Some Weird Questions On Aerodynamics
In summary, the conversation revolves around the question of whether a human head can be thrown as far as a perfectly round 10 lb rock using a machine with constant force and distance of propulsion. The general consensus is that due to its lack of aerodynamic efficiency, the human head would not be able to match the distance of the rock. However, factors such as hair length and shape of the head could potentially affect the outcome. The only way to know for sure would be to try it out, perhaps during Halloween.
TheAzn
Sorry for this weird thread.
Say that you throw a perfectly round 10 lb stone rock using a machine with constant force and distance of propulsion.
Can a 10 lb ("average") human head,with full hair about 2 inches long, be thrown -using the same machine - just as far as the 10 lb rock?
How about a 10 lb human head with a shaved head?
Again, I apologize for these weird questions. It's just that I was arguing with someone and this topic came up. My position was that a human head is not really aerodynamically efficient, and will fall far short behind the perfectly round 10 lb rock.
That is weird.
For a minute there I thought you meant a 10 pound human head of size 2 inches, in which case there might not be on PF an expert in shrunken heads but you never know.
If your machine throws your bowling ball rock 10 feet, then it would necessarily throw the human head 10 feet also
As the distance of throw increases, the velocity of ejection also increases, and so does the air drag. I would again assume the human head would have more drag then a bowling ball, so the bowling ball wins the toss contest and gets the gold.
The hairy head would get bronze and the bald one silver.
Then again, are these pointy heads shaped like a bullet in which case all bets are off.
on the other hand the dimples on a golf ball make it go further. So it's not totally inconceivable that the "head" might go further at high enough velocities (and perhaps with a bit of spin).
There is only one way to find out and halloween is coming soon :-)
That is true :D
Are you planning to storm a castle soon or something?
Just in general, a human head will use more drag than an equivalently sized spherical object so you would likely need more throwing power. Put a bigger counterweight on that trebuchet!
1. What is aerodynamics?
Aerodynamics is the study of how air moves around objects and how those objects react to the movement of air. It is a branch of physics that is important in understanding the behavior of airplanes, cars, and other objects that move through air.
2. How does aerodynamics affect flight?
Aerodynamics plays a crucial role in flight as it determines the lift, drag, and thrust of an aircraft. The shape, size, and angle of an aircraft's wings and body determine how it moves through the air and how much fuel is needed to keep it flying.
3. What are some factors that affect aerodynamics?
Some key factors that affect aerodynamics include the shape and size of an object, the speed at which it is moving, the density and viscosity of the air, and the angle at which the object meets the air. Other factors that can impact aerodynamics include turbulence, wind, and air pressure.
4. How does aerodynamics impact fuel efficiency?
Aerodynamics has a significant impact on fuel efficiency as it can either increase or decrease the amount of drag an object experiences when moving through the air. A more aerodynamically designed object experiences less drag, which means it requires less fuel to maintain its speed and momentum.
5. How has our understanding of aerodynamics changed over time?
Our understanding of aerodynamics has greatly evolved over time with advancements in technology and scientific research. The development of tools such as wind tunnels and computer simulations have allowed scientists to study and analyze aerodynamics in much greater detail, leading to more accurate and efficient designs in various industries such as aviation, automotive, and sports.
