed “classical” outcome by regarding the electron and “photon” as particles does not mean that is what they actually are. We can not pick and choose our experiments to fit our favourite theories we also have to take into account other experimental circumstances where the idea of a particle fails to explain the observed outcomes.
I cannot agree that particles are actually detected, an observer detects a classical event a change in the observable state of the detector and we only infer it is a response to a quantum event. I have no doubt that the observed change in the state of the detector is consequential on a quantum event occurring. Whether or not the quantum event has a specific location relative to our reference frame and the location of the detector I would suggest is unknowable.
  • #224
Zz.
This is your inference not what you actually detected or what’s likely to have happened at quantum level?
  • #225
Zz.
Then perhaps you will agree that the measured values for "position" and "momentum" and "energy" are properties of the changes in the detector(s) and do not necessarily represent the state of a quantum entity immediately before the detection?
Zz.
This depends on the group behaviour of the quantum systems forming the measuring apparatus and their interaction within themselves and with the quantum system to be measured as well as the group behaviour of the quantum systems forming the brain and creating the mind of the observer ( Locality for instance may be a property of the observer and not the quantum object). The resulting measurements may be extremely accurate at macroscopic level(classical outcome) but this does not necessarily mean it is providing precise information, say, about the position of something that may be inherently fuzzy.
We must have a better understanding of the group behaviour of quantum systems that form the experimental set up since it is their collective behaviour that allows us to obtain accuracy of measurement relative to our inertial reference frames. Our observations are limited to the macroscopic outcome of experimental situations. We may be capable of fixing the position of these outcomes with extreme accuracy, but this accuracy is created by the group behaviour of the quantum systems forming the detector and the “clocks” and “rulers” needed to fix the response’s location. The place and time of a quantum interaction initiating a detection event cannot be specified from the information we have available to us.
  • #226
Zz.
This reinforces the belief that the quantum objects do not possesses specific locations; their interactions do not possesses specific locations and their particle like behaviour is an illusion created by the integrated behaviour of all the quantum systems participating in the experimental set up. It also reinforces the idea that the wave-function controls of how the distribution of the intensity of a “particle’s” likelihood to interact is projected onto our reference frames.
  • #227
ZapperZ said:
Huh?
Zz.
My principle reason for doubting the existence of the photon was that its raison deter was to mediate the electromagnetism; to bridge the gulf between charged quantum entities. But if quantum entities don’t have uniquely defined positions in the world then the gulfs separating them are also undefined; opening up the possibility of direct interaction between the charged systems. I therefore brought the evidence of the violation of Bell’s inequality to reinforce the idea that charged quantum systems do not have unique positions in space, since here was further evidence of a non local flavour to our world.
As I wrote earlier you can’t pick and choose your experimental results to reinforce your favourite theory. Our underlying understanding of how things happen must explain all known experimental results if it is to be valid.
Locality is fundamental to classical physics, but the conventional definition seems incapable of explaining in a consistent way all the experimental results obtained by physics. At the heart of the problem is the Born rule that allows one classical description of a quantum entity; where the entity is spatially distributed; to be transformed into possible classical outcomes where the entity becomes point like.
Explaining how this happens in a relativistically friendly manner is one of the great problems of natural philosophy.
Zz.
Further evidence that you cannot pin point a quantum entity!
Measures of location are facilitated by the collective behaviour of quantum systems and their group “position” in the manifold.
I stand by my assertion that the weight of this evidence suggests that charged systems interact directly, so there is no requirement in nature for man’s photon. So the answer to Alveros’s question seems to be; something that does not exist does not have a size!
  • #228
Come again?
Other than the fact that this issue is getting pretty old and I've lost interest in it already, I have no idea what you just said here. If the detector is more of a property of itself, then you have to seriously explain why it just didn't make a detection trigger all by itself. Why does it need a photon (or anything else) to cause a measurement?
You are also forgetting that everything that you detect (including all of your sense) is an interaction of something with something. As an experimentalist, I have to be keenly aware of what I'm measuring and how I'm measuring it. Still, this doesn't address the "size of a photon", because you still have to "detect" the size. While I can point to you a position operator in QM, can you define for me a "size" operator?
