Electric field of a line charge and point charge
In summary, the problem involves a 39.2 cm long rod with a positive charge density of 72.0 mC/m placed along the y-axis and centered at the origin. A charge of +46.5 mC is placed 68.4 cm from the midpoint of the rod on the positive x-axis. The electric field at a point on the x-axis, which is halfway between the point charge and the center of the rod, is calculated by subtracting the individual electric fields from the line charge and point charge. This can also be calculated by integrating the field from each element of charge along the line, taking into account the linear charge density and distance from the point to the upper limit of the line of charge.
GravityGirl
29
A thin rod 39.2 cm long is charged uniformly with a positive charge density of 72.0 mC/m. The rod is placed along the y-axis and is centered at the origin. A charge of +46.5 mC is placed 68.4 cm from the midpoint of the rod on the positive x-axis. Calculate the electric field at a point on the x-axis, which is halfway between the point charge and the center of the rod. (Express your answer in terms of the unit vector x. For example, if the electric field is -10.5x N/C, then input -10.5 N/C.)
ok..so i drew a picture and i see that the E field of te line charge will be in the x direction becuase that i perpendicular to the line
i also see that the point charge will be in the x direction as well becuase it is located on the x-axis
so since both charges are postive and the point where i want to know the E field at is between them i am going to subtract their individual E fields at that point to get the net
E=Eline-Epoint
Eline=2K(lamda)/r where r= half the distance betwen the line and point charge
Epoint=kq/r^2
so i have E=(2k(lamda)/r)-(kq/r^2)
does this look right?...if not, please tell me what i am doing wrong
OK.
The field from that charge will point along the negative x-axis.
E=Eline-Epoint
OK. But I would prefer that you viewed it as adding the positive field from the line charge to the negative field from the point charge.
That formula applies to an infinitely long line charge. For a finite line charge you need to integrate.
Epoint=kq/r^2
OK.
Oops. I must've misread what GravityGirl wrote. :redface:
ok so if i am to integrat across the line charge then i would have
integral of Kdq/r^2=kQ/x(x-L) where L= the length of the rod and x= the distance to the point where i want to find the E field
so now i have (KQ/x(x-L))-(kQpoint/r^2)=E
but doesn't gauss's law also work (what i did above)
How did you get that answer? Doesn't look right to me. (What if x = L?)
Gauss's law is only useful when there is enough symmetry to simplify the calculation of the electric flux. That's true with an infinite line of charge, since you know the field must be radial; but not true with a finite line of charge.
i got the simplified answer to the integral from my book...but what about if is had ...
=k/r^2(intergral of dq)=kQ/r^2
does that look better??
That's only true for a point charge at one location. In a line charge, each charge element is at a different distance and direction. Read this: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html"
i see that the equation Ez is the same equation that i wa using in the firs attempt
so should Eline=2k(lamda)/r?
No it isn't. Make sure you are looking at the right equation.
No, as I said before, that only applies to an infinitely long line of charge.
Ok here can't we just take it as a distance of 68.4/2 = 34.1 cm from the midpoint of the rod? And then just integrate k dq/r^2? with r = 34.1 cm which can be converted to metres later.
You cannot treat the line charge as if its charge were concentrated at its center, if that's what you're thinking.
No I am not thinking that
I am thinking that if we take the symmetry from the line charge from both the sides, then we get the x component of the E field at 34.1 cm right?
I still don't understand what you mean. To calculate the field from that line charge you must integrate the field from each element of charge along the line. By symmetry, you know that there will only be an x component of the field.
you can integrate the function dE=kdQ/(r^2). dQ=lambda dy where lambda is the linear charge density Q/a where a is the length of the line of charge. and you find the y component by multiplying by the unit vector sin(phi) where phi is the angle between the x-axis and r where r is the distance from P(x,y) to the upper limit of your line of charge. r=sqrt(x^2+y^2) SO YOU GET...S dE_y= kQ/(a) S[(y)r^(-3/2)]dy.
What you will get if you integrate the right side from 0 to a is the y component of your Electric field. To find the x component uses a similar process but the integral is a bit trickier (trig substitution) Then you can plug and chug away.
there is probably an easier way to do this but i think the long way helps build an intuition because now its clear as day for me.
1. What is an electric field?
An electric field is a physical quantity that describes the influence a charged particle has on other charged particles in its vicinity. It is represented by a vector quantity and is measured in Newtons per Coulomb (N/C).
2. What is a line charge?
A line charge is an infinitely long, one-dimensional charge distribution. It can be thought of as a continuous line of charged particles with equal and opposite charges, resulting in a net charge of zero.
3. How is the electric field of a line charge calculated?
The electric field of a line charge can be calculated using Coulomb's law, which states that the electric field at a point is directly proportional to the magnitude of the charge and inversely proportional to the square of the distance from the charge. The formula for the electric field of a line charge is E = λ/(2πε0r), where λ is the linear charge density, ε0 is the permittivity of free space, and r is the distance from the charge.
4. What is a point charge?
A point charge is a single, isolated charged particle with a non-zero charge. It is considered to have a negligible size and can be represented as a mathematical point.
5. How is the electric field of a point charge calculated?
The electric field of a point charge can be calculated using Coulomb's law, which states that the electric field at a point is directly proportional to the magnitude of the charge and inversely proportional to the square of the distance from the charge. The formula for the electric field of a point charge is E = kQ/r2, where k is the Coulomb's constant, Q is the charge of the particle, and r is the distance from the particle.
