Problem in determining the moisture content
by tsy8804
Tags: content, determining, flow rate, moisture, moisture content, tube pressure
tsy8804
tsy8804 is offline
#1
Jan6-14, 07:31 PM
P: 1
Dear all chemist,
I am a biologist and need everyone help to provide your advice in order for me to continue my research.
I am currently looking for a formula to calculate the expected moisture content of a particular sample which will be flow through a tube inside the machine container. I have the reading of pressure which apply to suck the sample up from the tube end.
The purpose to calculate out the moisture content is due to certain concentration is only able to be suck up by apply certain pressure, and right now I would like to figure out what concentration/moisture content of sample is needed for a particular pressure to suck up.
May I know is there have any formula for me to calculate it out?
Thank you.
Phys.Org News Partner Chemistry news on Phys.org
Mantis shrimp stronger than airplanes
MRI sensor that enables long-term monitoring of oxygen levels could aid cancer diagnosis, treatment
The anti-inflammatory factory
Borek
Borek is offline
#2
Jan7-14, 02:35 AM
Admin
Borek's Avatar
P: 22,708
Your question is rather unclear, and without knowing details about what the sample is and what you know about it is rather impossible to answer.
However, my bet is that the answer is no - you can't calculate moisture content, but you should be able to determine it. Then finding an experimental dependency between pressure and moisture level should be trivial, unless fluctuations of the sample behavior are large.
Register to reply
Related Discussions
Prove if S and T are sets with outer content zero, SUT has outer content zero. Calculus & Beyond Homework 3
evaporation moisture Advanced Physics Homework 2
How to determine the moisture content of concrete Materials & Chemical Engineering 6
Matlab coding problem (Black-Scholes Option Pricing content) Math & Science Software 0
Need Help Air/Moisture General Physics 0