I have no clue on what you just said here. You somehow made it sound as if this is something we know nothing about. How do you think they detect those exotic particles in high-energy collisions at CERN and Fermilab? Do you think they are not keenly aware of how exactly the detection works and how they interact with what they're trying to detect? I mean, give these hard-working (and very intelligent) people SOME credit!
Zz.
  • #229
Then I want you to submit a paper to PRL to explain the results of the anti-bunching experiments without invoking the photon picture. Till you do that, I strongly suggest you cease making such statements on here that clearly violates the PF Guidelines. This is the only warning that you will get on this matter.
Zz.
  • #230
Wow. A few things: photons were invented by Planck and Einstein to explain black body radiation and the photoelectric effect. The invention of QED - Heisenberg, Pauli and Dirac, and Fermi -- brought Gauge invariance into play. so, in the Coulomb gauge, with divA=0, the particle-particle Coulomb interaction is a direct interaction; in the Lorentz Gauge, for practical purposes, the Coulomb interaction is mediated by photons -- Dirac gives an elegant discussion of the Coulomb gauge in his Quantum theory text.
Gauge Invariance is a big deal, an important deal; photons are tricky, no doubt, but no one has come close to presenting a better idea.Best to check it out.
Re positions: read about the basics of probability theory, then you will see the fallacy in your arguments about positions and interactions and the like.Note also that if positions and "gulfs' are uncertain then the probabilty of direct interactions will be very low. Why?
Regards,
Reilly Atkinson
  • #231
ZapperZ said:
Come again?
The particle-like behaviour is manifest in the interaction, not in flight. All we know is that light behaves as wave from source to detector and as particle at the detector. Period.
  • #232
We do? How do you know? Because it can "interfere" with itself? Even single photons? How do you explain the which-way experiments and the anti-bunching experiments, all of which have to occur "during flight" and then detected?
This is getting silly. We are now turning this thread into a "photon" thread. I guess this is probably because the issue of the "size of a photon" is dead and buried but people just can't leave that photon well-enough alone? Again, talk is cheap. Please show a citation where an alternative explanation and description has been done for those two experiments that I cited, plus the multi-photon photoemission.
Zz.
  • #233
ZapperZ said:
Come again?
Zz.
I mean that your interaction as the observer is with the detector and not the particle. Locality (of the detection) is a property of the group behaviour of the quantum systems forming the detector and the accuracy of the detector depends on their group behaviour.. Of course the detector needs to interact with something but the position of the actual interaction is not definable, only the response of the detector can have known position. Quantum mechanics only predicts the probable observable and measurable outcomes of experiments
Zz.
Sorry I thought that was exactly what we were talking about; that is the locality of the quantum interaction the initiates a response at an observable position at the detector.
Zz.
I’m sure you are an excellent experimentalist; even so, nature will only permit you to observe the response of the detector to a quantum event and not the event itself.
Zz.
If my reasoning is correct such an operator is unnecessary.
Zz.
I do, I think you should conduct a survey and ask them how exactly the detection works and how they interact with what they detect. I suspect you might be in for a surprise.
  • #234
Zz.
Sounds like reasonable challenge.
Zz.
Sorry! just got carried away
  • #235
Incidentally it was Ludvig’s Gauge not Hendrik’s but Lorentz invariant all the same.
Regards,
Reilly Atkinson
That all depends on the descriptions of the interacting entities and their event arena?
  • #236
Then by your conclusion, all types of measurement is suspect, including those made on electrons, protons, neutrons, neutrinos, etc.. Would you also like to write a paper to PRL and challenge all those experimental papers? For example, look at any photoemission papers such as those using ARPES that actually detect electrons on CCDs. Tell me that the position that I measured on the detector is not the exact position where the electron actually hits the screen, and that my deduction of the momentum based on that position has MORE to do with my interaction with the detector.
You seem to be talking full of hot air. Please make exact citations that actually support what you are saying.
I did! I work in the High Energy Physics division! I talk to these experimentalists all the time. Maybe it is YOU who should be doing that survey.
Zz.
  • #237
Zz.
