What does space quantization of angular momentum actually signify?
In summary, according to the orthodox interpretation of quantum mechanics, angular momentum is quantized and its direction is also quantized. However, in the de Broglie-Bohm interpretation, angular momentum is conserved and the directions are also conserved.
I_am_learning
682
I have just come to learn (Physics, with modern physics, Richard Wolfson, J M. Pasachoff, second edition) that not only angular momentum's magnitude is quantized, but also its direction.
Its given that, Cos[tex]\theta[/tex]min= l / [tex]\sqrt{l(l+1)}[/tex]
Telling that, [tex]\theta[/tex]min is the minimum angle between any orbital angular momentum (l) and any arbitrary chosen axis.
How can the orbital angular momentum always make certain minimum angle [tex]\theta[/tex]min with any arbitrarily chosen axis?
What if my chosen axis happens (by chance) to be the same axis of the orbital angular momentum?
It seems that my question was wrong. (no reply for so long)
What I am basically asking is --> What do direction quantization (of angular momentum) signify? Does it signifiy that
1. there should be only discrete angles between different angular momenta
OR
2. As I said in OP, there should be only discrete angles (greater than [tex]\theta[/tex]min) between any angular momenta and any chosen arbitrary axis
OR
Hi there,
One of the reasons you're not getting an answer is that in the orthodox interpretation of QM, the answer is 'the question is meaningless since we can never know the reality of a quantum system'.
In other interpretations such as many-worlds people only ever concern themselves with eternal verities and speaking in logically consistent sentences rather than concerning themselves with ontology or 'what really might be going on'. So they're not going to answer you either.
So conventionally one may speak of 'angular momentum' but you have to do 'air quotes' with your fingers as if to say 'but not really'.
In the de Broglie-Bohm interpretation however, the answer is as usual, straightforward. Particles have trajectories, pushed around by an objectively existing wave field represented mathematically by the wave function. And orbital angular momentum really is the angular momentum of particles 'orbiting' the nucleus. Of course this is a bit difficult if you believe that particles only exist when you look at them (as in the orthodox view).
Why is it quantized? You have to remember that in de Broglie-Bohm theory quantities are well-defined and continuously variable for all quantum states - values for the subset of wave functions which are eigenstates of some operator have no fundamental physical significance. So this characteristic features of QM - the existence of discrete energy levels - is due to the restriction of a basically continuous theory to motion associated with a subclass of eigenfunctions.
Now what happens with angular momentum? Let's say we prepare the system with a wave function which is an eigenfunction of the [tex]{\hat L}_z[/tex] operator (where the direction of the z-axis is arbitrary). Then the z component of the angular momentum will coincide with the eigenvalue of [tex]{\hat L}_z[/tex], and the total orbital angular momentum with the eigenvalue of [tex]{\hat L}^2[/tex]. Conventionally one would say that the x- and y- components are 'undefined'. However, in de Broglie-Bohm they are perfectly well-defined. In fact you have:
[tex]L_x= -m \hbar \cot \theta \cos \theta[/tex]
[tex]L_y = m\hbar \cot \theta \sin \theta[/tex]
[tex]L_z = m\hbar [/tex]
So the difference is that along the trajectory [tex]L_z[/tex] and the total angular momentum are conserved, but [tex]L_x[/tex] and [tex]L_y[/tex] are not. Thus, although the classical force is central the motion is asymmetrical, which reflects the fact that a particular direction in space has been singled out as the quantization axis.
Hope this helps, though I suspect it won't for some reason.
Quantization does not mean that there may not be intermediary values.
Take a superposition of different wave functions and you will obtain an average value between the discrete values. Normally the wave functions are superpositions rather than the eigenstates.
zenith8 said:
Hi there,
First of all, thank you for answering.
To make matter clear: I am not confused to accept that Energy and angular momentum is conserved. I can readily accept it by saying that, its what mathematically follows, if you solve Schrödinger's equation for electron bound to a nucleus and apply boundary conditions for the wave function.
What I am confused about is, direction quantization of Angular Momentum; from which follows a absurd sounding statement that --> whichever arbitrary axis you chose in space, the angular momentum isn't aligned to that axis!(it always makes some minimum angle with my arbitary axis)?
I hope you understand what I meant.
What is space quantization of angular momentum?
Space quantization of angular momentum is a concept in quantum mechanics that states that the angular momentum of a particle can only take on certain discrete values, rather than being continuous. This means that the angular momentum of a particle can only exist at specific levels, and cannot have any intermediate values.
What does space quantization of angular momentum signify?
Space quantization of angular momentum signifies that there are fundamental restrictions on the possible values of angular momentum in a quantum system. It shows that angular momentum is not continuous, as was previously believed, but rather exists at specific levels. This has important implications for our understanding of the behavior of particles at the quantum level.
How does space quantization of angular momentum affect the behavior of particles?
Space quantization of angular momentum affects the behavior of particles by limiting the possible values of their angular momentum. This leads to quantized energy levels and the phenomenon of spin, which is a type of angular momentum that particles possess due to their quantum nature. This concept is essential for understanding the behavior of particles in atoms and other quantum systems.
What is the significance of space quantization of angular momentum in quantum physics?
The significance of space quantization of angular momentum in quantum physics is that it provides a more accurate and complete understanding of the behavior of particles at the quantum level. It also helps to explain various phenomena, such as the quantized energy levels in atoms and the spin of particles. Additionally, it has practical applications in fields such as quantum computing and magnetic resonance imaging.
Is space quantization of angular momentum a proven concept?
Yes, space quantization of angular momentum is a well-established concept in quantum mechanics. It has been extensively studied and verified through experiments, and its predictions have been confirmed to be accurate. This concept is a fundamental part of our current understanding of the behavior of particles at the quantum level.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
