Find the critical points of (x^2+y^2-4)(x+y) and their nature
In summary, the student is trying to find the critical points of a function and its nature. However, he is having trouble solving the problem analytically and would like to understand how it is done. He has tried to eliminate a variable and found that it is not possible due to the 2xy term. Another solution would be to write the ellipses in a parametric form, but this he feels would be overly complicated. He has also tried to find the intersections of the ellipses but is having trouble doing so.
rbnvrw
Hi,
I am studying for my Analysis final and came across this problem I just can't get my head around:
Find the critical points of [itex]f(x,y) = (x^2+y^2-4)(x+y)[/itex] and their nature.
[itex]\vec{\nabla} f(x,y) = \vec{0}[/itex]
[itex]\frac{\partial f(x,y)}{\partial x} = 3x^2+2xy+y^2-4 = 0[/itex]
[itex]\frac{\partial f(x,y)}{\partial y} = 3y^2+2xy+x^2-4 = 0[/itex]
These are both ellipses with center (0,0) and angles [itex]\frac{5\pi}{8}[/itex] and [itex]\frac{\pi}{8}[/itex] respectively.
According to Wolfram Alpha, there are four intersection points. (Click here to view) However, I need to solve this problem analytically and I wish to understand how it is done.
I have tried to eliminate a variable from the equations, but it is not possible due to the [itex]2xy[/itex] term. Another solution would be to write the ellipses in a parametric form, but this I feel would be overly complicated.
Could anyone please shed some light on this?
Thanks in advance!
rbnvrw said:
Hi,
The first thing I would do is subtract one equation from the other to get
[tex]3(x^2- y^2)+ (y^2- x^2)= 2(x^2- y^2)= 0[/tex]
so that either y= x or y= -x.
Thanks in advance!
Subtract the second equation from the first one and factorise.
ehild
Thanks for your advice.
However, this doesn't give me the four points of intersection. If I take the solutions [itex]y=\pm x[/itex], I get the solutions [itex] (0,0) \wedge (\pm \sqrt{2},\pm \sqrt{2})[/itex].
However, the points [itex] (\pm \sqrt{\frac{2}{3}},\pm \sqrt{\frac{2}{3}})[/itex] are also solutions of the equation. And the point [itex](0,0)[/itex] is not a solution at all.
How would I get the other two points?
Thanks in advance!
Your values are not correct. Give the solutions as pairs.
(√2, √2) is not a solution, but (√2, -√2) is.
(0,0) is not a solution. How did you get it? If you substitute x=y into one of the original equation, you will get the pair with √(2/3)
ehild
I got this:
[itex]y = \pm x[/itex]
[itex](x^2+x^2-4)(x+x)=0[/itex]
[itex]x(x^2-2)=0[/itex]
[itex]x = 0 \vee x=\pm \sqrt{2}[/itex]
According to the solutions manual, which only states the values, not the method, the solutions are:
[itex]x = \pm \sqrt{2} \vee x = \pm \sqrt{\frac{2}{3}}[/itex]
Oops... I see it now. I used f(x,y) instead of the partial derivatives.
I will try again!
Yes! I got it!
Thank you for your help, I appreciate it! :D
You see, it was worth to write it again...:smile:
ehild
1. What are critical points?
Critical points are points on a graph where the derivative is equal to zero or undefined. They are important because they can tell us about the behavior of a function and where it reaches its maximum or minimum values.
2. How do you find the critical points of a function?
To find the critical points of a function, you need to take the derivative of the function and set it equal to zero. Then, solve for the values of x and y that make the derivative equal to zero or undefined. These values will be the critical points of the function.
3. What is the nature of a critical point?
The nature of a critical point can be determined by looking at the second derivative of the function at that point. If the second derivative is positive, the critical point is a minimum. If the second derivative is negative, the critical point is a maximum. If the second derivative is zero, the nature of the critical point is inconclusive and further analysis is needed.
4. How do you determine the nature of a critical point?
To determine the nature of a critical point, you need to evaluate the second derivative of the function at that point. If the second derivative is positive, the critical point is a minimum. If the second derivative is negative, the critical point is a maximum. If the second derivative is zero, the nature of the critical point is inconclusive and further analysis is needed.
5. How many critical points can a function have?
A function can have multiple critical points, depending on the complexity of the function. For example, a polynomial function of degree n can have up to n-1 critical points. However, some functions may not have any critical points at all.