Ok I can measure the position of an electron by passing it through a hole in a barrier and I know exactly where the electron was when it passed through the barrier. I then calculate the probability density for where it might interact with a screen beyond. If the barrier has two holes then I have two measures for the position of the electron as it goes through the screen and the distribution for where it is likely to hit the screen must be modified accordingly. In fact I can have as many measures of the position of where the electron goes through the barrier as a like and each will contribute to where I’m likely to find my interaction on the screen.
So did the electron have an exact position as it went through the barrier?
Does the experimental set-up influence the distribution of the likely measurable momentum along the plane of the screen?
  • #238
You seem to have a very strange way of making a position measurement, and then telling me something else about it. And why are we now talking about a "momentum" along the plane of the screen? This isn't a discussion about the HUP!
The "momentum" that I referred to is the momentum measurement in ARPES where the POSITION of the electron hitting the detector is equivalent to the in-plane momentum of the electron. In fact, it is the in-plane momentum of the electron while it was in the crystal material that emitted the electron in the first place. The resolution of the position corresponds directly to the resolution of the momentum. Refer to any of the latest ARPES papers on high-Tc superconductors, for example, since T. Valla's paper in Science in 1999. You'll see something that looks like my avatar!
Thus, you DO measure a position of electrons, etc. and upon measurement, make a direct connection to the trajectory of that electron back to where it came from. In fact, this is what experimentalists in high energy physics do all the time - making a vertex reconstruction of the event that they detected. They do this for practically everything to distinguish and identify the original particle that made the signal, be it EM showers (photons), muons, etc... We do the same thing for neutrino detectors at SuperK, MINOS, etc, which essentially are photon detectors! So to claim that the position being measured by these experiments have nothing really to do with an actual position of the particle but rather more to do with the detectors themselves is contrary to what is being practiced all over.
Have you noticed that not once have you made any direct reference to anything published or actual experimental work to support what you are saying? Why is that? In addition, when was the last time you actually had to make a photon or electron position detection?
I also notice that you could not tell me how many high energy experimentalists you have surveyed regarding their detection methods. Does that mean that many of the criteria you impose on me does not apply to you?
Zz.
  • #239
Because when you localize a photon, you loose the interference pattern, which is described by wave behaviour. To localize the photon means to detect it. Conclusion: when you don't detect it, the photon is described by a wave, when you detect it, by a particle.
Exactly which of the "which-way experiments" and of the "anti-bunching experiments" are you referring to?
Zz.
What is "multi-photon photoemission"?
Thank you.
  • #240
I'm sure by now that it would have gotten through you that I am not going to accept something just because you said so. Show me an exact citation of such formulation, please.
Again, check how the dynamics of all the detected particles are done in various experiments and tell me that their ability to reconstruct the particle's path leading to the detected spot is consistent with that you are saying. You may start by analyzing all those ARPES experiments.
ALL of them.
Thank you.
Bingo!
This thread should not be turned into a "photon doesn't exist", especially when you have not offered (or are even aware of) any of those experiments that explicitly invoke the photon picture in the physics.
Zz.
  • #241
ZapperZ said:
You seem to have a very strange way of making a position measurement, and then telling me something else about it. And why are we now talking about a "momentum" along the plane of the screen? This isn't a discussion about the HUP!Zz.
I don’t think you can consider quantum interactions without considering the effects of uncertainty.
I used the above illustration to show that the electron can be in more than one place at anyone time.In the ARPES experiment, apart from the measured value, all other values of momentum are canceled out through the electron’s self interference. Because of the free path between the target and the detector! This does not mean the electron does not possesses other values of momentum and position it is just the experimental set up ensures they do not affect the outcome by allowing for their destructive interference. If any object were to be placed near to the apparent path of the electron then the symmetry of the wave pattern would be disturbed and the results compromised.
ZapperZ said:
The "momentum" that I referred to is the momentum measurement in ARPES where the POSITION of the electron hitting the detector is equivalent to the in-plane momentum of the electron. In fact, it is the in-plane momentum of the electron while it was in the crystal material that emitted the electron in the first place. The resolution of the position corresponds directly to the resolution of the momentum. Refer to any of the latest ARPES papers on high-Tc superconductors, for example, since T. Valla's paper in Science in 1999. You'll see something that looks like my avatar!Zz.
I think here you should be referring to the angular distribution of the detector’s responses
Zz.
