First Order Differential Equations
In summary, the conversation discusses solving a differential equation using separation of variables. The attempt at a solution involves trying different methods, including substitution and integrating using a standard formula. Ultimately, the poster is able to successfully solve the equation.
Bucky
82
Solve the following differential equation using separation of variables
[tex] (1+x)^2 y' = (1-y)^2 , y(1) = 2 [/tex]
haven't gotten very far in this at all :/
i've tried dividing both sides by [tex](1+x)^2[/tex], in order to get y' on it's own..
[tex]y' = \frac{(1-y)^2}{(1+x)^2} [/tex]but i don't know how to integrate this...but had a go anyway
apparently the rule for integrating an expression in brackets is..
[tex] \frac{(ax + b)^n}{a(n+1)} [/tex]
so i tried integrating both halves of the fraction seperatley...giving
[tex]
\frac{(-y+1)^3 }{-3y}[/tex]
[tex]
\frac{(x+1)^2}{3x}
[/tex]
putting these together and dividing gave
[tex]\frac{3x(-y+1)^2}{-3y(x+1)^3} + C[/tex]however i don't think this is accurage, as substituting in 1 and 2 for x and y respectivley gmade C some out as -3/48. Can someone shed some light at where I've went wrong?
You haven't gotten y on it's own. Write y'=dy/dx and put the dy with the y's and the dx with the x's.
are you saying i need to get the y terms on one side of the equals and the x terms on the other side?
if so then I'm stumped. I'm not sure how to split up the equation in it's initial form.
How about dy/(1-y)^2=dx/(1+x)^2? Does it look split now?
ok, right, rearranged it and here's what i have:
[tex]\int \frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
[tex]\frac {1}{(1-y)^3}{3} = {1}{(1+x)^3}{3} + C[/tex]
which, after substituting y(0) = -1 (wrong values on first post BTW) i get
[tex]\frac{-7}{24} = C[/tex]
I'm pretty sure this is wrong...but anyway let's sub that back into the integrated function
[tex] \frac{1}{3} (1-y)^3 = \frac{1}{3} (1+x)^3 - 7/24 [/tex]
[tex] \frac 8(1-y)^3 = 8(1+x)^3 - 7[/tex]
the answer in teh book is given as
[tex] y = \frac{x-1}{1+3x}[/tex]
It would help a lot if you did the integrations correctly. The integral of 1/x^2 is not 1/x^3.
er sorry that's a typo, i get the integral of 1/(1+x)^3 to be...
1/3(1+x)^3
You want to integrate 1/(1+x)^2. Try again.
Hint: integral of 1/u^2 du=-1/u.
so...the integral of 1/(1+x)^2 is just -1 - (1/x) ?
even that doesn't seem right...though my formula book doesn't have the formula for such an instance.
Make a substitution u=x+1. Similarly for the y integral. You have done that, right?
ok so that gives...
[tex]- \frac{1}{(1-y)} = - \frac{1}{(1+x)} [/tex]
[tex]\int \frac{dy}{(1-y)^2} = \int \frac{dx}{(1+x)^2}[/tex]
I added the integral sign on the right side.
I think you meant
[tex]\frac{1}{3(1-y)^3}= \frac{1}{3(1+x)^3}+ C[/tex]
but you've missed a sign. But only one sign. As Dick said you need to substitute for both 1+ x and 1- y. If u= 1- y, what is du?
HallsofIvy said:
I think you meant
I think Halls was just cleaning up your notation and doesn't mean to imply that cube is the right power. But you did miss the substitution sign.
i don't see where the missing sign is. unless the sign attatched to the letter comes out? but that's not what i thought you meant when you said
1/u^2 = -1/u
so do you mean that i should have...
[tex]\frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
[tex]-\frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
EDIT: wait that can't be right...yeah I'm lost.
Bucky said:
ok so that gives...
If you differentiate the right side of this you get 1/(1+x)^2. That's what you want. If you differentiate the left side you get -1/(1-y)^2. Don't forget the chain rule. That's NOT what you want.
1/u^2 = -1/u
He certainly never said that! he said that the anti-derivative of 1/u2 is -1/u.
If you let u= 1+ x, then du= dx and dx/(1+x)2= du/u2. What's the anti-derivative of that?
If you let v= 1-y, then dv= -dy and y/(1-y)2= -dv/v2. What's the anti-derivative of that?
ok so i tried a totally different method and it seems to work.
instaed of substitution i tried using the standard integral
[tex] \int (ax+b)^n = \frac{(ax+b)^{n+1}}{a(n+1)} [/tex]
thanks a lot for your help guys!
Let u=(ax+b), du=a*dx, du/a=dx.
[tex] \int (ax+b)^n dx= \frac{1}{a} \int (u)^n du = \frac{1}{a}
\frac{u^(n+1)}{(n+1)} = \frac{(ax+b)^{n+1}}{a(n+1)}[/tex]
That is a TOTALLY DIFFERENT METHOD!
\frac{u^{n+1}}{(n+1)} = \frac{(ax+b)^{n+1}}{a(n+1)}[/tex]
What is a first order differential equation?
A first order differential equation is a mathematical equation that relates an unknown function to its derivative (or rate of change). It is called "first order" because it involves only the first derivative of the function.
What is the difference between an ordinary and a partial first order differential equation?
An ordinary first order differential equation involves only one independent variable, while a partial first order differential equation involves multiple independent variables. In other words, ordinary differential equations deal with functions of a single variable, while partial differential equations deal with functions of multiple variables.
What are some real-life applications of first order differential equations?
First order differential equations are used to model a wide variety of natural phenomena, such as population growth, chemical reactions, and circuit analysis. They are also used in engineering and physics to describe motion, heat transfer, and fluid flow.
What are the methods for solving first order differential equations?
There are several methods for solving first order differential equations, including separation of variables, integrating factors, and using power series. Other methods include numerical approximation techniques, such as Euler's method and Runge-Kutta methods.
What are initial value problems and boundary value problems for first order differential equations?
An initial value problem for a first order differential equation involves finding a solution that satisfies a given initial condition. This means that the value of the function and its derivative are known at a specific point. A boundary value problem, on the other hand, involves finding a solution that satisfies certain conditions at different points in the domain of the function.
