| New Reply |
Sequences and series problem |
Share Thread | Thread Tools |
| Nov23-12, 07:27 AM | #1 |
1. The problem statement, all variables and given/known data
Read this passage and then answer the questions that follow We know that, if [itex]a_1,a_2,.........,a_n[/itex] are in Harmonic Progression, then [itex]\frac{1}{a_1},\frac{1}{a_2}.........,\frac{1}{a_n},[/itex] are in Arithmetic Progression and vice versa. If [itex]a_1,a_2,.........,a_n[/itex] are in Arithmetic Progression with common difference d, then for any b(>0), the numbers [itex]b^{a_1},b^{a_2},b^{a_3},.......,b^{a_n}[/itex] are in Geometric Progression with common ratio r, then for any base b(b>0), [itex]log_b a_1,log_b a_2,...........,log_b a_n[/itex] are in Arithmetic Progression with common difference [itex]log_b r[/itex] Q.1. Given a Geometric Progression and an Arithmetic Progression with positive terms [itex]a,a_1,a_2,.........,a_n[/itex] and [itex]b, b_1, b_2,.............,b_n[/itex]. The common ratio of the Geometric Progression is different from 1. Then there exists [itex]x \in R^+[/itex], such that [itex]log_x a_n-log_x a[/itex] is equal to 2. Relevant equations 3. The attempt at a solution Let the common ratio of the given Geometric Progression be r. [itex]r= \left( \frac{a_n}{a} \right) ^{1/n}[/itex] Now from the last statement of the passage I can deduce that For [itex]x \in R^+ \\ log_x a, log_x a_1,.......,log_x a_n[/itex] is in Arithmetic Progression with common difference (D) = [itex]log_x \left( \frac{a_n}{a} \right)^{1/n}[/itex] Let the common difference of the given Arithmetic Progression(not the above one) be d. [itex]d= \dfrac{b_n - b}{n}[/itex] Now from the second statement of the passage I can deduce that For [itex]x \in R^+ \\ x^b, x^{b_1},............,x^{b_n}[/itex] is in Geometric Progression with common ratio (R) = [itex] x^{\frac{b_n - b}{n}}[/itex] I have to find [itex]log_x \dfrac{a_n}{a} \\ nlogD=log_x \dfrac{a_n}{a}\\ n=\dfrac{logx}{logR} (b_n - b)[/itex] Substituting the value of n from above into nlogD I get [itex]\dfrac{logx}{logR} (b_n - b) logD[/itex] |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov23-12, 09:14 AM | #2 |
| Nov23-12, 12:19 PM | #3 |
| Nov23-12, 02:11 PM | #4 |
In terms of what?
| Nov24-12, 06:58 AM | #5 |
a)a-b b)[itex]a_n -b[/itex] c)[itex]b_n - b[/itex] d)[itex]a_n - b_n [/itex] |
| Nov24-12, 04:36 PM | #6 |
Depending on your choice of x, you can make it equal to a lot of things. To be more precise:
[tex]\log_x(a_n)-\log_x(a)=\frac{\log(a_n)-\log(a)}{\log(x)}=\frac{\log(a_n/a)}{\log(x)}[/tex] Also, the restriction [itex]x>0[/itex] has no implications because [itex]\log(0)[/itex] is already undefined. |
| New Reply |
| Thread Tools | |
Similar Threads for: Sequences and series problem
| Thread | Forum | Replies | ||
| Sequences/Series Problem Based on Medication | Calculus & Beyond Homework | 44 | ||
| Sequences and Series Problem. Help!!!! Pleeaassee!!! | Precalculus Mathematics Homework | 3 | ||
| Divergent Harmonic Series, Convergent P-Series (Cauchy sequences) | Calculus & Beyond Homework | 1 | ||
| series and sequences problem | Calculus & Beyond Homework | 1 | ||
| Sequences and Series problem | Precalculus Mathematics Homework | 4 | ||