That because it’s all basic Physics! My only deviation is to have asserted that the weight evidence suggests that pairs of spatially extended quantum entities become “super-positioned” and interact directly and the result of their interaction produces a macroscopically measurable event at a specific position relative to our reference grids.
Sorry but this has no citation it just jumped out of my head; so where’s the best place for all the info on bunching and anti bunching?
  • #242
Not when it is detected! When I detect it, it has a well-defined position for that one single measurement!
Er.. say what? Where did you get this? What canceled out?
This is very strange. Have you looked at an electron analyzer and figure out what exactly it is that you're talking about?
I have no idea what you are talking about here. I suppose if you muddle it enough, I'd lose contact with what the issue is all about. You're succeeding.
Ah, now things have some explanation on why they are not making any sense.
H. Paul, Rev. Mod. Phys. 54, 1061 (1982)
Zz.
  • #243
I believed it was already established.
Which particle's path? In the thread " Why doesn't QM make particles zig-zag as they travel?" Marlon explained that the line we see in, e.g., a bubble chamber, it's not the particle's trajectory.
Zz.
If you explained what you mean with "multiphoton emission" I could express my opinion on the impossibility to explain it without the notion of photon. A related question: how the experiment of "quantum beats" is interpreted in the photon's paradigm?
  • #244
lightarrow said:
I believed it was already established.Which particle's path? In the thread " Why doesn't QM make particles zig-zag as they travel?" Marlon explained that the line we see in, e.g., a bubble chamber, it's not the particle's trajectory.
But we are not talking about a "bubble chamber" (that is a whole different matter here and I can easily point to you an even clearly tracking of single-electron motion, which I had already cited and commented on). So don't change the subject AGAIN!
I have no idea what this argument is all about. For some odd reason, you somehow dispute that a detection of a photon, electron, neutron, etc... on some detector somehow cannot be extrapolated back onto a path of where it came from? I'm not talking about BEFORE detection. I'm talking about from the moment of detection.
If this is exactly what you are claiming, then as I've said before, please write a rebuttal to all those astrophysics and high energy physics papers and tell them that their vertex reconstruction is outright false. Other than that, I have no patience left in arguing about the validity of photons because you have made no attempt at doing what I asked you to do, which is to find alternative explanations for all the experiments that I have mentioned.
And I am utterly puzzled why you can't find these experiments yourself. Google Scholar doesn't work for you? I gave you already a review paper on the anti-bunching experiments. Here are the multiphoton papers:
U. Hofer et al. Science v.277, p.1480 (1997).
A. Damascelli et al., Phys. Rev. B v.54, p.6031 (1996).
M. Aeschlimann et al., J. Chem. Phys. v.102, p.8606 (1995).
K. Giesen et al., Phys. Rev. Lett. v55, p.300 (1985).
Until you can come up with a non-photon formulation to describe all this, I suggest you devote your energy it rather than wasting it on here, because as you already know, I'm not going to buy it. And oh, just in case you think I'm just blowing off stuff I barely know, I too have made measurements involving such multiphoton effects, on magnesium photocathodes.
P.S. I noticed that you didn't answer my question about when the last time you looked at an electron analyzer used in ARPES experiments. Why is that?
Zz.
  • #245
This thread is both very long, and seems to be going in about a zillion different directions. Having received complaints about it, I'm going to take the liberty of locking it, because it just doesn't seem to be getting anywhere, and because some of the directions the thread is going in seem to be violating our PF guidelines.
Specifically, we aren't here to defend mainstream science, we are here to explain it.
I will therefore ask people who think that photons are unnecessary to please refrain from posting statements of their opinions unless they can quote a peer reviewed published paper, textbook, or other source which supports this as a current subject of scientific debate in accordance with our guidelines.
It is against our Posting Guidelines to discuss, in most of the PF forums, new or non-mainstream theories or ideas that have not been published in professional peer-reviewed journals or are not part of current professional mainstream scientific discussion.
I'd also like to encourage people to track down some of the references that have already been quoted if at all possible.
Some other people seem to perhaps have questions which fall within our guidelines, which unfortunately don't seem to be very clear. I'd like to encourage these people to post their questions in some other thread, as long as they are questions that fall within our guidelines.
Meanwhile because this thread is just so long and so incoherent, I'm going to put it out of its misery.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
