A Number Raised to the m Power
  • Thread starter Bashyboy
  • Tags
    Power
Good job!In summary, the conversation discusses the proof that a number raised to an even power will always result in a real number. The validity of this statement is discussed using examples and expanding a complex number as a binomial. It is concluded that the statement is only true for m=2 if the number is only real or imaginary.
Bashyboy
1,421
Hello Everyone,
I was wondering, does anyone know of a proof that showed if a number is raised to the mth power, where m is a positive even number, the number is always real?
Mathematics news on Phys.org
(1+2i)4 = -7-24i
Drats! I was hoping it was true! How about if m were only 2? Would the statement then be true?
It isn't: (a + bi)(a + bi) = a^2 + 2abi + b^2i^2 = a^2 + 2abi - b^2
##(1+i)^2=1+2i-1=2i##
Your claim will only be true for ##m=2## if the number is only real or imaginary. This is clear by expanding a complex number as a binomial.
##(a+bi)^2=a^2-b^2+2abi##
In order for this to be real, either ##a## or ##b## must be zero. You should check the case when ##m=4## by squaring ##(a^2-b^2+abi)## to see what you get.
Edit: I see that you figured it out as I was posting
Likes 1 person
1. What does it mean to raise a number to the m power?
Raising a number to the m power means multiplying the number by itself m times. It is also known as exponentiation.
2. How is a number raised to the m power calculated?
To calculate a number raised to the m power, you can use the formula:
am = a x a x a x ... (m times)
Alternatively, you can use a calculator or a programming language to perform the calculation for you.
3. What are the properties of a number raised to the m power?
The properties of a number raised to the m power include:
- The commutative property: am = ma
- The associative property: (ab)m = ab x m
- The distributive property: (a x b)m = am x bm
- The power of a power property: (ab)m = ab x m
4. What are some examples of raising a number to the m power?
Some examples of raising a number to the m power include:
- 23 = 2 x 2 x 2 = 8
- 52 = 5 x 5 = 25
- 104 = 10 x 10 x 10 x 10 = 10,000
- (-3)2 = (-3) x (-3) = 9
5. How is raising a number to the m power related to logarithms?
Raising a number to the m power and logarithms are inverse operations. This means that if a number is raised to the m power and then the result is taken to the logarithm base m, the original number will be obtained. For example:
log3(34) = 4
Similarly, if a logarithm base m is raised to the power of m, the result will be the original number. For example:
3log3(5) = 5
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
