- #141
- 8,142
- 1,756
Quantum_Prodegy said:oh come on does nobody get my joke? I thought it was funny...:D
I thought it was funny enough to immediately forward it to friends and family.
Quantum_Prodegy said:Gotta love high school...
So there's a chicken and an egg in bed, the egg rolls off the chicken, lights a cigarette and says "well, I guess we solved that riddle".
gerben said:but... how did they solve any riddle? (let alone the "chicken or the egg" riddle)
Mentat said:Do you know what the "chicken or the egg" riddle is?
gerben said:well I thought the riddle was: "what came first, the chicken or the egg?"
What the heck was he using? A 6 inch Pickett?Icebreaker said:Several scientists were all posed the following question: "What is 2 * 2 ?"
The engineer whips out his slide rule (so it's old) and shuffles it back and forth, and finally announces "3.99".
BobG said:What the heck was he using? A 6 inch Pickett?
Taking the natural log of 2, you get about .693. If you're going to make a mistake, you're going to read it too high as .694 - there's just no way to see that as .692. Adding them together, you should know you need to be a little past halfway between the 1.38 and 1.39 mark. Taking the inverse puts you very, very close to 4.00 - maybe someone could read it as 4.01 (if they're sloppy), but only a slide rule novice could think the answer was 3.99.
Or, you could let the 2 be 2 radians. Set the index over the two, put the cursor over the radian symbol, and you get about 114.6 degrees. That's about (180-65.4) degrees. Using the cosine difference law, you square the cosine of (65.4) degrees to get .177 (don't even bother reading the cosine, since you're not using that number) and square the sine of 65.4 to get .828 (both are probably just slightly high, so hopefully the errors will cancel out). The subtraction gets you -.652, which is the cosine of 180 ± 49.3 degrees (or in this case, the cosine of 180+49.3 degrees). Placing the radian symbol over 2.293 (or at least just slightly less than 2.295) results in the index being very, very close to 4.00. Maybe someone could read it as 4.01 (if they're sloppy), but I just don't see how anyone could get 3.99.
Unless ... It is conceivable that someone might align the 2 on the CI scale above the 2 on D scale and then just read the number below the index. If the 2's were misaligned just a bit, then maybe, just maybe, someone might get 3.99. But, the chances of someone choosing that method to solve the problem is just too small to even consider.
Here, this site explains everything (including what a Hemmi is).Quantum_Prodegy said:uuuh...u lost me when you added the log of 2...actually, when you mentioned a "pickett"
at what level of math do you learn to do that? At grade 11 we've learned log and radians (just) but how you applied that to 2*2 i have no idea, and what are the CI and D scales?
Here is the original quote "The great tragedy of Science - the slaying of a beautiful hypothesis by an ugly fact."Icebreaker said:"A mathematical tragedy is a beautiful conjecture ruined by an ugly fact."
Evo said:Here is the original quote "The great tragedy of Science - the slaying of a beautiful hypothesis by an ugly fact."
Thomas H. Huxley (1825 - 1895)
Monique said:"A bloke walks into a pub, and asks for a pint of Adenosinetriphosphate.
The barman says "That'll be 80p please!"
The corollary is true, but who the heck is Jenning?vikasj007 said:JENNING'S COROLLARY- the chances of the bread falling with the buttered side down is directly proportional to the cost of the carpet.
BobG said:The corollary is true, but who the heck is Jenning?
